[petsc-users] Various Questions Regarding PETSC
Mohammed Mostafa mo7ammedmostafa at gmail.com
Fri Jul 12 22:51:46 CDT 2019
Hello Matt,
Attached is the dumped entire log output using -log_view and -info.
Kamra
On Fri, Jul 12, 2019 at 9:23 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Jul 12, 2019 at 5:19 AM Mohammed Mostafa via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
>> Hello all,
>> I have a few question regarding Petsc,
> Please send the entire output of a run with all the logging turned on,
>   Thanks,
>     Matt
>> Question 1:
>> For the profiling , is it possible to only show the user defined log
>> events in the breakdown of each stage in Log-view.
>> I tried deactivating all ClassIDs, MAT,VEC, PC, KSP,PC,
>>  PetscLogEventExcludeClass(MAT_CLASSID);
>> PetscLogEventExcludeClass(VEC_CLASSID);
>> PetscLogEventExcludeClass(KSP_CLASSID);
>> PetscLogEventExcludeClass(PC_CLASSID);
>> which should "Deactivates event logging for a PETSc object class in every
>> stage" according to the manual.
>> however I still see them in the stage breakdown
>> --- Event Stage 1: Matrix Construction
>> BuildTwoSidedF         4 1.0 2.7364e-02 2.4 0.00e+00 0.0 0.0e+00 0.0e+00
>> 0.0e+00  0  0  0  0  0  18  0  0  0  0     0
>> VecSet                 1 1.0 4.5300e-06 2.4 0.00e+00 0.0 0.0e+00 0.0e+00
>> 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>> VecAssemblyBegin       2 1.0 2.7344e-02 2.4 0.00e+00 0.0 0.0e+00 0.0e+00
>> VecAssemblyEnd         2 1.0 8.3447e-06 1.5 0.00e+00 0.0 0.0e+00 0.0e+00
>> VecScatterBegin        2 1.0 7.5102e-05 1.7 0.00e+00 0.0 3.6e+01 2.1e+03
>> 0.0e+00  0  0  3  0  0   0  0 50 80  0     0
>> VecScatterEnd          2 1.0 3.5286e-05 2.2 0.00e+00 0.0 0.0e+00 0.0e+00
>> MatAssemblyBegin       2 1.0 8.8930e-05 1.9 0.00e+00 0.0 0.0e+00 0.0e+00
>> MatAssemblyEnd         2 1.0 1.3566e-02 1.1 0.00e+00 0.0 3.6e+01 5.3e+02
>> 8.0e+00  0  0  3  0  6  10  0 50 20100     0
>> AssembleMats           2 1.0 3.9774e-02 1.7 0.00e+00 0.0 7.2e+01 1.3e+03
>> 8.0e+00  0  0  7  0  6  28  0100100100     0  # USER EVENT
>> myMatSetValues         2 1.0 2.6931e-02 1.2 0.00e+00 0.0 0.0e+00 0.0e+00
>> 0.0e+00  0  0  0  0  0  19  0  0  0  0     0   # USER EVENT
>> setNativeMat           1 1.0 3.5613e-02 1.3 0.00e+00 0.0 0.0e+00 0.0e+00
>> 0.0e+00  0  0  0  0  0  24  0  0  0  0     0   # USER EVENT
>> setNativeMatII         1 1.0 4.7023e-02 1.5 0.00e+00 0.0 0.0e+00 0.0e+00
>> 0.0e+00  0  0  0  0  0  28  0  0  0  0     0   # USER EVENT
>> callScheme             1 1.0 2.2333e-03 1.2 0.00e+00 0.0 0.0e+00 0.0e+00
>> 0.0e+00  0  0  0  0  0   2  0  0  0  0     0   # USER EVENT
>> Also is possible to clear the logs so that I can write a  separate
>> profiling output file for each timestep ( since I am solving a transient
>> problem and I want to know the change in performance as time goes by )
>> Question 2:
>> Regarding MatSetValues
>> Right now, I writing a finite volume code, due to algorithm requirement I
>> have to write the matrix into local native format ( array of arrays) and
>> then loop through rows and use MatSetValues to set the elements in "Mat A"
>> MatSetValues(A, 1, &row, nj, j_index, coefvalues, INSERT_VALUES);
>> but it is very slow and it is killing my performance
>> although the matrix was properly set using
>> MatCreateAIJ(PETSC_COMM_WORLD, this->local_size, this->local_size,
>> PETSC_DETERMINE,
>> PETSC_DETERMINE, -1, d_nnz, -1, o_nnz, &A);
>> with d_nnz,and  o_nnz properly assigned so no mallocs occur during
>> matsetvalues and all inserted values are local so no off-processor values
>> So my question is it possible to set multiple rows at once hopefully all,
>> I checked the manual and MatSetValues can only set dense matrix block
>> because it seems that row by row is expensive
>> Or perhaps is it possible to copy all rows to the underlying matrix data,
>> as I mentioned all values are local and no off-processor values ( stash is
>> 0 )
>> [0] VecAssemblyBegin_MPI_BTS(): Stash has 0 entries, uses 0 mallocs.
