[petsc-users] Issue with DMPlexRestoreCone from Fortran
Thu Jul 4 08:36:36 CDT 2019
On Wed, Jul 3, 2019 at 1:03 PM Fabian.Jakub <
Fabian.Jakub at physik.uni-muenchen.de> wrote:
> Found the change...
> it was in Commit 6d563f2afc7bcefff9dc7869193a6debf1d639a5
> Date:   Wed Jun 26 12:32:01 2019 +0000
>     remove remnants of non-existing
> DMPlexRestore{Cone,ConeOrientation,Support}
You are right!
Vaclav, you cannot remove the Fortran RestoreCone() because it is actually
doing something.
Fortran needs to create arrays, and this code deallocates them. We do not
need that in C.
Can you put those back?
      Matt
> The patch removed the fortran stubs but not the C functions.
> In this case I guess that the fortran compiler reverts to the default
> calling convention and thus does not nullify the cone pointers but
> rather nulls the values in the cone.
> I suggest you remove the C functions to get a compiler error or revert
> the path.
> Many thanks,
> Fabian
> On 7/3/19 3:18 PM, Matthew Knepley wrote:
> > On Wed, Jul 3, 2019 at 7:38 AM Fabian.Jakub via petsc-users <
> > petsc-users at mcs.anl.gov> wrote:
> >> Dear Matt, Dear Petsc
> >> After my recent pull of petsc master I encounter test fails that use
> >> dmplex meshes.
> >> I attached a simple script to show an issue where DMPlexRestoreCone
> >> mangles the cone relationships in the DM.
> >> The behaviour happens with gcc 7.4.0 aswell as icc 19.0.3.199
> >> @ current petsc/master d3dc048301fdb3e4c282b528e7b28910551cfe13
> >> We recently had a system update and I am not 100% sure if this is some
> >> weird stuff going on at my end or if this is indeed Plex related or if I
> >> should not call Restore in the inner loop.
> >> Anyway, I would be most grateful if you could try to reproduce the error
> >> and hint me towards a solution.
> > Hi Fabian,
> > I think it might be your system update. Seems to run fine for me:
> > master *:~/Downloads/tmp$ ./plex_prism
> >  Cone           0 :           1           2           3           4
> >   5
> >  Cone           1 :           6           7           8
> >  Cone           2 :          12          13          14
> >  Cone           3 :           7           9          11          13
> >  Cone           4 :           6           9          10          12
> >  Cone           5 :           8          10          11          14
> >  Cone           6 :          15          16
> >  Cone           7 :          15          17
> >  Cone           8 :          16          17
> >  Cone           9 :          15          18
> >  Cone          10 :          16          19
> >  Cone          11 :          17          20
> >  Cone          12 :          18          19
> >  Cone          13 :          18          20
> >  Cone          14 :          19          20
> >  Cone          15 :
> >  Cone          16 :
> >  Cone          17 :
> >  Cone          18 :
