[petsc-users] PETSC matrix assembling super slow
Yaxiong Chen chen2018 at purdue.edu
Tue Jan 29 17:20:52 CST 2019
Hi Song,
I don't quite understand how I can use this command. I don't partition the gloabl matrix. If I add my elemental matrix to the global system it will be like this. And in my parallel part, I use each core to generate the elemental matrix in turn. In this case, I guess each core will be assigned the space for global matrix and finally be assembled.But according to the manual, it seems each core will store a part of the global matrix. Is the local submatrix in the MatMPIAIJSetPreallocation<https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatMPIAIJSetPreallocation.html#MatMPIAIJSetPreallocation>(Mat<https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/Mat.html#Mat> B,PetscInt<https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscInt.html#PetscInt> d_nz,const PetscInt<https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscInt.html#PetscInt> d_nnz[],PetscInt<https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscInt.html#PetscInt> o_nz,const PetscInt<https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscInt.html#PetscInt> o_nnz[])the same as my elemental matrix?
[cid:ac5af973-49cd-4207-8f47-a94751d7f444]
Thanks
Yaxiong Chen,
Ph.D. Student
School of Mechanical Engineering, 3171
585 Purdue Mall
West Lafayette, IN 47907
Sent: Tuesday, January 29, 2019 1:22 PM
To: Yaxiong Chen
Cc: Matthew Knepley; petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] PETSC matrix assembling super slow
I think you would prefer to preallocate the matrix
uncomment this line
! call MatMPIAIJSetPreallocation(Amat,f9,PETSC_NULL_INTEGER,f6,PETSC_NULL_INTEGER, ierr)
Le mar. 29 janv. 2019, à 12 h 40, Yaxiong Chen via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> a écrit :
Hello,
I have a 2D system which is assembled by each elemental matrix.  Ae is my elemental matrix, auxRHSe(:) and RHSe(:) and corresponding right hand side, idx is the global index. My code is as follow, however ,the assembling rate is super slow(Marked red in the code). I am not sure whether the assembling type is right or not. Since for each element, idx are not continuous numbers. Do you have any idea what is the better way to assemble the matrix?
Thanks
block
    PetscErrorCode ierr
     PetscMPIInt rank,nproc, mystart
     PetscInt  nelem
     integer,allocatable  ::info(:)
     real(wp), allocatable :: Ae(:,:), auxRHSe(:),RHSe(:)
     integer, allocatable      :: idx(:)
     PetscScalar, pointer :: xx_v(:)
     PC               prec
     PetscScalar ::   val
     Vec              xvec,bvec,uvec
     Mat              Amat
     KSP              ksp
     PetscViewer viewer
     PetscInt  geq,j,k,ne,M,Istart,Iend
     PetscBool  flg
     KSPConvergedReason reason
     Vec         dummyVec, dummyVecs(1)
     MatNullSpace nullspace
     call PetscInitialize( PETSC_NULL_CHARACTER, ierr )
     if (ierr .ne. 0) then
     print*,'Unable to initialize PETSc'
     stop
     endif
     call MPI_Comm_size(PETSC_COMM_WORLD,nproc,ierr)
     call MPI_Comm_rank(PETSC_COMM_WORLD,rank,ierr)
     mystart=rank+1
 !   Parameter set
     info=ptsystem%getInitInfo()
     nelem = info(Info_EleMatNum)+info(Info_FixedDOFNum)+info(Info_NumConstrain)
     print*,'nelem',nelem
 !  Create Matrix
     call MatCreate(PETSC_COMM_WORLD,Amat,ierr)
     call MatSetSizes( Amat,PETSC_DECIDE, PETSC_DECIDE, info(1), info(1), ierr )
     call MatSetType( Amat, MATMPIBAIJ, ierr )
     call MatSetFromOptions( Amat, ierr )
     call MatSetUp( Amat, ierr )
     call MatGetOwnershipRange( Amat, Istart, Iend, ierr )
      xvec = tVec(0)
      call MatCreateVecs( Amat, PETSC_NULL_VEC, xvec, ierr )
      call VecSetFromOptions( xvec, ierr )
      call VecDuplicate( xvec, bvec, ierr )
      call VecDuplicate( xvec, uvec, ierr )
   t1 = MPI_WTime();
      do i=mystart,nelem,nproc
            call ptSystem%getElementalMAT(i, Ae, auxRHSe, idx)
            ne=size(idx)
            if (allocated(auxRHSe))  call VecSetValues(bvec,ne,idx-1,auxRHSe,ADD_VALUES,ierr)
             call MatSetValues(Amat,ne,idx-1,ne,idx-1,Ae,ADD_VALUES,ierr)
      end do
      nelem   = info(Info_EleRHSNum)
      mystart = rank+1
      do i = mystart, nelem, nproc
        call ptSystem%getElementalRHS(i, RHSe, idx)
        print*,'idx',idx
        ne=size(idx)
        if (allocated(RHSe))  call VecSetValues(bvec,ne,idx-1,RHSe,ADD_VALUES,ierr)
      end do
      call MatAssemblyBegin(Amat,MAT_FINAL_ASSEMBLY,ierr)
      call MatAssemblyEnd(Amat,MAT_FINAL_ASSEMBLY,ierr)                          !  this part is slow, the for loop above is done but here it may get stuck
      call VecAssemblyBegin(bvec,ierr)        ! For a 2500 DOF system, assembling only takes over 2 seconds
      call VecAssemblyEnd(bvec,ierr)        ! But for a 10000 DOF system , it gets stuck
     t2 = MPI_WTime();
      print*,'assembeling time',t2-t1
      ! Solve
      call KSPCreate(PETSC_COMM_WORLD,ksp,ierr)
!  Set operators. Here the matrix that defines the linear system
!  also serves as the preconditioning matrix.
      call KSPSetOperators(ksp,Amat,Amat,ierr)
      call KSPSetFromOptions(ksp,ierr)
!                      Solve the linear system
    call KSPSetType(ksp,KSPCG,ierr)
    call KSPGetPC(ksp,prec,ierr)
   ! call KSPSetPCSide(ksp,PC_SYMMETRIC,ierr)
    call PCSetType(prec,PCJACOBI,ierr)
     call KSPSolve(ksp,bvec,xvec,ierr)
     call PetscFinalize(ierr)
end block
Yaxiong Chen,
Ph.D. Student
585 Purdue Mall
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190129/0f9fa5c2/attachment-0001.html>
Type: image/png
Desc: pastedImage.png
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190129/0f9fa5c2/attachment-0001.png>
