[petsc-users] Slow linear solver via MUMPS
Zhang, Junchao jczhang at mcs.anl.gov
Sat Jan 26 20:20:29 CST 2019
On Fri, Jan 25, 2019 at 8:07 PM Mohammad Gohardoust via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
I am trying to modify a "pure MPI" code for solving water movement equation in soils which employs KSP iterative solvers. This code gets really slow in the hpc I am testing it as I increase the number of calculating nodes (each node has 28 cores) even from 1 to 2. I went for implementing "MPI-OpenMP" solutions like MUMPS. I did this inside the petsc by:
KSPSetType(ksp, KSPPREONLY);
PCSetType(pc, PCLU);
PCFactorSetMatSolverType(pc, MATSOLVERMUMPS);
KSPSolve(ksp, ...
and I run it through:
export OMP_NUM_THREADS=16 && mpirun -n 2 ~/Programs/my_programs
On some cases, I saw multithreaded MUMPS could improve its performance about 30%. I guess something was wrong in your tests.  You need to compile MUMPS with OpenMP support. If you installed MUMPS through PETSc, you need petsc configure option --with-openmp=1. In addition, you need a multithreaded BLAS. You can do it through --download-openblas
But first of all, you should add --log_view to report your performance results.
The code is working (in my own PC) but it is too slow (maybe about 50 times slower). Since I am not an expert, I like to know is this what I should expect from MUMPS!?
Mohammad
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190127/93662874/attachment.html>
