[petsc-users] Memory growth issue
Sanjay Govindjee
s_g at berkeley.edu
Mon Jun 3 18:35:20 CDT 2019
Junchao,
I won't be feasible to share the code but I will run a similar test
as you have done (large problem); I will
try with both MPICH and OpenMPI. I also agree that deltas are not ideal
as there they do not account for latency in the freeing of memory
etc. But I will note when we have the memory growth issue latency
associated with free( ) appears not to be in play since the total
memory footprint grows monotonically.
I'll also have a look at massif. If you figure out the interface,
and can send me the lines to instrument the code with that will save me
some time.
-sanjay
On 6/3/19 3:17 PM, Zhang, Junchao wrote:
> Sanjay & Barry,
> Sorry, I made a mistake that I said I could reproduced Sanjay's
> experiments. I found 1) to correctly use PetscMallocGetCurrentUsage()
> when petsc is configured without debugging, I have to add -malloc to
> run the program. 2) I have to instrument the code outside of
> KSPSolve(). In my case, it is in SNESSolve_NEWTONLS. In old
> experiments, I did it inside KSPSolve. Since KSPSolve can recursively
> call KSPSolve, the old results were misleading.
> With these fixes, I measured differences of RSS and Petsc malloc
> before/after KSPSolve. I did experiments on MacBook
> using src/ts/examples/tutorials/advection-diffusion-reaction/ex5.c
> with commands like mpirun -n 4 ./ex5 -da_grid_x 64 -da_grid_y 64
> -ts_type beuler -ts_max_steps 500 -malloc.
> I find if the grid size is small, I can see a non-zero RSS-delta
> randomly, either with one mpi rank or multiple ranks, with MPICH or
> OpenMPI. If I increase grid sizes, e.g., -da_grid_x 256 -da_grid_y
> 256, I only see non-zero RSS-delta randomly at the first few
> iterations (with MPICH or OpenMPI). When the computer workload is high
> by simultaneously running ex5-openmpi and ex5-mpich, the MPICH one
> pops up much more non-zero RSS-delta. But "Malloc Delta" behavior is
> stable across all runs. There is only one nonzero malloc delta value
> in the first KSPSolve call. All remaining are zero. Something like this:
> mpirun -n 4 ./ex5-mpich -da_grid_x 256 -da_grid_y 256 -ts_type
> RSS Delta= 32489472, Malloc Delta= 26290304, RSS End= 136114176
> RSS Delta= 32768, Malloc Delta= 0, RSS End= 138510336
> RSS Delta= 0, Malloc Delta= 0, RSS End= 138522624
> RSS Delta= 0, Malloc Delta= 0, RSS End= 138539008
> So I think I can conclude there is no unfreed memory in KSPSolve()
> allocated by PETSc. Has MPICH allocated unfreed memory in KSPSolve?
> That is possible and I am trying to find a way like
> PetscMallocGetCurrentUsage() to measure that. Also, I think RSS delta
> is not a good way to measure memory allocation. It is dynamic and
> depends on state of the computer (swap, shared libraries loaded etc)
> when running the code. We should focus on malloc instead. If there
> was a valgrind tool, like performance profiling tools, that can let
> users measure memory allocated but not freed in a user specified code
> segment, that would be very helpful in this case. But I have not found
> one.
> Sanjay, did you say currently you could run with OpenMPI without out
> of memory, but with MPICH, you ran out of memory? Is it feasible to
> share your code so that I can test with? Thanks.
> --Junchao Zhang
> On Sat, Jun 1, 2019 at 3:21 AM Sanjay Govindjee <s_g at berkeley.edu
> <mailto:s_g at berkeley.edu>> wrote:
> Barry,
> If you look at the graphs I generated (on my Mac), you will see that
> OpenMPI and MPICH have very different values (along with the fact
> that
> MPICH does not seem to adhere
> to the standard (for releasing MPI_ISend resources following and
> MPI_Wait).
> -sanjay
> PS: I agree with Barry's assessment; this is really not that
> acceptable.
