[petsc-users] problem with CISS in SLEPC
Povolotskyi, Mykhailo
mpovolot at purdue.edu
Thu Jul 11 12:36:07 CDT 2019
Hello,
I want to use CISS for my eigenvalue problem. To test it I tried a
simple (2x2) matrix case, but the code failed with the following message:
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Error in external library
[0]PETSC ERROR: Error in LAPACK subroutine gesvd: info=127
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.8.4, Mar, 24, 2018
[0]PETSC ERROR: var1 on a linux-complex named brown-a027.rcac.purdue.edu
by mpovolot Thu Jul 11 13:28:21 2019
[0]PETSC ERROR: Configure options --with-scalar-type=complex --with-x=0
--with-hdf5 --download-hdf5=1 --with-single-library=1 --with-pic=1
--with-shared-libraries=0 --with-log=0 --with-clanguage=C++
--CXXFLAGS="-fopenmp -fPIC" --CFLAGS="-fopenmp -fPIC" --with-fortran=0
--FFLAGS="-fopenmp -fPIC" --with-debugging=0 --with-cc=mpicc
--with-fc=mpif90 --with-cxx=mpicxx COPTFLAGS= CXXOPTFLAGS= FOPTFLAGS=
--download-metis=1 --download-parmetis=1
--with-valgrind-dir=/apps/brown/valgrind/3.13.0_gcc-4.8.5
--download-mumps=1 --with-fortran-kernels=0 --download-superlu_dist=1
--with-blaslapack-lib="-L/apps/cent7/intel/compilers_and_libraries_2017.1.132/linux/mkl/lib/intel64
-lmkl_intel_lp64 -lmkl_gnu_thread -lmkl_core "
--with-blacs-lib=/apps/cent7/intel/compilers_and_libraries_2017.1.132/linux/mkl/lib/intel64/libmkl_blacs_intelmpi_lp64.so
--with-blacs-include=/apps/cent7/intel/compilers_and_libraries_2017.1.132/linux/mkl/include
--with-scalapack-lib="-Wl,-rpath,/apps/cent7/intel/compilers_and_libraries_2017.1.132/linux/mkl/lib/intel64
-lmkl_gf_lp64 -lmkl_gnu_thread -lmkl_core -lpthread
-lmkl_scalapack_lp64 -lmkl_blacs_intelmpi_lp64"
--with-scalapack-include=/apps/cent7/intel/compilers_and_libraries_2017.1.132/linux/mkl/include
[0]PETSC ERROR: #1 SVD_S() line 611 in
/depot/kildisha/apps/brown/nemo5/libs/slepc/build-cplx/src/eps/impls/ciss/ciss.c
[0]PETSC ERROR: #2 EPSSolve_CISS() line 1028 in
[0]PETSC ERROR: #3 EPSSolve() line 147 in
/depot/kildisha/apps/brown/nemo5/libs/slepc/build-cplx/src/eps/interface/epssolve.c
Here is the code:
void test1()
Mat matrix_petsc;
MatCreateDense(MPI_COMM_SELF,2,2,PETSC_DECIDE,PETSC_DECIDE,NULL,&matrix_petsc);
MatSetValue(matrix_petsc,0,0,complex<double>(1,0),INSERT_VALUES);
MatSetValue(matrix_petsc,1,1,complex<double>(2,0),INSERT_VALUES);
MatSetValue(matrix_petsc,0,1,complex<double>(0,0),INSERT_VALUES);
MatSetValue(matrix_petsc,1,0,complex<double>(0,0),INSERT_VALUES);
MatAssemblyBegin(matrix_petsc, MAT_FINAL_ASSEMBLY);
MatAssemblyEnd(matrix_petsc, MAT_FINAL_ASSEMBLY);
EPS eps;
EPSType type;
RG rg;
EPSCreate(MPI_COMM_SELF,&eps);
EPSSetOperators( eps,matrix_petsc,NULL);
EPSSetType(eps,EPSCISS);
EPSSetProblemType(eps, EPS_NHEP);
double real_min = -10;
double real_max = 10;
double imag_min = -10;
double imag_max = 10;
EPSGetRG(eps,&rg);
RGSetType(rg,RGINTERVAL);
RGIntervalSetEndpoints(rg,real_min,real_max,imag_min,imag_max);
EPSSolve(eps);
EPSDestroy(&eps);
MatDestroy(&matrix_petsc);
Do you see anything wrong in the way I'm calling SLEPC functions?
Thank you,
Michael.
