[petsc-users] Various Questions Regarding PETSC
Mohammed Mostafa mo7ammedmostafa at gmail.com
Sat Jul 13 12:31:41 CDT 2019
Apply the scaling test to my code is such a hassle since I need to generate
a family of meshes of different sizes so for now I applied it the ksp
example code
with m = 100,200,400,600,900,1350
I clipped the stage summary section for different m,
Summary of Stages:   ----- Time ------  ----- Flop ------  --- Messages ---
 -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total    Count   %Total
m=100
 1:    CreateMatrix: 4.5347e-04   2.5%  0.0000e+00   0.0%  0.000e+00   0.0%
 0.000e+00        0.0%  0.000e+00   0.0%
 2:  AssembleMatrix: 1.2514e-03   6.8%  0.0000e+00   0.0%  3.500e+01   3.7%
 1.499e+03        7.8%  8.000e+00   5.2%
m=200
 1:    CreateMatrix: 2.1127e-03   3.2%  0.0000e+00   0.0%  0.000e+00   0.0%
 2:  AssembleMatrix: 2.3036e-03   3.4%  0.0000e+00   0.0%  3.500e+01   2.4%
 2.985e+03        4.8%  8.000e+00   3.1%
m=400
 1:    CreateMatrix: 8.8379e-03   0.9%  0.0000e+00   0.0%  0.000e+00   0.0%
 2:  AssembleMatrix: 5.1055e-03   0.5%  0.0000e+00   0.0%  3.500e+01   1.1%
 5.956e+03        2.1%  8.000e+00   1.3%
m=600
 1:    CreateMatrix: 1.2745e-02   0.3%  0.0000e+00   0.0%  0.000e+00   0.0%
 2:  AssembleMatrix: 1.4184e-02   0.3%  0.0000e+00   0.0%  3.500e+01   0.6%
 8.923e+03        1.2%  8.000e+00   0.8%
m=900
 1:    CreateMatrix: 4.1014e-02   0.2%  0.0000e+00   0.0%  0.000e+00   0.0%
 2:  AssembleMatrix: 2.6641e-02   0.2%  0.0000e+00   0.0%  3.500e+01   0.4%
 1.338e+04        0.8%  8.000e+00   0.5%
m=1350
 1:    CreateMatrix: 9.3838e-02   0.2%  0.0000e+00   0.0%  0.000e+00   0.0%
 2:  AssembleMatrix: 5.2478e-02   0.1%  0.0000e+00   0.0%  3.500e+01   0.4%
 2.007e+04        0.7%  8.000e+00   0.5%
when summarized it becomes as follows
m timings_CreateMatrix timings_AssembleMatrix m_ratio timing_ratio_setValue
timing_ratio_assemble
100 4.53E-04 1.25E-03 1 1 1
200 2.11E-03 2.30E-03 2 4.65896310671048 1.84081828352245
400 8.84E-03 5.11E-03 2 4.18322525678042 2.21631359611044
600 1.27E-02 1.42E-02 1.5 1.44208465812014 2.77818039369308
900 4.10E-02 2.66E-02 1.5 3.21804629266379 1.87824309080654
1350 9.38E-02 5.25E-02 1.5 2.28795045594187 1.96982095266694
On Sun, Jul 14, 2019 at 1:52 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Sat, Jul 13, 2019 at 11:20 AM Mohammed Mostafa <
> mo7ammedmostafa at gmail.com> wrote:
>> I am sorry but I don’t see what you mean by small times
>> Although mat assembly is relatively smaller
>> The cost of mat set values is still significant
>> The same can be said for vec assembly
>> Combined vec/mat assembly  and matsetvalues constitute about 50% of the
>> total cost of matrix construction
> This is why I asked you about scaling, since it is difficult to
> disentangle overheads from scalable work at 10^-2 seconds.
> Second, if you look at the times for the PETSc example you ran, setvalues
> and assembly is clearly not 50% of the
> time for construction. I cannot see your code, so we do not know exactly
> what the custom events are timing. I
> would think about incrementally changing the example until you get what
> you want.
