[petsc-users] Implementing TS routine
Manuel Valera mvalera-w at sdsu.edu
Tue Jul 9 14:37:25 CDT 2019
On Tue, Jul 9, 2019 at 11:27 AM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> > On Jul 8, 2019, at 6:53 PM, Manuel Valera via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> > Hi Zhang,
> > Thanks to your help i have implemented the TS routine for my temperature
> DMDA array, and it works correctly including in MPI.
> > The breakthrough for me was realizing that TS steps and max time steps
> are all set up once, and used/advanced all at once when invoked with
> TSSolution. So what i did was to add all of the TSCreate / initialization
> into the main loop so i am basically creating and destroying the TS objects
> every time step.
>    Why? You can create the TS objects once outside and then inside advance
> them one step at a time inside the loop if you want.
For some reason this is not possible, if you could provide any ideas let me
know, the situation is this:
This block is now inside the main loop:
                call TSCreate(PETSC_COMM_WORLD,ts,ierr)
                call TSSetProblemType(ts,TS_NONLINEAR,ierr)
                call TSSetSolution(ts,LocTemperature,ierr)
                call
TSSetRHSFunction(ts,PETSC_NULL_VEC,FormRHSFunction,PETSC_NULL_VEC,ierr)
                call TSSetType(ts,TSSSP,ierr)
                call TSSetTimeStep(ts,dt,ierr)
                call TSSetDM(ts,daScalars,ierr)
                call TSSetMaxTime(ts,dt,ierr)
                call
TSSetExactFinalTime(ts,TS_EXACTFINALTIME_MATCHSTEP,ierr)
                call TSSetFromOptions(ts,ierr)
                call TSSetUp(ts,ierr)
                call TSSolve(ts,LocTemperature,ierr)
                call TSDestroy(ts,ierr)
Where i create, set everything up and solve the TS problem for a single
time step. If i take TSCreate and TSDestroy out of this loop, the TS will
advance all the dt's at time zero of the program (first iteration) and then
continue executing the rest without taking this into account. The only way
i have found for TS to be executed every time in the way i need it is
creating all objects and executing them at this moment. Any idea on how i
can control this from out of the loop would be appreciated.
Keep in mind that i want to use only the TS routine in this step, as i
mentioned every example seems to include the dynamics of the problem inside
the TS, and then it makes sense that we could set a specific totaltime and
advance it all at TSSolution, what i am trying to do is quite different, as
all of the dynamics are to be preserved outside of the TS, i only really
need to make use of the function that takes u and f(t,u) and gives out
u(t+1) with a specific time stepping scheme.
> > I hope the overhead time is not to bad when i scale to bigger problems.
>    I would say it is only extremely strange conditions would you need to
> recreate the TS for each timestep. Better to now figure out how to reuse
> them.
Agreed and i would like to know how to reuse them but the behavior seems to
be against what i want to do.
> > Next step would be to apply the same to advance the velocities, but
> problem now is that they are in a 4D dmda array of 3 degrees of freedom,
> any suggestions on how to implement this? does TS support multiple degrees
> of freedom arrays?
>    TS doesn't care how you access the vector entries in your function
> evaluations. All TS every sees is a Vec.
>    I am scared that you said 4D dmda array of 3 degrees of freedom. PETSc
> DMDA only goes up to 3 dimensions. So if you truely need 4 dim plus 3 dof
> per point you need to "fake it" but putting the last dimension into the dof
> slot. In other words use a 3d DMDA and have for dof  3*n where n is the
> size of the 4th dimension. The code to access the values will now be a
> little cumbersome since you can only access the array as 4d and the 4th
> dimension contains both the 3 and the last dimension but it is not too bad.
>    But if you mean 3 physical dimensions plus 3 dof then everything is
> fine just use the 3d DMDA.
Sorry i didn't speak clearly, i really meant 3 physical dimensions plus 3
DOF, i am already using the 3D DMDAs here. My velocity array looks like
vel(0:3,i,j,k) so 3 spatial dimensions and 3 degrees of freedom one for
each velocity direction, so vel(0,...) is u, vel(1,..) is v and vel(2,..)
is w. The problem comes again when i try to use the TS to solve for this
kind of array. Do i need a 1 dimensional vector for the f(t,u) ?
In the case of the temperature, i have created a natural vector from the 3D
RHS array, and use that as a f(t,u), do i need to do the same for the
velocities, or can i provide a 3D array with 3 DOF as either the f(t,u) and
the u? If the latter is the case, i could create a new 3D DMDA to hold the
RHS functions of each of the velocity, in the same structure the velocities
are. If the case if the former i would need to create new natural vectors
for each of the RHS, but also copy the velocities into a single DOF DMDA ?
Thanks, i think i am a bit at a loss here,
>    Barry
> > Thanks,
> > On Thu, Jul 4, 2019 at 9:18 PM Zhang, Hong <hongzhang at anl.gov> wrote:
> >> On Jul 3, 2019, at 3:10 PM, Manuel Valera <mvalera-w at sdsu.edu> wrote:
> >> Thanks Zhang for your answer,
> >> I ended up getting a compiling and running TS routine... that does not
> give me the answers, and i am not sure what i am doing wrong,
> >> My TS code so far looks like this:
> >> (...initialization...)
> >> call TSSetSolution(ts,gTemperature,ierr)
> >> call
> > The second last argument should be the user context. If you pass NULL,
> the ctx variable in your FormRHSFunction will be NULL.
> >> call TSSetMaxTime(ts,TotalTime,ierr)
> >> call TSSetExactFinalTime(ts,TS_EXACTFINALTIME_STEPOVER,ierr)
> >> (... then inside main calculations loop i have...)
