[petsc-users] Efficiency of different choice of local rows for MPIAIJ * MPIDENSE
hong at aspiritech.org
Mon Jul 1 20:56:22 CDT 2019
Ian:
PETSc implementation of C = A*B requires C has same row ownership as A.
I believe the distribution will be dominated by the dense matrices B and C,
not sparse matrices A. Have you implemented C = A*B and logged performance?
Hong
> I am recently trying to do matrix multiplication for C = A*B, where A is a
> sparse matrix MPIAIJ, C and B are created as dense matrices MPIDENSE.
> In matrix A, the nonzeros are not distributed evenly across the processor,
> meaning that if using the default setting to let each processor own similar
> number of rows, the number of nonzeros owned by each processor will be
> significantly different. So I want to use different number of local rows
> for each processor. In this case, does the MPIDense matrices B and C need
> to be in the same row-layout as A?
> I mean, is something like the following is doable (A owns 3 rows and B, C
> own 2 rows)
> A B C
> P0 o o o o | o. o o. o o
> o o o o | o o o o o
> o o o o | o. *. ----- = ----
> --------------- o o o o
> P1 o o o o | o o o o o
> In this case, the entries can be evenly distributed for B and C thus more
> memory efficient.
> But I am not sure would this make communication more complicated thus slow
> down the overall wall time. How would you recommend to do?
> a) Let rows of A and B be both evenly distributed
> b) Let A have different rows layout, and B, C evenly distributed
> c) Let A have different rows layout, and B, C follow A
> Or maybe other better way that I did not think about.
> Thanks a lot for your help,
> Ian
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190701/89e91738/attachment.html>