>> [0] VecAssemblyBegin_MPI_BTS(): Block-Stash has 0 entries, uses 0 mallocs.
>> [0] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
>> [1] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
>> [2] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
>> [3] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
>> [4] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
>> [5] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
>> [2] MatAssemblyEnd_SeqAIJ(): Matrix size: 186064 X 186064; storage space:
>> 0 unneeded,743028 used
>> [1] MatAssemblyEnd_SeqAIJ(): Matrix size: 186062 X 186062; storage space:
>> 0 unneeded,742972 used
>> [1] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 0
>> [1] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 4
>> [1] MatCheckCompressedRow(): Found the ratio (num_zerorows
>> 0)/(num_localrows 186062) < 0.6. Do not use CompressedRow routines.
>> [2] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 0
>> [2] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 4
>> [2] MatCheckCompressedRow(): Found the ratio (num_zerorows
>> 0)/(num_localrows 186064) < 0.6. Do not use CompressedRow routines.
>> [4] MatAssemblyEnd_SeqAIJ(): Matrix size: 186063 X 186063; storage space:
>> 0 unneeded,743093 used
>> [0] MatAssemblyEnd_SeqAIJ(): Matrix size: 186062 X 186062; storage space:
>> 0 unneeded,743036 used
>> [4] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 0
>> [4] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 4
>> [4] MatCheckCompressedRow(): Found the ratio (num_zerorows
>> 0)/(num_localrows 186063) < 0.6. Do not use CompressedRow routines.
>> [0] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 0
>> [5] MatAssemblyEnd_SeqAIJ(): Matrix size: 186062 X 186062; storage space:
>> 0 unneeded,742938 used
>> [5] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 0
>> [5] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 4
>> [5] MatCheckCompressedRow(): Found the ratio (num_zerorows
>> [0] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 4
>> [0] MatCheckCompressedRow(): Found the ratio (num_zerorows
>> [3] MatAssemblyEnd_SeqAIJ(): Matrix size: 186063 X 186063; storage space:
>> 0 unneeded,743049 used
>> [3] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 0
>> [3] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 4
>> [3] MatCheckCompressedRow(): Found the ratio (num_zerorows
>> [2] MatAssemblyEnd_SeqAIJ(): Matrix size: 186064 X 685; storage space: 0
>> unneeded,685 used
>> [4] MatAssemblyEnd_SeqAIJ(): Matrix size: 186063 X 649; storage space: 0
>> unneeded,649 used
>> [4] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 1
>> 185414)/(num_localrows 186063) > 0.6. Use CompressedRow routines.
>> [2] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 1
>> 185379)/(num_localrows 186064) > 0.6. Use CompressedRow routines.
>> [1] MatAssemblyEnd_SeqAIJ(): Matrix size: 186062 X 1011; storage space: 0
>> unneeded,1011 used
>> [5] MatAssemblyEnd_SeqAIJ(): Matrix size: 186062 X 1137; storage space: 0
>> unneeded,1137 used
>> [5] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 1
>> 184925)/(num_localrows 186062) > 0.6. Use CompressedRow routines.
>> [1] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 1
>> [3] MatAssemblyEnd_SeqAIJ(): Matrix size: 186063 X 658; storage space: 0
>> unneeded,658 used
>> [0] MatAssemblyEnd_SeqAIJ(): Matrix size: 186062 X 648; storage space: 0
>> unneeded,648 used
>> 185051)/(num_localrows 186062) > 0.6. Use CompressedRow routines.
>> [0] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 1
>> 185414)/(num_localrows 186062) > 0.6. Use CompressedRow routines.
>> [3] MatAssemblyEnd_SeqAIJ(): Maximum nonzeros in any row is 1
>> 185405)/(num_localrows 186063) > 0.6. Use CompressedRow routines.