>   Thanks,
>      Matt
>> So is this problem of my matrix setup/ preallocation
>> Or is this a hardware  issue, for whatever reason the copy is overly slow
>> The code was run on a single node
>> Or is this function call overhead since matsetvalues is being called 1M
>> times inside the for loop ( 170k times in each process)
>> Thanks, Kamra
>> On Sun, Jul 14, 2019 at 12:41 AM Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Sat, Jul 13, 2019 at 9:56 AM Mohammed Mostafa <
>>>> Hello Matt,
>>>> I revised my code and changed the way I create the rhs vector,
>>>> previosly I was using vecCreateGhost just in case I need the ghost
>>>> values, but for now I changed that to
>>>> vecCreateMPI(.......)
>>>> So maybe that was the cause of the scatter
>>>> I am attaching with this email a new log output
>>> Okay, the times are now very small. How does it scale up?
>>>   Thanks,
>>>      Matt
>>>> Also regarding how I fill my petsc matrix,
>>>> In my code I fill a temp CSR format matrix becasue otherwise I would
>>>> need "MatSetValue" to fill the petsc mat element by element
>>>> which is not recommmeded in the petsc manual and probably very
>>>> expensive due to function call overhead
>>>> *So after I create my matrix in CSR format, I fill the PETSC mat A as
>>>> follows*
>>>>> for (i = 0; i < nMatRows; i++) {
>>>>>  cffset = CSR_iptr[i];
>>>>> row_index = row_gIndex[i];
>>>>> nj = Eqn_nj[i];
>>>>> MatSetValues(PhiEqnSolver.A, 1, &row_index, nj, CSR_jptr + offset,
>>>>> CSR_vptr +  offset, INSERT_VALUES);
>>>> *After That*
>>>>> VecAssemblyBegin(RHS);
>>>>> VecAssemblyEnd(RHS);
>>>>> MatAssemblyBegin(A, MAT_FINAL_ASSEMBLY);
>>>>> MatAssemblyEnd(A, MAT_FINAL_ASSEMBLY);
>>>> *I don't believe , I am doing anything special, if possible I would
>>>> like to set the whole csr matrix at once in one command.*
>>>> *I took a look at the code for MatSetValues, if I am understanding it
>>>> correctly(hopefully) I think I could do it, maybe modify it or create a new
>>>> routine entirely for this pupose.*
>>>> *i.e. MatSetValuesFromCSR(.....)*
>>>> *Or is there a particular reason why it has to be this way*
>>>> I also tried ksp ex3 but I slightly tweaked it to add a logging stage
>>>> around the assembly and MatSetValues and I am attaching the modified
>>>> example here as well.
>>>> Although in this example the matrix stash is not empty ( means
>>>> off-processor values are being set ) but the timing values for roughly the
>>>> same matrix size , the command I used is
>>>> mpirun -np 6 ./mod_ksp_ex3 -m 1000 -log_view -info
>>>> Regards,
>>>> Kamra
>>>> On Sat, Jul 13, 2019 at 1:43 PM Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Fri, Jul 12, 2019 at 10:51 PM Mohammed Mostafa <
>>>>>> Hello Matt,
>>>>>> Attached is the dumped entire log output using -log_view and -info.
>>>>> In matrix construction, it looks like you have a mixture of load
>>>>> imbalance (see the imbalance in the Begin events)
>>>>> and lots of Scatter messages in your assembly. We turn off
>>>>> MatSetValues() logging by default since it is usually
>>>>> called many times, but you can explicitly turn it back on if you want.
>>>>> I don't think that is the problem here. Its easy
>>>>> to see from examples (say SNES ex5) that it is not the major time
>>>>> sink. What is the Scatter doing?
>>>>>   Thanks,
>>>>>      Matt
>>>>>> Thanks,
>>>>>> Kamra
>>>>>> On Fri, Jul 12, 2019 at 9:23 PM Matthew Knepley <knepley at gmail.com>
>>>>>> wrote:
>>>>>>> On Fri, Jul 12, 2019 at 5:19 AM Mohammed Mostafa via petsc-users <
>>>>>>> petsc-users at mcs.anl.gov> wrote:
>>>>>>>> Hello all,
>>>>>>>> I have a few question regarding Petsc,
>>>>>>> Please send the entire output of a run with all the logging turned
>>>>>>> on, using -log_view and -info.