> >  Cone          19 :
> >  Cone          20 :
> > master *:~/Downloads/tmp$ ./plex_prism -show_plex ::ascii_info_detail
> > DM Object: testplex 1 MPI processes
> >   type: plex
> > testplex in 3 dimensions:
> > Supports:
> > [0] Max support size: 3
> > [0]: 1 ----> 0
> > [0]: 2 ----> 0
> > [0]: 3 ----> 0
> > [0]: 4 ----> 0
> > [0]: 5 ----> 0
> > [0]: 6 ----> 1
> > [0]: 6 ----> 4
> > [0]: 7 ----> 1
> > [0]: 7 ----> 3
> > [0]: 8 ----> 1
> > [0]: 8 ----> 5
> > [0]: 9 ----> 3
> > [0]: 9 ----> 4
> > [0]: 10 ----> 4
> > [0]: 10 ----> 5
> > [0]: 11 ----> 3
> > [0]: 11 ----> 5
> > [0]: 12 ----> 2
> > [0]: 12 ----> 4
> > [0]: 13 ----> 2
> > [0]: 13 ----> 3
> > [0]: 14 ----> 2
> > [0]: 14 ----> 5
> > [0]: 15 ----> 6
> > [0]: 15 ----> 7
> > [0]: 15 ----> 9
> > [0]: 16 ----> 6
> > [0]: 16 ----> 8
> > [0]: 16 ----> 10
> > [0]: 17 ----> 7
> > [0]: 17 ----> 8
> > [0]: 17 ----> 11
> > [0]: 18 ----> 9
> > [0]: 18 ----> 12
> > [0]: 18 ----> 13
> > [0]: 19 ----> 10
> > [0]: 19 ----> 12
> > [0]: 19 ----> 14
> > [0]: 20 ----> 11
> > [0]: 20 ----> 13
> > [0]: 20 ----> 14
> > Cones:
> > [0] Max cone size: 5
> > [0]: 0 <---- 1 (0)
> > [0]: 0 <---- 2 (0)
> > [0]: 0 <---- 3 (0)
> > [0]: 0 <---- 4 (0)
> > [0]: 0 <---- 5 (0)
> > [0]: 1 <---- 6 (0)
> > [0]: 1 <---- 7 (0)
> > [0]: 1 <---- 8 (0)
> > [0]: 2 <---- 12 (0)
> > [0]: 2 <---- 13 (0)
> > [0]: 2 <---- 14 (0)
> > [0]: 3 <---- 7 (0)
> > [0]: 3 <---- 9 (0)
> > [0]: 3 <---- 11 (0)
> > [0]: 3 <---- 13 (0)
> > [0]: 4 <---- 6 (0)
> > [0]: 4 <---- 9 (0)
> > [0]: 4 <---- 10 (0)
> > [0]: 4 <---- 12 (0)
> > [0]: 5 <---- 8 (0)
> > [0]: 5 <---- 10 (0)
> > [0]: 5 <---- 11 (0)
> > [0]: 5 <---- 14 (0)
> > [0]: 6 <---- 15 (0)
> > [0]: 6 <---- 16 (0)
> > [0]: 7 <---- 15 (0)
> > [0]: 7 <---- 17 (0)
> > [0]: 8 <---- 16 (0)
> > [0]: 8 <---- 17 (0)
> > [0]: 9 <---- 15 (0)
> > [0]: 9 <---- 18 (0)
> > [0]: 10 <---- 16 (0)
> > [0]: 10 <---- 19 (0)
> > [0]: 11 <---- 17 (0)
> > [0]: 11 <---- 20 (0)
> > [0]: 12 <---- 18 (0)
> > [0]: 12 <---- 19 (0)
> > [0]: 13 <---- 18 (0)
> > [0]: 13 <---- 20 (0)
> > [0]: 14 <---- 19 (0)
> > [0]: 14 <---- 20 (0)
> > coordinates with 1 fields
> >   field 0 with 3 components
> > Process 0:
> >   (   0) dim  0 offset   0
> >   (   1) dim  0 offset   0
> >   (   2) dim  0 offset   0
> >   (   3) dim  0 offset   0
> >   (   4) dim  0 offset   0
> >   (   5) dim  0 offset   0
> >   (   6) dim  0 offset   0
> >   (   7) dim  0 offset   0
> >   (   8) dim  0 offset   0
> >   (   9) dim  0 offset   0
> >   (  10) dim  0 offset   0
> >   (  11) dim  0 offset   0
> >   (  12) dim  0 offset   0
> >   (  13) dim  0 offset   0
> >   (  14) dim  0 offset   0
> >   (  15) dim  3 offset   0 0. 0. 0.
> >   (  16) dim  3 offset   3 0. 2. 0.
> >   (  17) dim  3 offset   6 2. 1. 0.
> >   (  18) dim  3 offset   9 0. 0. 1.
> >   (  19) dim  3 offset  12 0. 2. 1.
> >   (  20) dim  3 offset  15 2. 1. 1.