>> Question 3:
>> If all matrix and vector inserted data are local, what part of the
>> vec/mat assembly consumes time because matsetvalues and matassembly consume
>> more time than matrix builder
>> Also this is not just for the first time MAT_FINAL_ASSEMBLY
>> For context the matrix in the above is nearly 1Mx1M partitioned over six
>> processes and it was NOT built using DM
>> Finally the configure options are:
>> Configure options:
>> PETSC_ARCH=release3 -with-debugging=0 COPTFLAGS="-O3 -march=native
>> -mtune=native" CXXOPTFLAGS="-O3 -march=native -mtune=native" FOPTFLAGS="-O3
>> -march=native -mtune=native" --with-cc=mpicc --with-cxx=mpicxx
>> --with-fc=mpif90 --download-metis --download-hypre
>> Sorry for such long question and thanks in advance
>> Thanks
>> M. Kamra
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190713/eb690508/attachment-0001.html>
[0] PetscInitialize(): PETSc successfully started: number of processors = 6
[0] PetscGetHostName(): Rejecting domainname, likely is NIS mohamedkamra-DAIV-DQZ520.(none)
[0] PetscInitialize(): Running on machine: mohamedkamra-DAIV-DQZ520
[1] PetscInitialize(): PETSc successfully started: number of processors = 6
[1] PetscGetHostName(): Rejecting domainname, likely is NIS mohamedkamra-DAIV-DQZ520.(none)
[1] PetscInitialize(): Running on machine: mohamedkamra-DAIV-DQZ520
[2] PetscInitialize(): PETSc successfully started: number of processors = 6
[2] PetscGetHostName(): Rejecting domainname, likely is NIS mohamedkamra-DAIV-DQZ520.(none)
[2] PetscInitialize(): Running on machine: mohamedkamra-DAIV-DQZ520
[3] PetscInitialize(): PETSc successfully started: number of processors = 6
[3] PetscGetHostName(): Rejecting domainname, likely is NIS mohamedkamra-DAIV-DQZ520.(none)
[3] PetscInitialize(): Running on machine: mohamedkamra-DAIV-DQZ520
[4] PetscInitialize(): PETSc successfully started: number of processors = 6
[4] PetscGetHostName(): Rejecting domainname, likely is NIS mohamedkamra-DAIV-DQZ520.(none)
[4] PetscInitialize(): Running on machine: mohamedkamra-DAIV-DQZ520
[5] PetscInitialize(): PETSc successfully started: number of processors = 6
[5] PetscGetHostName(): Rejecting domainname, likely is NIS mohamedkamra-DAIV-DQZ520.(none)
[5] PetscInitialize(): Running on machine: mohamedkamra-DAIV-DQZ520
Processor: 0/6
[0] PetscCommDuplicate(): Duplicating a communicator 1140850688 -2080374780 max tags = 268435455
[1] PetscCommDuplicate(): Duplicating a communicator 1140850688 -2080374782 max tags = 268435455
[2] PetscCommDuplicate(): Duplicating a communicator 1140850688 -2080374782 max tags = 268435455
[3] PetscCommDuplicate(): Duplicating a communicator 1140850688 -2080374782 max tags = 268435455
[4] PetscCommDuplicate(): Duplicating a communicator 1140850688 -2080374782 max tags = 268435455
[5] PetscCommDuplicate(): Duplicating a communicator 1140850688 -2080374782 max tags = 268435455
[3] PetscCommDuplicate(): Duplicating a communicator 1140850689 -2080374780 max tags = 268435455
[2] PetscCommDuplicate(): Duplicating a communicator 1140850689 -2080374780 max tags = 268435455
[4] PetscCommDuplicate(): Duplicating a communicator 1140850689 -2080374780 max tags = 268435455
[0] PetscCommDuplicate(): Duplicating a communicator 1140850689 -2080374777 max tags = 268435455
[2] PetscCommDuplicate(): Using internal PETSc communicator 1140850688 -2080374782
[4] PetscCommDuplicate(): Using internal PETSc communicator 1140850688 -2080374782
[1] PetscCommDuplicate(): Duplicating a communicator 1140850689 -2080374780 max tags = 268435455
[3] PetscCommDuplicate(): Using internal PETSc communicator 1140850688 -2080374782
[5] PetscCommDuplicate(): Duplicating a communicator 1140850689 -2080374780 max tags = 268435455
[1] PetscCommDuplicate(): Using internal PETSc communicator 1140850688 -2080374782
[5] PetscCommDuplicate(): Using internal PETSc communicator 1140850688 -2080374782
[0] PetscCommDuplicate(): Using internal PETSc communicator 1140850688 -2080374780
[0] PetscCommDuplicate(): Using internal PETSc communicator 1140850689 -2080374777
[1] PetscCommDuplicate(): Using internal PETSc communicator 1140850689 -2080374780
[2] PetscCommDuplicate(): Using internal PETSc communicator 1140850689 -2080374780
[3] PetscCommDuplicate(): Using internal PETSc communicator 1140850689 -2080374780
[4] PetscCommDuplicate(): Using internal PETSc communicator 1140850689 -2080374780
[5] PetscCommDuplicate(): Using internal PETSc communicator 1140850689 -2080374780
[0] VecScatterCreate_MPI1(): Using MPI1 for vector scatter
[0] VecScatterCreateCommon_PtoS_MPI1(): Using blocksize 3 scatter
[0] VecScatterCreate_PtoS(): Special case: blocked indices to stride
[0] VecScatterCreateCommon_PtoS_MPI1(): Using blocksize 1 scatter
[0] VecScatterCreate_PtoS(): General case: MPI to Seq
 <<< Linear Solver Setup Successfully >>>
Set Matrix Start
[2] MatAssemblyEnd_SeqAIJ(): Matrix size: 186064 X 186064; storage space: 0 unneeded,743028 used
[3] MatAssemblyEnd_SeqAIJ(): Matrix size: 186063 X 186063; storage space: 0 unneeded,743049 used
[3] MatCheckCompressedRow(): Found the ratio (num_zerorows 0)/(num_localrows 186063) < 0.6. Do not use CompressedRow routines.
