[petsc-users] MemCpy (HtoD and DtoH) in Krylov solver
Xiangdong epscodes at gmail.com
Thu Jul 18 08:11:00 CDT 2019
On Thu, Jul 18, 2019 at 5:11 AM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>    1) What preconditioner are you using? If any.
Currently I am using none as I want to understand how gmres works on GPU.
>    2) Where/how are you getting this information about the MemCpy(HtoD)
> and one call MemCpy(DtoH)? We might like to utilize this same sort of
> information to plan future optimizations.
I am using nvprof and nvvp from cuda toolkit. It looks like there are one
MemCpy(HtoD) and three MemCpy(DtoH) calls per iteration for np=1 case. See
the attached snapshots.
>    3) Are you using more than 1 MPI rank?
I tried both np=1 and np=2. Attached please find snapshots from nvvp for
both np=1 and np=2 cases. The figures showing gpu calls with two pure gmres
iterations.
Thanks.
Xiangdong
>   If you use the master branch (which we highly recommend for anyone using
> GPUs and PETSc) the -log_view option will log communication between CPU and
> GPU and display it in the summary table. This is useful for seeing exactly
> what operations are doing vector communication between the CPU/GPU.
>   We welcome all feedback on the GPUs since it previously has only been
> lightly used.
>    Barry
> > On Jul 16, 2019, at 9:05 PM, Xiangdong via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> > Hello everyone,
> > I am new to petsc gpu and have a simple question.
> > When I tried to solve Ax=b where A is MATAIJCUSPARSE and b and x are
> VECSEQCUDA  with GMRES(or GCR) and pcnone, I found that during each krylov
> iteration, there are one call MemCpy(HtoD) and one call MemCpy(DtoH). Does
> that mean the Krylov solve is not 100% on GPU and the solve still needs
> some work from CPU? What are these MemCpys for during the each iteration?
> > Thank you.
> > Best,
> > Xiangdong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190718/db899cbd/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190718/db899cbd/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190718/db899cbd/attachment-0003.png>
