[petsc-users] Imbalance in ParMETIS
    Eda Oktay
    eda.oktay at metu.edu.tr
    Mon Jul  1 03:00:42 CDT 2019
Dear Matt,
In order to get a nice cut, I am trying to change the balance, that is why
I tried to change ubvec. But still I couldn't understand why it didn't
change anything.
I tried to change vertex weights but it only made Max and Min change but it
didn't change the cut.
Eda
On Fri, Jun 28, 2019, 1:49 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Jun 28, 2019 at 5:38 AM Eda Oktay via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
>> Hello everyone,
>> I am trying to change load balance in ParMETIS in order to give different
>> number of elements to different processors. In the manual, it states that
>> changing "ubvec" parameter should work. So, instead of 1.05, I gave 1.2,1.5
>> and so on but load balance didn't change. I always get Max 5 Min 5 when I
>> view load balance. The partitioning part of my code is:
> ParMetis is always balancing. ubvec changes the balance between having
> even partitions and a nice cut. If
> you want unbalanced partitions, you have to change the vertex weights.
>   Thanks,
>     Matt
>>  ierr = MatConvert(A,MATMPIADJ,MAT_INITIAL_MATRIX,&AL);CHKERRQ(ierr);
>>   ierr = MatPartitioningCreate(MPI_COMM_WORLD,&part);CHKERRQ(ierr);
>>   ierr = MatPartitioningSetAdjacency(part,AL);CHKERRQ(ierr);
>>   ierr = MatPartitioningSetFromOptions(part);CHKERRQ(ierr);
>>   ierr = MatPartitioningApply(part,&partitioning);CHKERRQ(ierr);
>>   MatPartitioningViewImbalance(part,partitioning);
>> What should I do? Why changing ubvec didn't change anything, am I
>> missing something?
>> Thanks,
>> Eda
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190701/2c00e498/attachment.html>