[0] MatAssemblyEnd_SeqAIJ(): Matrix size: 186062 X 186062; storage space: 0 unneeded,743036 used
[5] MatAssemblyEnd_SeqAIJ(): Matrix size: 186062 X 186062; storage space: 0 unneeded,742938 used
[0] MatCheckCompressedRow(): Found the ratio (num_zerorows 0)/(num_localrows 186062) < 0.6. Do not use CompressedRow routines.
[2] MatCheckCompressedRow(): Found the ratio (num_zerorows 0)/(num_localrows 186064) < 0.6. Do not use CompressedRow routines.
[5] MatCheckCompressedRow(): Found the ratio (num_zerorows 0)/(num_localrows 186062) < 0.6. Do not use CompressedRow routines.
[1] MatAssemblyEnd_SeqAIJ(): Matrix size: 186062 X 186062; storage space: 0 unneeded,742972 used
[4] MatAssemblyEnd_SeqAIJ(): Matrix size: 186063 X 186063; storage space: 0 unneeded,743093 used
[4] MatCheckCompressedRow(): Found the ratio (num_zerorows 0)/(num_localrows 186063) < 0.6. Do not use CompressedRow routines.
[1] MatCheckCompressedRow(): Found the ratio (num_zerorows 0)/(num_localrows 186062) < 0.6. Do not use CompressedRow routines.
[3] MatSeqAIJCheckInode(): Found 186063 nodes out of 186063 rows. Not using Inode routines
[2] MatSeqAIJCheckInode(): Found 186064 nodes out of 186064 rows. Not using Inode routines
[5] MatSeqAIJCheckInode(): Found 186062 nodes out of 186062 rows. Not using Inode routines
[0] MatSeqAIJCheckInode(): Found 186062 nodes out of 186062 rows. Not using Inode routines
[1] MatSeqAIJCheckInode(): Found 186062 nodes out of 186062 rows. Not using Inode routines
[4] MatSeqAIJCheckInode(): Found 186063 nodes out of 186063 rows. Not using Inode routines
[5] MatAssemblyEnd_SeqAIJ(): Matrix size: 186062 X 1137; storage space: 0 unneeded,1137 used
[5] MatCheckCompressedRow(): Found the ratio (num_zerorows 184925)/(num_localrows 186062) > 0.6. Use CompressedRow routines.
[2] MatAssemblyEnd_SeqAIJ(): Matrix size: 186064 X 685; storage space: 0 unneeded,685 used
[3] MatAssemblyEnd_SeqAIJ(): Matrix size: 186063 X 658; storage space: 0 unneeded,658 used
[2] MatCheckCompressedRow(): Found the ratio (num_zerorows 185379)/(num_localrows 186064) > 0.6. Use CompressedRow routines.
[3] MatCheckCompressedRow(): Found the ratio (num_zerorows 185405)/(num_localrows 186063) > 0.6. Use CompressedRow routines.
[0] MatAssemblyEnd_SeqAIJ(): Matrix size: 186062 X 648; storage space: 0 unneeded,648 used
[0] MatCheckCompressedRow(): Found the ratio (num_zerorows 185414)/(num_localrows 186062) > 0.6. Use CompressedRow routines.
[4] MatAssemblyEnd_SeqAIJ(): Matrix size: 186063 X 649; storage space: 0 unneeded,649 used
[1] MatAssemblyEnd_SeqAIJ(): Matrix size: 186062 X 1011; storage space: 0 unneeded,1011 used
[1] MatCheckCompressedRow(): Found the ratio (num_zerorows 185051)/(num_localrows 186062) > 0.6. Use CompressedRow routines.