> >  Cone           0 :           1           2           3           4
> >   5
> >  Cone           1 :           6           7           8
> >  Cone           2 :          12          13          14
> >  Cone           3 :           7           9          11          13
> >  Cone           4 :           6           9          10          12
> >  Cone           5 :           8          10          11          14
> >  Cone           6 :          15          16
> >  Cone           7 :          15          17
> >  Cone           8 :          16          17
> >  Cone           9 :          15          18
> >  Cone          10 :          16          19
> >  Cone          11 :          17          20
> >  Cone          12 :          18          19
> >  Cone          13 :          18          20
> >  Cone          14 :          19          20
> >  Cone          15 :
> >  Cone          16 :
> >  Cone          17 :
> >  Cone          18 :
> >  Cone          19 :
> >  Cone          20 :
> >   type: plex
> > Supports:
> > [0]: 1 ----> 0
> > [0]: 2 ----> 0
> > [0]: 3 ----> 0
> > [0]: 4 ----> 0
> > [0]: 5 ----> 0
> > [0]: 6 ----> 1
> > [0]: 6 ----> 4
> > [0]: 7 ----> 1
> > [0]: 7 ----> 3
> > [0]: 8 ----> 1
> > [0]: 8 ----> 5
> > [0]: 9 ----> 3
> > [0]: 9 ----> 4
> > [0]: 10 ----> 4
> > [0]: 10 ----> 5
> > [0]: 11 ----> 3
> > [0]: 11 ----> 5
> > [0]: 12 ----> 2
> > [0]: 12 ----> 4
> > [0]: 13 ----> 2
> > [0]: 13 ----> 3
> > [0]: 14 ----> 2
> > [0]: 14 ----> 5
> > [0]: 15 ----> 6
> > [0]: 15 ----> 7
> > [0]: 15 ----> 9
> > [0]: 16 ----> 6
> > [0]: 16 ----> 8
> > [0]: 16 ----> 10
> > [0]: 17 ----> 7
> > [0]: 17 ----> 8
> > [0]: 17 ----> 11
> > [0]: 18 ----> 9
> > [0]: 18 ----> 12
> > [0]: 18 ----> 13
> > [0]: 19 ----> 10
> > [0]: 19 ----> 12
> > [0]: 19 ----> 14
> > [0]: 20 ----> 11
> > [0]: 20 ----> 13
> > [0]: 20 ----> 14
> > Cones:
> > [0]: 0 <---- 1 (0)
> > [0]: 0 <---- 2 (0)
> > [0]: 0 <---- 3 (0)
> > [0]: 0 <---- 4 (0)
> > [0]: 0 <---- 5 (0)
> > [0]: 1 <---- 6 (0)
> > [0]: 1 <---- 7 (0)
> > [0]: 1 <---- 8 (0)
> > [0]: 2 <---- 12 (0)
> > [0]: 2 <---- 13 (0)
> > [0]: 2 <---- 14 (0)
> > [0]: 3 <---- 7 (0)
> > [0]: 3 <---- 9 (0)
> > [0]: 3 <---- 11 (0)
> > [0]: 3 <---- 13 (0)
> > [0]: 4 <---- 6 (0)
> > [0]: 4 <---- 9 (0)
> > [0]: 4 <---- 10 (0)
> > [0]: 4 <---- 12 (0)
> > [0]: 5 <---- 8 (0)
> > [0]: 5 <---- 10 (0)
> > [0]: 5 <---- 11 (0)
> > [0]: 5 <---- 14 (0)
> > [0]: 6 <---- 15 (0)
> > [0]: 6 <---- 16 (0)
> > [0]: 7 <---- 15 (0)
> > [0]: 7 <---- 17 (0)
> > [0]: 8 <---- 16 (0)
> > [0]: 8 <---- 17 (0)
> > [0]: 9 <---- 15 (0)
> > [0]: 9 <---- 18 (0)
> > Process 0:
> >   (   0) dim  0 offset   0
> >   (   1) dim  0 offset   0
> >   (   2) dim  0 offset   0
> >   (   3) dim  0 offset   0
> >   (   4) dim  0 offset   0
> >   (   5) dim  0 offset   0
> >   (   6) dim  0 offset   0
> >   (   7) dim  0 offset   0
> >   (   8) dim  0 offset   0
> >   (   9) dim  0 offset   0
> >   Thanks,
> >      Matt
> >> As always, many many thanks!