>>>>>>>   Thanks,
>>>>>>>     Matt
>>>>>>>> Question 1:
>>>>>>>> For the profiling , is it possible to only show the user defined
>>>>>>>> log events in the breakdown of each stage in Log-view.
>>>>>>>> I tried deactivating all ClassIDs, MAT,VEC, PC, KSP,PC,
>>>>>>>>  PetscLogEventExcludeClass(MAT_CLASSID);
>>>>>>>> PetscLogEventExcludeClass(VEC_CLASSID);
>>>>>>>> PetscLogEventExcludeClass(KSP_CLASSID);
>>>>>>>> PetscLogEventExcludeClass(PC_CLASSID);
>>>>>>>> which should "Deactivates event logging for a PETSc object class in
>>>>>>>> every stage" according to the manual.
>>>>>>>> however I still see them in the stage breakdown
>>>>>>>> --- Event Stage 1: Matrix Construction
>>>>>>>> BuildTwoSidedF         4 1.0 2.7364e-02 2.4 0.00e+00 0.0 0.0e+00
>>>>>>>> 0.0e+00 0.0e+00  0  0  0  0  0  18  0  0  0  0     0
>>>>>>>> VecSet                 1 1.0 4.5300e-06 2.4 0.00e+00 0.0 0.0e+00
>>>>>>>> 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>>>>>>>> VecAssemblyBegin       2 1.0 2.7344e-02 2.4 0.00e+00 0.0 0.0e+00
>>>>>>>> VecAssemblyEnd         2 1.0 8.3447e-06 1.5 0.00e+00 0.0 0.0e+00
>>>>>>>> VecScatterBegin        2 1.0 7.5102e-05 1.7 0.00e+00 0.0 3.6e+01
>>>>>>>> 2.1e+03 0.0e+00  0  0  3  0  0   0  0 50 80  0     0
>>>>>>>> VecScatterEnd          2 1.0 3.5286e-05 2.2 0.00e+00 0.0 0.0e+00
>>>>>>>> MatAssemblyBegin       2 1.0 8.8930e-05 1.9 0.00e+00 0.0 0.0e+00
>>>>>>>> MatAssemblyEnd         2 1.0 1.3566e-02 1.1 0.00e+00 0.0 3.6e+01
>>>>>>>> 5.3e+02 8.0e+00  0  0  3  0  6  10  0 50 20100     0
>>>>>>>> AssembleMats           2 1.0 3.9774e-02 1.7 0.00e+00 0.0 7.2e+01
>>>>>>>> 1.3e+03 8.0e+00  0  0  7  0  6  28  0100100100     0  # USER EVENT
>>>>>>>> myMatSetValues         2 1.0 2.6931e-02 1.2 0.00e+00 0.0 0.0e+00
>>>>>>>> 0.0e+00 0.0e+00  0  0  0  0  0  19  0  0  0  0     0   # USER EVENT
>>>>>>>> setNativeMat           1 1.0 3.5613e-02 1.3 0.00e+00 0.0 0.0e+00
>>>>>>>> 0.0e+00 0.0e+00  0  0  0  0  0  24  0  0  0  0     0   # USER EVENT
>>>>>>>> setNativeMatII         1 1.0 4.7023e-02 1.5 0.00e+00 0.0 0.0e+00
>>>>>>>> 0.0e+00 0.0e+00  0  0  0  0  0  28  0  0  0  0     0   # USER EVENT
>>>>>>>> callScheme             1 1.0 2.2333e-03 1.2 0.00e+00 0.0 0.0e+00
>>>>>>>> 0.0e+00 0.0e+00  0  0  0  0  0   2  0  0  0  0     0   # USER EVENT
>>>>>>>> Also is possible to clear the logs so that I can write a  separate
>>>>>>>> profiling output file for each timestep ( since I am solving a transient
>>>>>>>> problem and I want to know the change in performance as time goes by )
>>>>>>>> Question 2:
>>>>>>>> Regarding MatSetValues
>>>>>>>> Right now, I writing a finite volume code, due to algorithm
>>>>>>>> requirement I have to write the matrix into local native format ( array of
>>>>>>>> arrays) and then loop through rows and use MatSetValues to set the elements
>>>>>>>> in "Mat A"