[4] MatCheckCompressedRow(): Found the ratio (num_zerorows 185414)/(num_localrows 186063) > 0.6. Use CompressedRow routines.
 Time to Setup (II): 5.26303
 Time to Setup (III): 4.77501, count = 1
[0] MatCreateSubMatrices_MPIAIJ_Local(): Number of outgoing messages 0 Total message length 0
[5] MatCreateSubMatrices_MPIAIJ_Local(): Number of outgoing messages 0 Total message length 0
[1] MatCreateSubMatrices_MPIAIJ_Local(): Number of outgoing messages 0 Total message length 0
[2] MatCreateSubMatrices_MPIAIJ_Local(): Number of outgoing messages 0 Total message length 0
[3] MatCreateSubMatrices_MPIAIJ_Local(): Number of outgoing messages 0 Total message length 0
[4] MatCreateSubMatrices_MPIAIJ_Local(): Number of outgoing messages 0 Total message length 0
[3] MatAssemblyEnd_SeqAIJ(): Matrix size: 186063 X 930313; storage space: 0 unneeded,658 used
[4] MatAssemblyEnd_SeqAIJ(): Matrix size: 186063 X 930313; storage space: 0 unneeded,649 used
[0] MatAssemblyEnd_SeqAIJ(): Matrix size: 186062 X 930314; storage space: 0 unneeded,648 used
[2] MatAssemblyEnd_SeqAIJ(): Matrix size: 186064 X 930312; storage space: 0 unneeded,685 used
[5] MatAssemblyEnd_SeqAIJ(): Matrix size: 186062 X 930314; storage space: 0 unneeded,1137 used
[1] MatAssemblyEnd_SeqAIJ(): Matrix size: 186062 X 930314; storage space: 0 unneeded,1011 used
[3] MatSeqAIJCheckInode(): Found 37997 nodes of 186063. Limit used: 5. Using Inode routines
[4] MatSeqAIJCheckInode(): Found 37991 nodes of 186063. Limit used: 5. Using Inode routines
[2] MatSeqAIJCheckInode(): Found 38030 nodes of 186064. Limit used: 5. Using Inode routines
[0] MatSeqAIJCheckInode(): Found 37993 nodes of 186062. Limit used: 5. Using Inode routines
[1] MatSeqAIJCheckInode(): Found 38413 nodes of 186062. Limit used: 5. Using Inode routines
[5] MatSeqAIJCheckInode(): Found 38565 nodes of 186062. Limit used: 5. Using Inode routines
[2] MatCreateSubMatrices_MPIAIJ_Local(): Number of outgoing messages 5 Total message length 930327
[3] MatCreateSubMatrices_MPIAIJ_Local(): Number of outgoing messages 5 Total message length 930328
[0] MatCreateSubMatrices_MPIAIJ_Local(): Number of outgoing messages 5 Total message length 930329
[1] MatCreateSubMatrices_MPIAIJ_Local(): Number of outgoing messages 5 Total message length 930329
[5] MatCreateSubMatrices_MPIAIJ_Local(): Number of outgoing messages 5 Total message length 930329
[4] MatCreateSubMatrices_MPIAIJ_Local(): Number of outgoing messages 5 Total message length 930328
[2] MatAssemblyEnd_SeqAIJ(): Matrix size: 930312 X 186064; storage space: 0 unneeded,685 used
[2] MatCheckCompressedRow(): Found the ratio (num_zerorows 929627)/(num_localrows 930312) > 0.6. Use CompressedRow routines.
[2] MatSeqAIJCheckInode(): Found 186870 nodes of 930312. Limit used: 5. Using Inode routines
[5] MatAssemblyEnd_SeqAIJ(): Matrix size: 930314 X 186062; storage space: 0 unneeded,1137 used
[5] MatCheckCompressedRow(): Found the ratio (num_zerorows 929177)/(num_localrows 930314) > 0.6. Use CompressedRow routines.
[5] MatSeqAIJCheckInode(): Found 187410 nodes of 930314. Limit used: 5. Using Inode routines
[1] MatAssemblyEnd_SeqAIJ(): Matrix size: 930314 X 186062; storage space: 0 unneeded,1011 used
[1] MatCheckCompressedRow(): Found the ratio (num_zerorows 929303)/(num_localrows 930314) > 0.6. Use CompressedRow routines.
[1] MatSeqAIJCheckInode(): Found 187283 nodes of 930314. Limit used: 5. Using Inode routines
[3] MatAssemblyEnd_SeqAIJ(): Matrix size: 930313 X 186063; storage space: 0 unneeded,658 used
[3] MatCheckCompressedRow(): Found the ratio (num_zerorows 929655)/(num_localrows 930313) > 0.6. Use CompressedRow routines.