> On 6/1/19 1:00 AM, Smith, Barry F. wrote:
> > Junchao,
> > This is insane. Either the OpenMPI library or something in
> the OS underneath related to sockets and interprocess
> communication is grabbing additional space for each round of MPI
> communication! Does MPICH have the same values or different
> values than OpenMP? When you run on Linux do you get the same
> values as Apple or different. --- Same values seem to indicate the
> issue is inside OpenMPI/MPICH different values indicates problem
> is more likely at the OS level. Does this happen only with the
> default VecScatter that uses blocking MPI, what happens with
> PetscSF under Vec? Is it somehow related to PETSc's use of
> nonblocking sends and receives? One could presumably use valgrind
> to see exactly what lines in what code are causing these
> increases. I don't think we can just shrug and say this is the way
> it is, we need to track down and understand the cause (and if
> possible fix).
> > Barry
> >> On May 31, 2019, at 2:53 PM, Zhang, Junchao
> <jczhang at mcs.anl.gov <mailto:jczhang at mcs.anl.gov>> wrote:
> >> Sanjay,
> >> I tried petsc with MPICH and OpenMPI on my Macbook. I inserted
> PetscMemoryGetCurrentUsage/PetscMallocGetCurrentUsage at the
> beginning and end of KSPSolve and then computed the delta and
> summed over processes. Then I tested with
> >> With OpenMPI,
> >> mpirun -n 4 ./ex5 -da_grid_x 128 -da_grid_y 128 -ts_type beuler
> -ts_max_steps 500 > 128.log
> >> grep -n -v "RSS Delta= 0, Malloc Delta= 0" 128.log
> >> 1:RSS Delta= 69632, Malloc Delta= 0
> >> 2:RSS Delta= 69632, Malloc Delta= 0
> >> 3:RSS Delta= 69632, Malloc Delta= 0
> >> 4:RSS Delta= 69632, Malloc Delta= 0
> >> 9:RSS Delta=9.25286e+06, Malloc Delta= 0
> >> 22:RSS Delta= 49152, Malloc Delta= 0
> >> 44:RSS Delta= 20480, Malloc Delta= 0
> >> 53:RSS Delta= 49152, Malloc Delta= 0
> >> 66:RSS Delta= 4096, Malloc Delta= 0
> >> 97:RSS Delta= 16384, Malloc Delta= 0
> >> 119:RSS Delta= 20480, Malloc Delta= 0
> >> 141:RSS Delta= 53248, Malloc Delta= 0
> >> 176:RSS Delta= 16384, Malloc Delta= 0
> >> 308:RSS Delta= 16384, Malloc Delta= 0
> >> 352:RSS Delta= 16384, Malloc Delta= 0
> >> 550:RSS Delta= 16384, Malloc Delta= 0
> >> 572:RSS Delta= 16384, Malloc Delta= 0
> >> 669:RSS Delta= 40960, Malloc Delta= 0
> >> 924:RSS Delta= 32768, Malloc Delta= 0
> >> 1694:RSS Delta= 20480, Malloc Delta= 0
> >> 2099:RSS Delta= 16384, Malloc Delta= 0
> >> 2244:RSS Delta= 20480, Malloc Delta= 0
> >> 3001:RSS Delta= 16384, Malloc Delta= 0
> >> 5883:RSS Delta= 16384, Malloc Delta= 0
> >> If I increased the grid
> >> mpirun -n 4 ./ex5 -da_grid_x 512 -da_grid_y 512 -ts_type beuler
> -ts_max_steps 500 -malloc_test >512.log
> >> grep -n -v "RSS Delta= 0, Malloc Delta= 0" 512.log
> >> 1:RSS Delta=1.05267e+06, Malloc Delta= 0
> >> 2:RSS Delta=1.05267e+06, Malloc Delta= 0
> >> 3:RSS Delta=1.05267e+06, Malloc Delta= 0
> >> 4:RSS Delta=1.05267e+06, Malloc Delta= 0
> >> 13:RSS Delta=1.24932e+08, Malloc Delta= 0
> >> So we did see RSS increase in 4k-page sizes after KSPSolve. As
> long as no memory leaks, why do you care about it? Is it because
> you run out of memory?
> >> On Thu, May 30, 2019 at 1:59 PM Smith, Barry F.
> <bsmith at mcs.anl.gov <mailto:bsmith at mcs.anl.gov>> wrote:
> >> Thanks for the update. So the current conclusions are that
> using the Waitall in your code
> >> 1) solves the memory issue with OpenMPI in your code
> >> 2) does not solve the memory issue with PETSc KSPSolve
> >> 3) MPICH has memory issues both for your code and PETSc
> KSPSolve (despite) the wait all fix?