> >> Fabian
> >> P.S. here the output of
> >> make run
> >> and note the cones, the second time they are outputted...
> >>   type: plex
> >> Supports:
> >> [0]: 1 ----> 0
> >> [0]: 2 ----> 0
> >> [0]: 3 ----> 0
> >> [0]: 4 ----> 0
> >> [0]: 5 ----> 0
> >> [0]: 6 ----> 1
> >> [0]: 6 ----> 4
> >> [0]: 7 ----> 1
> >> [0]: 7 ----> 3
> >> [0]: 8 ----> 1
> >> [0]: 8 ----> 5
> >> [0]: 9 ----> 3
> >> [0]: 9 ----> 4
> >> [0]: 10 ----> 4
> >> [0]: 10 ----> 5
> >> [0]: 11 ----> 3
> >> [0]: 11 ----> 5
> >> [0]: 12 ----> 2
> >> [0]: 12 ----> 4
> >> [0]: 13 ----> 2
> >> [0]: 13 ----> 3
> >> [0]: 14 ----> 2
> >> [0]: 14 ----> 5
> >> [0]: 15 ----> 6
> >> [0]: 15 ----> 7
> >> [0]: 15 ----> 9
> >> [0]: 16 ----> 6
> >> [0]: 16 ----> 8
> >> [0]: 16 ----> 10
> >> [0]: 17 ----> 7
> >> [0]: 17 ----> 8
> >> [0]: 17 ----> 11
> >> [0]: 18 ----> 9
> >> [0]: 18 ----> 12
> >> [0]: 18 ----> 13
> >> [0]: 19 ----> 10
> >> [0]: 19 ----> 12
> >> [0]: 19 ----> 14
> >> [0]: 20 ----> 11
> >> [0]: 20 ----> 13
> >> [0]: 20 ----> 14
> >> Cones:
> >> [0]: 0 <---- 1 (0)
> >> [0]: 0 <---- 2 (0)
> >> [0]: 0 <---- 3 (0)
> >> [0]: 0 <---- 4 (0)
> >> [0]: 0 <---- 5 (0)
> >> [0]: 1 <---- 6 (0)
> >> [0]: 1 <---- 7 (0)
> >> [0]: 1 <---- 8 (0)
> >> [0]: 2 <---- 12 (0)
> >> [0]: 2 <---- 13 (0)
> >> [0]: 2 <---- 14 (0)
> >> [0]: 3 <---- 7 (0)
> >> [0]: 3 <---- 9 (0)
> >> [0]: 3 <---- 11 (0)
> >> [0]: 3 <---- 13 (0)
> >> [0]: 4 <---- 6 (0)
> >> [0]: 4 <---- 9 (0)
> >> [0]: 4 <---- 10 (0)
> >> [0]: 4 <---- 12 (0)
> >> [0]: 5 <---- 8 (0)
> >> [0]: 5 <---- 10 (0)
> >> [0]: 5 <---- 11 (0)
> >> [0]: 5 <---- 14 (0)
> >> [0]: 6 <---- 15 (0)
> >> [0]: 6 <---- 16 (0)
> >> [0]: 7 <---- 15 (0)
> >> [0]: 7 <---- 17 (0)
> >> [0]: 8 <---- 16 (0)
> >> [0]: 8 <---- 17 (0)
> >> [0]: 9 <---- 15 (0)
> >> [0]: 9 <---- 18 (0)
> >> Process 0:
> >>   (   0) dim  0 offset   0
> >>   (   1) dim  0 offset   0
> >>   (   2) dim  0 offset   0
> >>   (   3) dim  0 offset   0
> >>   (   4) dim  0 offset   0
> >>   (   5) dim  0 offset   0
> >>   (   6) dim  0 offset   0
> >>   (   7) dim  0 offset   0
> >>   (   8) dim  0 offset   0
> >>   (   9) dim  0 offset   0
> >>   type: plex
> >> Supports:
> >> [0]: 1 ----> 0
> >> [0]: 2 ----> 0
> >> [0]: 3 ----> 0
> >> [0]: 4 ----> 0