>>>>>>>> MatSetValues(A, 1, &row, nj, j_index, coefvalues, INSERT_VALUES);
>>>>>>>> but it is very slow and it is killing my performance
>>>>>>>> although the matrix was properly set using
>>>>>>>> MatCreateAIJ(PETSC_COMM_WORLD, this->local_size, this->local_size,
>>>>>>>> PETSC_DETERMINE,
>>>>>>>> PETSC_DETERMINE, -1, d_nnz, -1, o_nnz, &A);
>>>>>>>> with d_nnz,and  o_nnz properly assigned so no mallocs occur during
>>>>>>>> matsetvalues and all inserted values are local so no off-processor values
>>>>>>>> So my question is it possible to set multiple rows at once
>>>>>>>> hopefully all, I checked the manual and MatSetValues can only set dense
>>>>>>>> matrix block because it seems that row by row is expensive
>>>>>>>> Or perhaps is it possible to copy all rows to the underlying matrix
>>>>>>>> data, as I mentioned all values are local and no off-processor values (
>>>>>>>> stash is 0 )
>>>>>>>> [0] VecAssemblyBegin_MPI_BTS(): Stash has 0 entries, uses 0 mallocs.
>>>>>>>> [0] VecAssemblyBegin_MPI_BTS(): Block-Stash has 0 entries, uses 0
>>>>>>>> mallocs.
>>>>>>>> [0] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
>>>>>>>> [1] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
>>>>>>>> [2] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
>>>>>>>> [3] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
>>>>>>>> [4] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
>>>>>>>> [5] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
>>>>>>>> [2] MatAssemblyEnd_SeqAIJ(): Matrix size: 186064 X 186064; storage
>>>>>>>> space: 0 unneeded,743028 used
>>>>>>>> [1] MatAssemblyEnd_SeqAIJ(): Matrix size: 186062 X 186062; storage
>>>>>>>> space: 0 unneeded,742972 used
>>>>>>>> [1] MatAssemblyEnd_SeqAIJ(): Number of mallocs during
>>>>>>>> MatSetValues() is 0
>>>>>>>> [1] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 4
>>>>>>>> [1] MatCheckCompressedRow(): Found the ratio (num_zerorows
>>>>>>>> 0)/(num_localrows 186062) < 0.6. Do not use CompressedRow routines.
>>>>>>>> [2] MatAssemblyEnd_SeqAIJ(): Number of mallocs during
>>>>>>>> MatSetValues() is 0
>>>>>>>> [2] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 4
>>>>>>>> [2] MatCheckCompressedRow(): Found the ratio (num_zerorows
>>>>>>>> 0)/(num_localrows 186064) < 0.6. Do not use CompressedRow routines.
>>>>>>>> [4] MatAssemblyEnd_SeqAIJ(): Matrix size: 186063 X 186063; storage
>>>>>>>> space: 0 unneeded,743093 used
>>>>>>>> [0] MatAssemblyEnd_SeqAIJ(): Matrix size: 186062 X 186062; storage
>>>>>>>> space: 0 unneeded,743036 used
>>>>>>>> [4] MatAssemblyEnd_SeqAIJ(): Number of mallocs during
>>>>>>>> MatSetValues() is 0
>>>>>>>> [4] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 4
>>>>>>>> [4] MatCheckCompressedRow(): Found the ratio (num_zerorows
>>>>>>>> 0)/(num_localrows 186063) < 0.6. Do not use CompressedRow routines.
