[petsc-users] confused by the converged reason output
Fri Jul 19 13:47:04 CDT 2019
On Fri, Jul 19, 2019 at 11:21 AM Michael Wick <michael.wick.1980 at gmail.com>
wrote:
> Yes, it returns:
> Linear m_fieldsplit_0_ solve converged due to CONVERGED_RTOL iterations 3
0 KSP preconditioned resid norm 5.402205955230e-11 true resid norm
9.999870838355e-01 ||r(i)||/||b|| 1.000000000000e+00
1 KSP preconditioned resid norm 2.240069771831e-12 true resid norm
2.329743436488e-01 ||r(i)||/||b|| 2.329773528226e-01
2 KSP preconditioned resid norm 3.394412665922e-13 true resid norm
7.296473323081e-02 ||r(i)||/||b|| 7.296567566748e-02
3 KSP preconditioned resid norm 4.936386334724e-14 true resid norm
1.313944571812e-02 ||r(i)||/||b|| 1.313961543155e-02
KSP Object:(m_fieldsplit_0_) 24 MPI processes
  type: gmres
    GMRES: restart=100, using Classical (unmodified) Gram-Schmidt
Orthogonalization with no iterative refinement
    GMRES: happy breakdown tolerance 1e-30
  maximum iterations=100, initial guess is zero
  tolerances:  relative=0.001, absolute=1e-50, divergence=10000
  left preconditioning
  using PRECONDITIONED norm type for convergence test
Note that the relative tolerance is 0.001, so the termination seems correct.
    Matt
> On Fri, Jul 19, 2019 at 9:20 AM Matthew Knepley <knepley at gmail.com> wrote:
>> On Fri, Jul 19, 2019 at 11:14 AM Michael Wick via petsc-users <
>> petsc-users at mcs.anl.gov> wrote:
>>> Hi PETSc team:
>>> I am a bit confused by the output of converged reason. I set the
>>> relative tolerance to be 10^{-3}. In my run, I get the monitor true
>>> residual to be as follows.
>> Can you run with -ksp_converged_reason?
>>   Thanks,
>>      Matt
>>> And the converged reason is solve converged due to CONVERGED_RTOL
>>> iterations 3. The relative error is quite far from the prescribed
>>> tolerance. Is there something I should know about the stopping criteria?
>>> The ks_view output is
>>>   type: gmres
>>> PC Object:(m_fieldsplit_0_) 24 MPI processes
>>>   type: hypre
>>>     HYPRE BoomerAMG preconditioning
>>>     HYPRE BoomerAMG: Cycle type V
>>>     HYPRE BoomerAMG: Maximum number of levels 25
>>>     HYPRE BoomerAMG: Maximum number of iterations PER hypre call 1
>>>     HYPRE BoomerAMG: Convergence tolerance PER hypre call 0
>>>     HYPRE BoomerAMG: Threshold for strong coupling 0.25
>>>     HYPRE BoomerAMG: Interpolation truncation factor 0
>>>     HYPRE BoomerAMG: Interpolation: max elements per row 0
>>>     HYPRE BoomerAMG: Number of levels of aggressive coarsening 0
>>>     HYPRE BoomerAMG: Number of paths for aggressive coarsening 1
>>>     HYPRE BoomerAMG: Maximum row sums 0.9
>>>     HYPRE BoomerAMG: Sweeps down         1
>>>     HYPRE BoomerAMG: Sweeps up           1
>>>     HYPRE BoomerAMG: Sweeps on coarse    1
>>>     HYPRE BoomerAMG: Relax down          symmetric-SOR/Jacobi
>>>     HYPRE BoomerAMG: Relax up            symmetric-SOR/Jacobi
>>>     HYPRE BoomerAMG: Relax on coarse     Gaussian-elimination
>>>     HYPRE BoomerAMG: Relax weight  (all)      1
>>>     HYPRE BoomerAMG: Outer relax weight (all) 1
>>>     HYPRE BoomerAMG: Using CF-relaxation
>>>     HYPRE BoomerAMG: Measure type        local
>>>     HYPRE BoomerAMG: Coarsen type        HMIS
>>>     HYPRE BoomerAMG: Interpolation type  ext+i
>>>   linear system matrix = precond matrix:
>>>   Mat Object:  (m_fieldsplit_0_)   24 MPI processes
>>>     type: mpiaij
>>>     rows=115812, cols=115812
>>>     total: nonzeros=1.34986e+06, allocated nonzeros=1.34986e+06
>>>     total number of mallocs used during MatSetValues calls =0
>>>       not using I-node (on process 0) routines
>>> Thanks,
>>> Mike
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190719/c57af48a/attachment.html>