> >> call TSSolve(ts,gTemperature,ierr)
> >> (...and my RHSFunction looks like this...)
> >> subroutine FormRHSFunction(ts,t,t_loc,rhs_loc,ctx,ierr)
> >>   use petscvec
> >>   use petscts
> >>   use petscdmda
> >>   use petscdm
> >>   USE utils
> >>   USE dmdaobjs
> >>   USE probsize
> >>   USE modelparams
> >>   implicit none
> >>   TS            :: ts
> >>   PetscReal     :: t
> >>   Vec           :: ctx,t_loc,rhs_loc
> >>   PetscErrorCode    :: ierr
> >>         call TSGetDM(ts,daScalars,ierr)
> >>         call DMGetLocalVector(daScalars,t_loc,ierr);
> > t_loc is the input, it should be not modified.
> >>         call
> DMGlobalToLocalBegin(daScalars,gTemperature,INSERT_VALUES,t_loc,ierr);CHKERRQ(ierr)
> >>         call
> DMGlobalToLocalEnd(daScalars,gTemperature,INSERT_VALUES,t_loc,ierr);CHKERRQ(ierr)
> > FormRHSFunction is supposed to implement rhs_loc = f(t,t_loc). So you
> want to scatter ghost points for t_loc, not gTemperature.
> >>         call DMDASolveTExplicit(3)
> >>         call DMGetLocalVector(daScalars,rhs_loc,ierr);
> >>         call
> DMGlobalToLocalBegin(daScalars,TRHSS_ts,INSERT_VALUES,rhs_loc,ierr);CHKERRQ(ierr)
> >>         call
> DMGlobalToLocalEnd(daScalars,TRHSS_ts,INSERT_VALUES,rhs_loc,ierr);CHKERRQ(ierr)
> > There is no need to scatter ghost points for rhs_loc.
> >>         call DMRestoreLocalVector(daScalars,t_loc,ierr);CHKERRQ(ierr)
> >>         call DMRestoreLocalVector(daScalars,rhs_loc,ierr);CHKERRQ(ierr)
> >> end subroutine FormRHSFunction
> >> Where DMDASolveTExplicit(3) is the old function to calculate time
> integration with runge kutta, modified to only generate the f(t,u) which in
> this case is rhs_loc,
> >> I still have several doubts:
> >>      • Will this explicit RHS calculation work with TS routines? my
> time integration is explicit so far and it would involve a fair deal of
> extra work to make it implicit.
> > For explicit time integration, one needs to provide only RHSFunction.
> >>      • This 't' parameter in the RHSFunction is controlled by PETSC? i
> am not providing anything for it directly, where is it coming from?
> > It is controlled by PETSc. If your problem is autonomous (the RHS does
> not depend on t), it can be simply ignored.
> >>      • Do i need to provide a Jacobian or the TS routine will try to
> guess one? This is related to the first point where my time scheme being
> explicit does not use a jacobian.
> > For explicit time integration, Jacobian is not needed.
> > Hong
> >> Thanks, any help is appreciated, if you see any errors or need more
> information please let me know,
> >> Regards,
> >> Manuel
> >> On Wed, Jun 26, 2019 at 9:54 PM Zhang, Hong <hongzhang at anl.gov> wrote:
> >>> On Jun 26, 2019, at 4:17 PM, Manuel Valera via petsc-users <
> >>> Hi PETSc,
> >>> I am trying to implement the Time stepping routines in my model, i
> have a working runge-kutta time scheme that goes to the following steps:
> >>>     • Interpolate u,v,w to the time advancing variable position.
> >>>     • Calculate nonlinear coefficients and advect velocities with a
> forward-backward shock capturing scheme.
> >>>     • Calculate the variable laplacian
> >>>     • Sum terms to create RHS (nonlinear advected velocities +
> laplacian)
> >>>     • Finally, the runge kutta integration is done in a typical way
> that looks like:
> >>>                    newtemp(t+1) = prevtemp(t) + dt*RHS
> >>> So my questions are:
> >>>     • I think my problem is nonlinear, but is being made linearized by
> the advecting scheme, is this correct? this is to know if i should use the
> linear or nonlinear routines for TS.
> >> TSComputeRHSFunctionLinear is just a convenience function for linear
> ODEs in the form udot=Au. Using it won’t buy you much. So for TS starters,
> it is fine to assume your problem is nonlinear and think of the form
> udot=f(t,u) where f is the RHS function.
> >>>     • How do i know what are the appropriate routines i should be
> using here? so far i think i should use the following:
> >>> call TSSetProblemType(ts,TS_LINEAR,ierr)
> >>> call TSSetRHSFunction(ts,NULL,TSComputeRHSFunctionLinear,NULL,ierr)
> >>> call TSSolve(ts,loctemperature,ierr)
> >>> Should i use call TSSetRHSJacobian for the temperature jacobian in
> this case?
> >> I would suggest to write your own RHSFunction and set it to TS with
> TSSetRHSFunction().
> >>> I am using
> https://www.mcs.anl.gov/petsc/petsc-current/src/ts/examples/tutorials/ex4.c.html
> as a  general guide, is there a more appropriate example?
> >> ex4 is a good example. In addition, ex9 uses finite volume method with
> slope limiters to solve a variety of problems such as advection equation,
> burgers equation and shallow water equation. It might be an overkill, but
> it seems to be close to the problem you are trying to solve. Note that you
> might want to use the SSP methods (-ts_type ssp) instead of the classic
> Runge-Kutta methods for problems with shocks.
> >> Hong (Mr.)
> >>> The dt value and total timesteps are controlled by the model,
> >>> Thanks for your help,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190709/db52ab1e/attachment-0001.html>
