[petsc-users] Out of memory - diffusion equation eigenvalues
Rodrigo Piccinini
rbpiccinini at gmail.com
Mon Jul 1 18:19:16 CDT 2019
Hello,
I'm trying to solve for the first ten smallest eigenvalues of a diffusion
equation in a 3d heterogeneous medium (varying diffusion coefficient), but
I'm getting an error message:
Traceback (most recent call last):
> File "eigendrake_spe10_v2.py", line 121, in <module>
> es.solve()
> File "SLEPc/EPS.pyx", line 1132, in slepc4py.SLEPc.EPS.solve
> petsc4py.PETSc.Error: error code 55
> [0] EPSSolve() line 136 in
> /tmp/pip-req-build-6t_4bkg3/src/eps/interface/epssolve.c
> [0] EPSSetUp() line 269 in
> /tmp/pip-req-build-6t_4bkg3/src/eps/interface/epssetup.c
> [0] STSetUp() line 271 in
> /tmp/pip-req-build-6t_4bkg3/src/sys/classes/st/interface/stsolve.c
> [0] STSetUp_Shift() line 119 in
> /tmp/pip-req-build-6t_4bkg3/src/sys/classes/st/impls/shift/shift.c
> [0] KSPSetUp() line 391 in
> /tmp/pip-req-build-070lpqqd/src/ksp/ksp/interface/itfunc.c
> [0] PCSetUp() line 932 in
> /tmp/pip-req-build-070lpqqd/src/ksp/pc/interface/precon.c
> [0] PCSetUp_LU() line 99 in
> /tmp/pip-req-build-070lpqqd/src/ksp/pc/impls/factor/lu/lu.c
> [0] MatLUFactorSymbolic() line 3111 in
> /tmp/pip-req-build-070lpqqd/src/mat/interface/matrix.c
> [0] MatLUFactorSymbolic_SeqAIJ() line 366 in
> /tmp/pip-req-build-070lpqqd/src/mat/impls/aij/seq/aijfact.c
> [0] PetscMallocA() line 390 in
> /tmp/pip-req-build-070lpqqd/src/sys/memory/mal.c
> [0] Out of memory. Allocated: 0, Used by process: 14097043456
> [0] Memory requested 18446744069467867136
I'm using code from Firedrake Project <https://www.firedrakeproject.org/>
(finite-element method) to discretize the equations.
My code is available here:
https://github.com/rbpiccinini/codes/blob/master/eigendrake/eigendrake_spe10_v2.py
The code was run with 64GB available as RAM memory. The requested memory
seems to be abnormally high, though.
I'm able to solve for the eigenvalues of a 2d smaller problem. However, if
I try to solve the 3d problem, I get the out of memory error.
Could anybody help me understand the issue?
Thanks in advance.
Rodrigo
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190701/5b233617/attachment.html>
