[petsc-users] LU Performance
Jared Crean
jcrean01 at gmail.com
Thu Jul 4 16:05:32 CDT 2019
Hello,
I am getting very bad performance from the Umfpack LU solver when I
use it via Petsc compared to calling Umfpack directly. It takes about
5.5 seconds to factor and solve the matrix with Umfpack, but 140 seconds
when I use Petsc with -ksp_type preonly -pc_type lu
-pc_factor_mat_solver_type umfpack.
I have attached a minimal example (test.c) that reads a matrix from
a file, solves with Umfpack, and then solves with Petsc. The matrix
data files are not included because they are about 250 megabytes. I
also attached the output of the program with -log_view for
-pc_factor_mat_solver_type umfpack (fout_umfpacklu) and
-pc_factor_mat_solver_type petsc (fout_petsclu). Both results show
nearly all of the time is spent in MatLuFactorNum. The times are very
similar, so I am wondering if Petsc is really calling Umfpack or if the
Petsc LU solver is getting called in both cases.
Jared Crean
Type: application/gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190704/959d9003/attachment.bin>
