[petsc-users] MatMultTranspose memory usage
Tue Jul 30 10:34:37 CDT 2019
On Wed, Jul 31, 2019 at 3:25 AM Karl Lin via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hi, Richard,
> We have a new question. Is there a limit for MatCreateMPIAIJ and
> MatSetValues? What I mean is that, we tried to create a sparse matrix and
> populate it with 50GB of data in one process, I got a crash and error
> saying object too big. Thank you for any insight.
1) Always send the complete error.
2) It sounds like you got an out of memory error for that process.
   Matt
> Regards,
> Karl
> On Thu, Jul 18, 2019 at 2:36 PM Mills, Richard Tran via petsc-users <
>> Hi Kun and Karl,
>> If you are using the AIJMKL matrix types and have a recent version of
>> MKL, the AIJMKL code uses MKL's inspector-executor sparse BLAS routines,
>> which are described at
>> https://software.intel.com/en-us/mkl-developer-reference-c-inspector-executor-sparse-blas-routines
>> The inspector-executor analysis routines take the AIJ (compressed sparse
>> row) format data from PETSc and then create a copy in an optimized,
>> internal layout used by MKL. We have to keep PETSc's own, AIJ
>> representation around, as it is needed for several operations that MKL does
>> not provide. This does, unfortunately, mean that roughly double (or more,
>> depending on what MKL decides to do) the amount of memory is required. The
>> reason you see the memory usage increase right when a MatMult() or
>> MatMultTranspose() operation occurs is that the we default to a "lazy"
>> approach to calling the analysis routine (mkl_sparse_optimize()) until an
>> operation that uses an MKL-provided kernel is requested. (You can use an
>> "eager" approach that calls mkl_sparse_optimize() during MatAssemblyEnd()
>> by specifying "-mat_aijmkl_eager_inspection" in the PETSc options.)
>> If memory is at enough of a premium for you that you can't afford the
>> extra copy used by the MKL inspector-executor routines, then I suggest
>> using the usual PETSc AIJ format instead of AIJMKL. AIJ is fairly well
>> optimized for many cases (and even has some hand-optimized kernels using
>> Intel AVX/AVX2/AVX-512 intrinsics) and often outperforms AIJMKL. You should
>> try both AIJ and AIJMKL, anyway, to see which is faster for your
>> combination of problem and computing platform.
>> Best regards,
>> Richard
>> On 7/17/19 8:46 PM, Karl Lin via petsc-users wrote:
>> We also found that if we use MatCreateSeqAIJ, then no more memory
>> increase with matrix vector multiplication. However, with
>> MatCreateMPIAIJMKL, the behavior is consistent.
>> On Wed, Jul 17, 2019 at 5:26 PM Karl Lin <karl.linkui at gmail.com> wrote:
>>> MatCreateMPIAIJMKL
>>> parallel and sequential exhibit the same behavior. In fact, we found
>>> that doing matmult will increase the memory by the size of matrix as well.
>>> On Wed, Jul 17, 2019 at 4:55 PM Zhang, Hong <hzhang at mcs.anl.gov> wrote:
>>>> Karl:
>>>> What matrix format do you use? Run it in parallel or sequential?
>>>> Hong
>>>> We used /proc/self/stat to track the resident set size during program
>>>>> run, and we saw the resident set size jumped by the size of the matrix
>>>>> right after we did matmulttranspose.
>>>>> On Wed, Jul 17, 2019 at 12:04 PM hong--- via petsc-users <
>>>>>> Kun:
>>>>>> How do you know 'MatMultTranpose creates an extra memory copy of
>>>>>> matrix'?
>>>>>> Hong
>>>>>> Hi,
>>>>>>> I was using MatMultTranpose and MatMult to solver a linear system.
>>>>>>> However we found out, MatMultTranpose create an extra memory copy of
>>>>>>> matrix for its operation. This extra memory copy is not stated everywhere
>>>>>>> in petsc manual.
>>>>>>> This basically double my memory requirement to solve my system.
>>>>>>> I remember mkl’s routine can do inplace matrix transpose vector
>>>>>>> product, without transposing the matrix itself.
>>>>>>> Is this always the case? Or there is way to make petsc to do inplace
>>>>>>> matrix transpose vector product.
>>>>>>> Any help is greatly appreciated.
>>>>>>> Regards,
>>>>>>> Kun
>>>>>>> Schlumberger-Private
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190731/9ddd7207/attachment.html>