> >> If you literately just comment out the call to KSPSolve() with
> OpenMPI is there no growth in memory usage?
> >> Both 2 and 3 are concerning, indicate possible memory leak bugs
> in MPICH and not freeing all MPI resources in KSPSolve()
> >> Junchao, can you please investigate 2 and 3 with, for example,
> a TS example that uses the linear solver (like with -ts_type
> beuler)? Thanks
> >> Barry
> >>> On May 30, 2019, at 1:47 PM, Sanjay Govindjee
> <s_g at berkeley.edu <mailto:s_g at berkeley.edu>> wrote:
> >>> Lawrence,
> >>> Thanks for taking a look! This is what I had been wondering
> about -- my knowledge of MPI is pretty minimal and
> >>> this origins of the routine were from a programmer we hired a
> decade+ back from NERSC. I'll have to look into
> >>> VecScatter. It will be great to dispense with our
> roll-your-own routines (we even have our own reduceALL scattered
> around the code).
> >>> Interestingly, the MPI_WaitALL has solved the problem when
> using OpenMPI but it still persists with MPICH. Graphs attached.
> >>> I'm going to run with openmpi for now (but I guess I really
> still need to figure out what is wrong with MPICH and WaitALL;
> >>> I'll try Barry's suggestion of
> --download-mpich-configure-arguments="--enable-error-messages=all
> --enable-g" later today and report back).
> >>> Regarding MPI_Barrier, it was put in due a problem that some
> processes were finishing up sending and receiving and exiting the
> subroutine
> >>> before the receiving processes had completed (which resulted
> in data loss as the buffers are freed after the call to the
> routine). MPI_Barrier was the solution proposed
> >>> to us. I don't think I can dispense with it, but will think
> about some more.
> >>> I'm not so sure about using MPI_IRecv as it will require a bit
> of rewriting since right now I process the received
> >>> data sequentially after each blocking MPI_Recv -- clearly
> slower but easier to code.
> >>> Thanks again for the help.
> >>> -sanjay
> >>> On 5/30/19 4:48 AM, Lawrence Mitchell wrote:
> >>>> Hi Sanjay,
> >>>>> On 30 May 2019, at 08:58, Sanjay Govindjee via petsc-users
> <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
> >>>>> The problem seems to persist but with a different
> signature. Graphs attached as before.
> >>>>> Totals with MPICH (NB: single run)
> >>>>> For the CG/Jacobi data_exchange_total = 41,385,984;
> kspsolve_total = 38,289,408
> >>>>> For the GMRES/BJACOBI data_exchange_total = 41,324,544;
> kspsolve_total = 41,324,544
> >>>>> Just reading the MPI docs I am wondering if I need some sort
> of MPI_Wait/MPI_Waitall before my MPI_Barrier in the data exchange
> routine?
> >>>>> I would have thought that with the blocking receives and the
> MPI_Barrier that everything will have fully completed and cleaned
> up before
> >>>>> all processes exited the routine, but perhaps I am wrong on
> that.
> >>>> Skimming the fortran code you sent you do:
> >>>> for i in ...:
> >>>> call MPI_Isend(..., req, ierr)
> >>>> for i in ...:
> >>>> call MPI_Recv(..., ierr)
> >>>> But you never call MPI_Wait on the request you got back from
> the Isend. So the MPI library will never free the data structures
> it created.
> >>>> The usual pattern for these non-blocking communications is to
> allocate an array for the requests of length nsend+nrecv and then do:
> >>>> for i in nsend:
> >>>> call MPI_Isend(..., req[i], ierr)
> >>>> for j in nrecv:
> >>>> call MPI_Irecv(..., req[nsend+j], ierr)
> >>>> call MPI_Waitall(req, ..., ierr)
> >>>> I note also there's no need for the Barrier at the end of the
> routine, this kind of communication does neighbourwise
> synchronisation, no need to add (unnecessary) global
> synchronisation too.
> >>>> As an aside, is there a reason you don't use PETSc's
> VecScatter to manage this global to local exchange?
> >>>> Cheers,
> >>>> Lawrence
> <cg_mpichwall.png><cg_wall.png><gmres_mpichwall.png><gmres_wall.png>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190603/d297feb8/attachment-0001.html>
