[petsc-users] MemCpy (HtoD and DtoH) in Krylov solver
Xiangdong
epscodes at gmail.com
Wed Jul 17 15:33:48 CDT 2019
Thanks for your explanation.
Is it correct to say that ONLY the VecNorm, VecDot, VecMDot, MatMult
operations in GMRES are done on GPU and everything else is done on CPU?
Thanks.
Xiangdong
On Wed, Jul 17, 2019 at 7:34 AM Mark Adams <mfadams at lbl.gov> wrote:
> Also, MPI communication is done from the host, so every mat-vec will do a
> "CopySome" call from the device, do MPI comms, and then the next time you
> do GPU work it will copy from the host to get the update.
> On Tue, Jul 16, 2019 at 10:22 PM Matthew Knepley via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
>> On Tue, Jul 16, 2019 at 9:07 PM Xiangdong via petsc-users <
>>> Hello everyone,
>>> I am new to petsc gpu and have a simple question.
>>> When I tried to solve Ax=b where A is MATAIJCUSPARSE and b and x are
>>> VECSEQCUDA with GMRES(or GCR) and pcnone, I found that during each krylov
>>> iteration, there are one call MemCpy(HtoD) and one call MemCpy(DtoH). Does
>>> that mean the Krylov solve is not 100% on GPU and the solve still needs
>>> some work from CPU? What are these MemCpys for during the each iteration?
>> We have GPU experts on the list, but there is definitely a communication
>> because we do not do orthogonalization on the GPU,
>> just the BLAS ops. This is a very small amount of data, so it just
>> contributed latency, and I would guess that it is less then kernel
>> launch latency.
>> Thanks,
>> Matt
>>> Thank you.
>>> Best,
>>> Xiangdong
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190717/fb199bba/attachment.html>