[3] MatSeqAIJCheckInode(): Found 186842 nodes of 930313. Limit used: 5. Using Inode routines
[0] MatAssemblyEnd_SeqAIJ(): Matrix size: 930314 X 186062; storage space: 0 unneeded,648 used
[0] MatCheckCompressedRow(): Found the ratio (num_zerorows 929666)/(num_localrows 930314) > 0.6. Use CompressedRow routines.
[0] MatSeqAIJCheckInode(): Found 186837 nodes of 930314. Limit used: 5. Using Inode routines
 isMatSymm = true
Set Matrix Done
 Setting Preconditioner 	DONE
 Setting Iterative Solver 	DONE
[4] MatAssemblyEnd_SeqAIJ(): Matrix size: 930313 X 186063; storage space: 0 unneeded,649 used
[4] MatCheckCompressedRow(): Found the ratio (num_zerorows 929664)/(num_localrows 930313) > 0.6. Use CompressedRow routines.
[4] MatSeqAIJCheckInode(): Found 186825 nodes of 930313. Limit used: 5. Using Inode routines
[0] PCSetUp(): Setting up PC for first time
[0] MatConvert(): Check superclass seqhypre mpiaij -> 0
[0] MatConvert(): Check superclass mpihypre mpiaij -> 0
[0] MatConvert(): Check specialized (1) MatConvert_mpiaij_seqhypre_C (mpiaij) -> 0
[0] MatConvert(): Check specialized (1) MatConvert_mpiaij_mpihypre_C (mpiaij) -> 0
[0] MatConvert(): Check specialized (1) MatConvert_mpiaij_hypre_C (mpiaij) -> 1
[0] KSPConvergedDefault(): user has provided nonzero initial guess, computing 2-norm of RHS
[0] PCSetUp(): Leaving PC with identical preconditioner since operator is unchanged
[0] KSPConvergedDefault(): Linear solver has converged. Residual norm 6.843645053482e-13 is less than absolute tolerance 1.000000000000e-12 at iteration 17
 Solution Converged in 17 to error 6.84365e-13 where tol = 1.00000e-05
 Init Res = 1. , Converged @@ 17 iterations and the reason is  ATOL and resNorm = 6.8436e-13[0] VecAssemblyBegin_MPI_BTS(): Stash has 0 entries, uses 0 mallocs.
 Updating Auxilary Field
Face Data (-1.00243, 1.00399, 112999.)
 LeastSquare Gradient is Happy
 Variable : Generic Variable (none)
                Variable is computed at the cell Center
       isCellData Up2Date  : yes
       isFaceData Up2Date  : yes
       isGradient Up2Date  : yes
	Writing File <OutputData/VTK/PoissonBench000000.pvtu>
[4] PetscFinalize(): PetscFinalize() called
[5] PetscFinalize(): PetscFinalize() called
[1] PetscFinalize(): PetscFinalize() called
[2] PetscFinalize(): PetscFinalize() called
[3] PetscFinalize(): PetscFinalize() called
[0] PetscFinalize(): PetscFinalize() called
***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r -fCourier9' to print this document            ***
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
./OpenAqua300 on a release3 named mohamedkamra-DAIV-DQZ520 with 6 processors, by mohamedkamra Sat Jul 13 12:32:48 2019
Using Petsc Release Version 3.11.2, May, 18, 2019
                         Max       Max/Min     Avg       Total
Time (sec):           2.257e+01     1.000   2.257e+01
Objects:              7.000e+01     1.000   7.000e+01
Flop:                 6.260e+07     1.000   6.260e+07  3.756e+08
Flop/sec:             2.774e+06     1.000   2.773e+06  1.664e+07
MPI Messages:         1.255e+03     2.427   7.630e+02  4.578e+03
MPI Message Lengths:  5.430e+07     1.018   7.029e+04  3.218e+08
MPI Reductions:       1.410e+02     1.000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N --> 2N flop
                            and VecAXPY() for complex vectors of length N --> 8N flop
Summary of Stages:   ----- Time ------  ----- Flop ------  --- Messages ---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total    Count   %Total     Avg         %Total    Count   %Total
 0:      Main Stage: 8.6126e+00  38.2%  0.0000e+00   0.0%  4.140e+02   9.0%  1.713e+03        0.2%  6.200e+01  44.0%
 1: Matrix Construction: 1.0037e+01  44.5%  0.0000e+00   0.0%  3.636e+03  79.4%  2.112e+03        2.4%  8.000e+00   5.7%
 2: System Solution: 3.6352e+00  16.1%  3.7166e+08  99.0%  4.920e+02  10.7%  6.365e+05       97.3%  6.400e+01  45.4%
 3:  Update AuxData: 2.8637e-01   1.3%  3.9110e+06   1.0%  3.600e+01   0.8%  6.384e+03        0.1%  0.000e+00   0.0%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flop: Max - maximum over all processors
                  Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   AvgLen: average message length (bytes)
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
      %T - percent time in this phase         %F - percent flop in this phase
      %M - percent messages in this phase     %L - percent message lengths in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flop over all processors)/(max time over all processors)
Event                Count      Time (sec)     Flop                              --- Global ---  --- Stage ----  Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   AvgLen  Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
BuildTwoSidedF         9 1.0 6.8691e-02255.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet                17 1.0 4.3519e-02 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAssemblyBegin      18 1.0 6.8860e-02198.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAssemblyEnd        18 1.0 3.3617e-05 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterBegin        9 1.0 3.2783e-04 2.1 0.00e+00 0.0 1.6e+02 3.5e+03 0.0e+00  0  0  4  0  0   0  0 39 81  0     0
