[petsc-users] DMNetwork in petsc4py
Abhyankar, Shrirang G shrirang.abhyankar at pnnl.gov
Sun Jun 2 22:59:14 CDT 2019
Justin,
   As far as I know, there are no petsc4py wrappers written yet for DMNetwork and I don’t think anyone is working on it currently. If you are planning to do it then go ahead and let us know what you need.
Shri
From: petsc-users <petsc-users-bounces at mcs.anl.gov> on behalf of Justin Chang via petsc-users <petsc-users at mcs.anl.gov>
Reply-To: Justin Chang <jychang48 at gmail.com>
Date: Monday, May 20, 2019 at 1:50 PM
To: petsc-users <petsc-users at mcs.anl.gov>
Subject: [petsc-users] DMNetwork in petsc4py
Hi all,
Is there any current effort or plan to make the DMNetwork calls available in petsc4py? I don't see anything DMNetwork related in the master branch. Because we (NREL) have lots of existing network-like applications written in Python and Julia, none of which use PETSc, and instead use unscalable direct methods, so I think instead of rewriting everything into a C-based PETSc code it would be much more feasible to integrate their application code into petsc4py with DMNetwork.
If not I was planning on writing these wrappers myself but wasn't sure if someone here is already doing it.
Justin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190603/46996243/attachment.html>
