[petsc-users] Solving a sequence of linear systems stored on disk with MUMPS
Thibaut Appel
t.appel17 at imperial.ac.uk
Mon Jul 29 05:45:41 CDT 2019
Hi Hong,
Thanks very much for that example I appreciate it.
I'll test that in a few days and come back with questions if needed,
Thibaut
On 25/07/2019 21:25, hong at aspiritech.org wrote:
> Thibaut:
> I added an example (in the branch hzhang/add-ksp-tutorials-ex6/master)
> https://bitbucket.org/petsc/petsc/commits/cf847786fd804b3606d0281d404c4763f36fe475?at=hzhang/add-ksp-tutorials-ex6/master
> You can run it with
> mpiexec -n 2 ./ex6 -num_numfac 2 -pc_type lu
> -pc_factor_mat_solver_type mumps -ksp_monitor -log_view
> MatLUFactorSym 1 1.0 3.5911e-03
> MatLUFactorNum 2 1.0 6.3920e-03
> This shows the code does one symbolic factorization and two numeric
> factorizations.
> For your convenience, the code ex6.c is attached below.
> Let me know if you have encounter any problems.
> Hong
> On Thu, Jul 25, 2019 at 1:30 PM Zhang, Hong via petsc-users
> <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
> Thibaut:
> I'm writing a simple example using KSP directly -- will send to
> you soon.
> Hong
> Hi Hong,
> That sounds like a more reasonable approach, I had no idea the
> PETSc/MUMPS interface could provide such a level of control on
> the solve process. Therefore, after assembling the matrix A_0,
> I should do something along the lines of:
> MatGetFactor(A_0, MATSOLVERMUMPS, MAT_FACTOR_LU, F)
> MatLUFactorSymbolic(F, A_0, NULL, NULL, info)
> MatLUFactorNumeric(F, A_0, info)
> and then call MatSolve? However I don't understand, I thought
> F would remain the same during the whole process but it's an
> input parameter of MatSolve so I'd need one F_m for each A_m?
> Which is not what you mentioned (do one symbolic factorization
> only)
> On a side note, after preallocating and assembling the first
> matrix, should I create/assemble all the others with
> MatDuplicate(A_0, MAT_DO_NOT_COPY_VALUES, A_m)
> Calls to MatSetValues( ... )
> MatAssemblyBegin(A_m, MAT_FINAL_ASSEMBLY)
> MatAssemblyEnd(A_m, MAT_FINAL_ASSEMBLY)
> Is that the recommended/most scalable way of duplicating a
> matrix + its non-zero structure?
> Thank you for your support and suggestions,
> Thibaut
> On 23/07/2019 18:38, Zhang, Hong wrote:
>> Thibaut:
>> Thanks for taking the time. I would typically run that on
>> a small
>> cluster node of 16 or 32 physical cores with 2 or 4
>> sockets. I use 16 or
>> 32 MPI ranks and bind them to cores.
>> The matrices would ALL have the same size and the same
>> nonzero structure
>> - it's just a few numerical values that would differ.
>> You may do one symbolic factorization of A_m, use it in the
>> m-i loop:
>> - numeric factorization of A_m
>> - solve A_m x_m,i = b_m,i
>> in mumps, numeric factorization and solve are scalable.
>> Repeated numeric factorization of A_m are likely faster than
>> reading data files from the disc.
>> Hong
>> This is a good point you've raised as I don't think MUMPS
>> is able to
>> exploit that - I asked the question in their users list
>> just to be sure.
>> There are some options in SuperLU dist to reuse
>> permutation arrays, but
>> there's no I/O for that solver. And the native PETSc LU
>> solver is not
>> parallel?
>> I'm using high-order finite differences so I'm suffering
>> from a lot of
>> fill-in, one of the reasons why storing factorizations in
>> RAM is not
>> viable. In comparison, I have almost unlimited disk space.
>> I'm aware my need might seem counter-intuitive, but I'm
>> really willing
>> to sacrifice performance in the I/O part. My code is
>> already heavily
>> based on PETSc (preallocation, assembly for
>> matrices/vectors) coupled
>> with MUMPS I'm minimizing the loss of efficiency.
>> Thibaut
>> On 23/07/2019 17:13, Smith, Barry F. wrote:
>> > What types of computing systems will you be doing
>> the computations? Roughly how many MPI_ranks?
>> > Are the matrices all the same size? Do they have the
>> same or different nonzero structures? Would it be
>> possible to use the same symbolic representation for all
>> of them and just have different numerical values?
>> > Clusters and large scale computing centers are
>> notoriously terrible at IO; often IO is orders of
>> magnitude slower than compute/memory making this type of
>> workflow unrealistically slow. From a cost analysis point
>> of view often just buying lots of memory might be the
>> most efficacious approach.
>> > That said, what you suggest might require only a few
>> lines of code (though determining where to put them is
>> the tricky part) depending on the MUMPS interface for
>> saving a filer to disk. What we would do is keep the
>> PETSc wrapper that lives around the MUMPS matrix
>> Mat_MUMPS but using the MUMPS API save the information in
>> the DMUMPS_STRUC_C id; and then reload it when needed.
>> > The user level API could be something like
>> > MatMumpsSaveToDisk(Mat) and
>> MatMumpsLoadFromDisk(Mat) they would just money with
>> DMUMPS_STRUC_C id; item.
>> > Barry
>> >> On Jul 23, 2019, at 9:24 AM, Thibaut Appel via
>> petsc-users <petsc-users at mcs.anl.gov
>> >> Dear PETSc users,
>> >> I need to solve several linear systems successively,
>> with LU factorization, as part of an iterative process in
>> my Fortran application code.
>> >> The process would solve M systems (A_m)(x_m,i) =
>> (b_m,i) for m=1,M at each iteration i, but computing the
>> LU factorization of A_m only once.
>> >> The RHSs (b_m,i+1) are computed from all the different
>> (x_m,i) and all depend upon each other.
>> >> The way I envisage to perform that is to use MUMPS to
>> compute, successively, each of the LU factorizations (m)
>> in parallel and store the factors on disk,
>> creating/assembling/destroying the matrices A_m on the go.
>> >> Then whenever needed, read the factors in parallel to
>> solve the systems. Since version 5.2, MUMPS has a
>> save/restore feature that allows that, see
>> http://mumps.enseeiht.fr/doc/userguide_5.2.1.pdf p.20, 24
>> and 58.
>> >> In its current state, the PETSc/MUMPS interface does
>> not incorporate that feature. I'm an advanced Fortran
>> programmer but not in C so I don't think I would do an
>> amazing job having a go inside
>> src/mat/impls/aij/mpi/mumps/mumps.c.
>> >> I was picturing something like creating as many KSP
>> objects as linear systems to be solved, with some sort of
>> flag to force the storage of LU factors on disk after the
>> first call to KSPSolve. Then keep calling KSPSolve as
>> many times as needed.
>> >> Would you support such a feature?
>> >> Thanks for your support,
>> >> Thibaut
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190729/25768f99/attachment.html>