VecScatterEnd          9 1.0 3.1114e-04 4.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
BuildTwoSidedF       400 1.0 6.5222e-01 2.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   5  0  0  0  0     0
VecSet                 1 1.0 2.8610e-06 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAssemblyBegin     200 1.0 6.2633e-01 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   5  0  0  0  0     0
VecAssemblyEnd       200 1.0 6.7163e-04 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterBegin      200 1.0 5.9373e-03 2.2 0.00e+00 0.0 3.6e+03 2.1e+03 0.0e+00  0  0 79  2  0   0  0 99100  0     0
VecScatterEnd        200 1.0 2.7236e-0223.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyBegin     200 1.0 3.2747e-02 5.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyEnd       200 1.0 9.0972e-01 1.0 0.00e+00 0.0 3.6e+01 5.3e+02 8.0e+00  4  0  1  0  6   9  0  1  0100     0
AssembleMats         200 1.0 1.5568e+00 1.2 0.00e+00 0.0 3.6e+03 2.1e+03 8.0e+00  6  0 79  2  6  14  0100100100     0
myMatSetValues       200 1.0 2.5367e+00 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 11  0  0  0  0  25  0  0  0  0     0
setNativeMat         100 1.0 2.8223e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 12  0  0  0  0  28  0  0  0  0     0
setNativeMatII       100 1.0 3.2174e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 14  0  0  0  0  31  0  0  0  0     0
callScheme           100 1.0 2.0700e-01 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   2  0  0  0  0     0
--- Event Stage 2: System Solution
BuildTwoSidedF         2 1.0 3.1161e-04 2.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecTDot               34 1.0 2.9358e-02 1.7 1.27e+07 1.0 0.0e+00 0.0e+00 3.4e+01  0 20  0  0 24   1 20  0  0 53  2586
VecNorm               19 1.0 8.2438e-03 1.1 7.07e+06 1.0 0.0e+00 0.0e+00 1.9e+01  0 11  0  0 13   0 11  0  0 30  5146
VecCopy                1 1.0 3.7718e-04 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet                17 1.0 6.2864e-03 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY               34 1.0 2.3406e-02 1.0 1.27e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0 20  0  0  0   1 20  0  0  0  3243
VecAYPX               17 1.0 1.0511e-02 1.1 6.14e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0 10  0  0  0   0 10  0  0  0  3505
VecAssemblyBegin       1 1.0 1.4949e-04 2.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAssemblyEnd         1 1.0 3.0994e-06 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterBegin       19 1.0 7.8726e-04 1.7 0.00e+00 0.0 3.4e+02 2.1e+03 0.0e+00  0  0  7  0  0   0  0 70  0  0     0
VecScatterEnd         19 1.0 2.5105e-0311.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatMult               18 1.0 7.5983e-02 1.0 2.34e+07 1.0 3.2e+02 2.1e+03 0.0e+00  0 37  7  0  0   2 38 66  0  0  1850
MatConvert             1 1.0 5.0359e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00  0  0  0  0  3   1  0  0  0  6     0
MatAssemblyBegin       3 1.0 1.7092e-0344.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyEnd         3 1.0 4.8217e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00  0  0  0  0  3   1  0  0  0  6     0
MatGetRowIJ            2 1.0 3.8147e-06 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatCreateSubMats       2 1.0 1.1497e+00 1.6 0.00e+00 0.0 1.5e+02 2.1e+06 4.0e+00  4  0  3 97  3  25  0 30100  6     0
KSPSetUp               1 1.0 4.1850e-01211.4 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00  1  0  0  0  1   6  0  0  0  3     0
KSPSolve               1 1.0 1.3674e+00 1.0 6.20e+07 1.0 3.2e+02 2.1e+03 5.3e+01  6 99  7  0 38  38100 66  0 83   272
PCSetUp                1 1.0 1.0755e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00  5  0  0  0  3  30  0  0  0  6     0
PCApply               17 1.0 1.2312e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  5  0  0  0  0  34  0  0  0  0     0
--- Event Stage 3: Update AuxData
BuildTwoSidedF         2 1.0 2.6415e-0228.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   6  0  0  0  0     0
VecMax                 1 1.0 1.0192e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecMin                 1 1.0 1.0574e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNorm                1 1.0 9.1124e-04 1.0 6.52e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0100  0  0  0  4292
VecAssemblyBegin       3 1.0 2.6719e-0228.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   6  0  0  0  0     0
VecAssemblyEnd         3 1.0 8.8215e-06 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterBegin        2 1.0 1.1158e-04 2.6 0.00e+00 0.0 3.6e+01 6.4e+03 0.0e+00  0  0  1  0  0   0  0100100  0     0
VecScatterEnd          2 1.0 2.3389e-0414.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
Memory usage is given in bytes:
Object Type          Creations   Destructions     Memory  Descendants' Mem.