>>>>>>>> [0] MatAssemblyEnd_SeqAIJ(): Number of mallocs during
>>>>>>>> MatSetValues() is 0
>>>>>>>> [5] MatAssemblyEnd_SeqAIJ(): Matrix size: 186062 X 186062; storage
>>>>>>>> space: 0 unneeded,742938 used
>>>>>>>> [5] MatAssemblyEnd_SeqAIJ(): Number of mallocs during
>>>>>>>> MatSetValues() is 0
>>>>>>>> [5] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 4
>>>>>>>> [5] MatCheckCompressedRow(): Found the ratio (num_zerorows
>>>>>>>> [0] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 4
>>>>>>>> [0] MatCheckCompressedRow(): Found the ratio (num_zerorows
>>>>>>>> [3] MatAssemblyEnd_SeqAIJ(): Matrix size: 186063 X 186063; storage
>>>>>>>> space: 0 unneeded,743049 used
>>>>>>>> [3] MatAssemblyEnd_SeqAIJ(): Number of mallocs during
>>>>>>>> MatSetValues() is 0
>>>>>>>> [3] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 4
>>>>>>>> [3] MatCheckCompressedRow(): Found the ratio (num_zerorows
>>>>>>>> [2] MatAssemblyEnd_SeqAIJ(): Matrix size: 186064 X 685; storage
>>>>>>>> space: 0 unneeded,685 used
>>>>>>>> [4] MatAssemblyEnd_SeqAIJ(): Matrix size: 186063 X 649; storage
>>>>>>>> space: 0 unneeded,649 used
>>>>>>>> MatSetValues() is 0
>>>>>>>> [4] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 1
>>>>>>>> 185414)/(num_localrows 186063) > 0.6. Use CompressedRow routines.
>>>>>>>> MatSetValues() is 0
>>>>>>>> [2] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 1
>>>>>>>> 185379)/(num_localrows 186064) > 0.6. Use CompressedRow routines.
>>>>>>>> [1] MatAssemblyEnd_SeqAIJ(): Matrix size: 186062 X 1011; storage
>>>>>>>> space: 0 unneeded,1011 used
>>>>>>>> [5] MatAssemblyEnd_SeqAIJ(): Matrix size: 186062 X 1137; storage
>>>>>>>> space: 0 unneeded,1137 used
>>>>>>>> MatSetValues() is 0
>>>>>>>> [5] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 1
>>>>>>>> 184925)/(num_localrows 186062) > 0.6. Use CompressedRow routines.
>>>>>>>> MatSetValues() is 0
>>>>>>>> [1] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 1
>>>>>>>> [3] MatAssemblyEnd_SeqAIJ(): Matrix size: 186063 X 658; storage
>>>>>>>> space: 0 unneeded,658 used
>>>>>>>> [0] MatAssemblyEnd_SeqAIJ(): Matrix size: 186062 X 648; storage
>>>>>>>> space: 0 unneeded,648 used
>>>>>>>> 185051)/(num_localrows 186062) > 0.6. Use CompressedRow routines.
>>>>>>>> MatSetValues() is 0
>>>>>>>> [0] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 1
>>>>>>>> 185414)/(num_localrows 186062) > 0.6. Use CompressedRow routines.
>>>>>>>> MatSetValues() is 0
>>>>>>>> [3] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 1
>>>>>>>> 185405)/(num_localrows 186063) > 0.6. Use CompressedRow routines.
>>>>>>>> Question 3:
>>>>>>>> If all matrix and vector inserted data are local, what part of the
>>>>>>>> vec/mat assembly consumes time because matsetvalues and matassembly consume
>>>>>>>> more time than matrix builder
>>>>>>>> Also this is not just for the first time MAT_FINAL_ASSEMBLY
>>>>>>>> For context the matrix in the above is nearly 1Mx1M partitioned
>>>>>>>> over six processes and it was NOT built using DM
>>>>>>>> Finally the configure options are:
>>>>>>>> Configure options:
>>>>>>>> PETSC_ARCH=release3 -with-debugging=0 COPTFLAGS="-O3 -march=native
>>>>>>>> -mtune=native" CXXOPTFLAGS="-O3 -march=native -mtune=native" FOPTFLAGS="-O3
>>>>>>>> -march=native -mtune=native" --with-cc=mpicc --with-cxx=mpicxx
>>>>>>>> --with-fc=mpif90 --download-metis --download-hypre
>>>>>>>> Sorry for such long question and thanks in advance
>>>>>>>> Thanks
>>>>>>>> M. Kamra
>>>>>>> What most experimenters take for granted before they begin their
>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190714/4b80160e/attachment-0001.html>