> >> [0]: 5 ----> 0
> >> [0]: 6 ----> 1
> >> [0]: 6 ----> 4
> >> [0]: 7 ----> 1
> >> [0]: 7 ----> 3
> >> [0]: 8 ----> 1
> >> [0]: 8 ----> 5
> >> [0]: 9 ----> 3
> >> [0]: 9 ----> 4
> >> [0]: 10 ----> 4
> >> [0]: 10 ----> 5
> >> [0]: 11 ----> 3
> >> [0]: 11 ----> 5
> >> [0]: 12 ----> 2
> >> [0]: 12 ----> 4
> >> [0]: 13 ----> 2
> >> [0]: 13 ----> 3
> >> [0]: 14 ----> 2
> >> [0]: 14 ----> 5
> >> [0]: 15 ----> 6
> >> [0]: 15 ----> 7
> >> [0]: 15 ----> 9
> >> [0]: 16 ----> 6
> >> [0]: 16 ----> 8
> >> [0]: 16 ----> 10
> >> [0]: 17 ----> 7
> >> [0]: 17 ----> 8
> >> [0]: 17 ----> 11
> >> [0]: 18 ----> 9
> >> [0]: 18 ----> 12
> >> [0]: 18 ----> 13
> >> [0]: 19 ----> 10
> >> [0]: 19 ----> 12
> >> [0]: 19 ----> 14
> >> [0]: 20 ----> 11
> >> [0]: 20 ----> 13
> >> [0]: 20 ----> 14
> >> Cones:
> >> [0]: 0 <---- 0 (0)
> >> [0]: 0 <---- 0 (0)
> >> [0]: 0 <---- 3 (0)
> >> [0]: 0 <---- 4 (0)
> >> [0]: 0 <---- 5 (0)
> >> [0]: 1 <---- 0 (0)
> >> [0]: 1 <---- 0 (0)
> >> [0]: 1 <---- 8 (0)
> >> [0]: 2 <---- 0 (0)
> >> [0]: 2 <---- 0 (0)
> >> [0]: 2 <---- 14 (0)
> >> [0]: 3 <---- 0 (0)
> >> [0]: 3 <---- 0 (0)
> >> [0]: 3 <---- 11 (0)
> >> [0]: 3 <---- 13 (0)
> >> [0]: 4 <---- 0 (0)
> >> [0]: 4 <---- 0 (0)
> >> [0]: 4 <---- 10 (0)
> >> [0]: 4 <---- 12 (0)
> >> [0]: 5 <---- 0 (0)
> >> [0]: 5 <---- 0 (0)
> >> [0]: 5 <---- 11 (0)
> >> [0]: 5 <---- 14 (0)
> >> [0]: 6 <---- 0 (0)
> >> [0]: 6 <---- 0 (0)
> >> [0]: 7 <---- 0 (0)
> >> [0]: 7 <---- 0 (0)
> >> [0]: 8 <---- 0 (0)
> >> [0]: 8 <---- 0 (0)
> >> [0]: 9 <---- 0 (0)
> >> [0]: 9 <---- 0 (0)
> >> [0]: 10 <---- 0 (0)
> >> [0]: 10 <---- 0 (0)
> >> [0]: 11 <---- 0 (0)
> >> [0]: 11 <---- 0 (0)
> >> [0]: 12 <---- 0 (0)
> >> [0]: 12 <---- 0 (0)
> >> [0]: 13 <---- 0 (0)
> >> [0]: 13 <---- 0 (0)
> >> [0]: 14 <---- 0 (0)
> >> [0]: 14 <---- 0 (0)
> >> Process 0:
> >>   (   0) dim  0 offset   0
> >>   (   1) dim  0 offset   0
> >>   (   2) dim  0 offset   0
> >>   (   3) dim  0 offset   0
> >>   (   4) dim  0 offset   0
> >>   (   5) dim  0 offset   0
> >>   (   6) dim  0 offset   0
> >>   (   7) dim  0 offset   0
> >>   (   8) dim  0 offset   0
> >>   (   9) dim  0 offset   0
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190704/a96dc33c/attachment-0001.html>