Reports information only for process 0.
              Vector    20              0            0     0.
           Index Set    14             14        29232     0.
   IS L to G Mapping     7              0            0     0.
         Vec Scatter     7              0            0     0.
              Matrix     3              0            0     0.
       Krylov Solver     1              0            0     0.
              Viewer     1              0            0     0.
              Vector     2              1         1664     0.
           Index Set     2              2         4176     0.
         Vec Scatter     1              0            0     0.
              Vector     6              3      1493488     0.
           Index Set     2              2      3722840     0.
              Matrix     3              2     22349512     0.
      Preconditioner     1              0            0     0.
Average time to get PetscTime(): 8.10623e-07
Average time for MPI_Barrier(): 2.09808e-06
Average time for zero size MPI_Send(): 8.34465e-07
#PETSc Option Table entries:
-info
-ksp_monitor
-log_view
-pc_hypre_boomeramg_max_iter 1
-pc_hypre_boomeramg_relax_type_all SOR/Jacobi
-pc_hypre_boomeramg_rtol 0
-pc_hypre_boomeramg_strong_threshold 0.4
[1] Petsc_DelViewer(): Removing viewer data attribute in an MPI_Comm -2080374782
[2] Petsc_DelViewer(): Removing viewer data attribute in an MPI_Comm -2080374782
[3] Petsc_DelViewer(): Removing viewer data attribute in an MPI_Comm -2080374782
[4] Petsc_DelViewer(): Removing viewer data attribute in an MPI_Comm -2080374782
[5] Petsc_DelViewer(): Removing viewer data attribute in an MPI_Comm -2080374782
-pc_pfmg_num_post_relax 1
-pc_pfmg_num_pre_relax 2
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure options: PETSC_ARCH=release3 -with-debugging=0 COPTFLAGS="-O3 -march=native -mtune=native" CXXOPTFLAGS="-O3 -march=native -mtune=native" FOPTFLAGS="-O3 -march=native -mtune=native" --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90 --download-metis --download-hypre
Libraries compiled on 2019-07-03 09:57:26 on mohamedkamra-DAIV-DQZ520
Machine characteristics: Linux-4.18.0-25-generic-x86_64-with-Ubuntu-18.04-bionic
Using PETSc directory: /home/mohamedkamra/Downloads/petsc-3.11.2
Using PETSc arch: release3
Using C compiler: mpicc  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -O3 -march=native -mtune=native
Using Fortran compiler: mpif90  -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -O3 -march=native -mtune=native
Using include paths: -I/home/mohamedkamra/Downloads/petsc-3.11.2/include -I/home/mohamedkamra/Downloads/petsc-3.11.2/release3/include
Using C linker: mpicc
Using Fortran linker: mpif90
Using libraries: -Wl,-rpath,/home/mohamedkamra/Downloads/petsc-3.11.2/release3/lib -L/home/mohamedkamra/Downloads/petsc-3.11.2/release3/lib -lpetsc -Wl,-rpath,/home/mohamedkamra/Downloads/petsc-3.11.2/release3/lib -L/home/mohamedkamra/Downloads/petsc-3.11.2/release3/lib -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/7 -L/usr/lib/gcc/x86_64-linux-gnu/7 -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu -lHYPRE -llapack -lblas -lmetis -lm -lX11 -lpthread -lstdc++ -ldl -lmpichfort -lmpich -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath -lstdc++ -ldl
[0] Petsc_DelViewer(): Removing viewer data attribute in an MPI_Comm -2080374780
