[petsc-users] Fw: Integrate PETSC with existing Fortran
Yaxiong Chen
chen2018 at purdue.edu
Thu Jan 24 09:11:24 CST 2019
However, I changed the makefile,but I still received the following error:
HiDACX/obj/debug/optimal_mechanical_part.o
mpif90 -cpp -JHiDACX/obj/debug/ -Wall -fcheck=bounds -I/usr/local/include -I/Users/yaxiong/Downloads/petsc-3.9.4/include -c /Users/yaxiong/Documents/HiDAC_Code_Git/HiDAC_Tao_NURBS_Petsc/Hidac_Fortran_Lib/HiDAC_Test/optimal_mechanical_part.F90 -o HiDACX/obj/debug/optimal_mechanical_part.o
/Users/yaxiong/Downloads/petsc-3.9.4/include/petsc/finclude/petscsys.h:13:2:
#if defined (PETSC_HAVE_MPIUNI)
1~~~~~~~~~~~~
Fatal Error: petscconf.h: No such file or directory
compilation terminated.
Sent: Thursday, January 24, 2019 9:50 AM
To: Matthew Knepley
Subject: Re: [petsc-users]Integrate PETSC with existing Fortran
I see. This is because I have one .c file in the bunch of files.
$(OBJS_DIR)%.o:
@mkdir -p $(OBJS_DIR)
@echo $@
$(if $(findstring .f90, $<), \
$(FC) $(FCFLAGS) $(FIDIR) -c $< -o $@, \
$(CC) $(CCFLAGS) $(CIDIR) -c $< -o $@)
This command in makefile will use CC instead of FC since I change f90 to F90.
Thanks
Yaxiong Chen,
Ph.D. Student
School of Mechanical Engineering, 3171
585 Purdue Mall
West Lafayette, IN 47907
Sent: Thursday, January 24, 2019 5:54 AM
To: Yaxiong Chen
Cc: petsc-users at mcs.anl.gov
On Wed, Jan 23, 2019 at 2:31 PM Yaxiong Chen <chen2018 at purdue.edu<mailto:chen2018 at purdue.edu>> wrote:
Hi Matt,
I changed optimal_mechanical_part.f90 to optimal_mechanical_part.F90. But I still received the following error:
mpicc -Dqh_QHpointer -ansi -Wall -I/usr/local/include/libqhull -c /Users/yaxiong/Documents/HiDAC_Code_Git/HiDAC_Tao_NURBS_Petsc/Hidac_Fortran_Lib/HiDAC_Test/optimal_mechanical_part.F90 -o HiDACX/obj/debug/optimal_mechanical_part.o
error: invalid value 'f95-cpp-input' in '-x f95-cpp-input'
make[1]: *** [HiDACX/obj/debug/optimal_mechanical_part.o] Error 1
make: *** [debug] Error 2
Is there anything wrong with the flag?
You are compiling a Fortran file with mpicc, instead of mpif90?
Matt
Thanks
Yaxiong Chen,
Ph.D. Student
585 Purdue Mall
From: Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>>
Sent: Wednesday, January 23, 2019 1:30 PM
To: Yaxiong Chen
Cc: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>
On Wed, Jan 23, 2019 at 1:27 PM Yaxiong Chen <chen2018 at purdue.edu<mailto:chen2018 at purdue.edu>> wrote:
Hi Matt,
I tried to modify the structure of present code and use KSP in the main program(optimal_mechanical_part). Now the makefile is as following :
OUT_DIR := HiDACX/
## Define mode
ifndef MODE
.PHONY: debug release
debug: export MODE := debug
release: export MODE := release
debug release:
@$(MAKE) $@
clean:
rm -rf $(OUT_DIR)obj/ $(OUT_DIR)lib/ $(OUT_DIR)bin/
else
## SRCS = $(shell find ../../MyGit/Hidac_Fortran_Lib/ "*.f90")
SRCS_DIR := $(HOME)/Documents/HiDAC_Code_Git/HiDAC_Tao_NURBS_Petsc/Hidac_Fortran_Lib/
FSRCS := \
HiDAC_Utils/HiDAC_parameter.f90 \
HiDAC_Utils/HiDAC_dataStructure.f90 \
HiDAC_Utils/HiDAC_Math/HiDAC_mathFunction.f90 \
HiDAC_Utils/HiDAC_Math/HiDAC_mathType.f90 \
HiDAC_Utils/HiDAC_Math/HiDAC_tensor.f90 \
HiDAC_Utils/HiDAC_Math/HiDAC_Math.f90 \
HiDAC_Utils/HiDAC_Port/HiDAC_IGES.f90 \
HiDAC_Utils/HiDAC_Port/IR_Precision.f90 \
HiDAC_Utils/HiDAC_Port/Lib_Pack_Data.f90 \
HiDAC_Utils/HiDAC_Port/Lib_Base64.f90 \
HiDAC_Utils/HiDAC_Port/Lib_VTK_IO.f90 \
HiDAC_Utils/HiDAC_Port/HiDAC_VTK.f90 \
HiDAC_Utils/HiDAC_Port/HiDAC_Port.f90 \
HiDAC_Utils/HiDAC_DistanceField/HiDAC_QhullInterface_F.f90 \
HiDAC_Utils/HiDAC_DistanceField/HiDAC_BezierHull.f90 \
HiDAC_Utils/HiDAC_DistanceField/HiDAC_DistanceField.f90 \
HiDAC_Utils/HiDAC_Utils.f90 \
HiDAC_Material/HiDAC_baseMat.f90 \
HiDAC_Material/HiDAC_isoElasticMat.f90 \
HiDAC_Material/HiDAC_thermoMat.f90 \
HiDAC_Material/HiDAC_Material.f90 \
HiDAC_Approximation/HiDAC_node.f90 \
HiDAC_Approximation/HiDAC_nodeNet.f90 \
HiDAC_Approximation/HiDAC_baseApproximation.f90 \
HiDAC_Approximation/HiDAC_Approximation.f90 \
HiDAC_Approximation/HiDAC_Approximation_NURBS/HiDAC_knot.f90 \
HiDAC_Approximation/HiDAC_Approximation_NURBS/HiDAC_BezierApproximation.f90 \
HiDAC_Approximation/HiDAC_Approximation_NURBS/HiDAC_NURBSApproximation.f90 \
HiDAC_Approximation/HiDAC_Approximation_NURBS/HiDAC_THBApproximation.f90 \
HiDAC_Domain/HiDAC_primitive.f90 \
HiDAC_Domain/HiDAC_enrichment.f90 \
HiDAC_Domain/HiDAC_composedDomain.f90 \
HiDAC_Domain/HiDAC_Domain.f90 \
HiDAC_Quadrature/HiDAC_quadType.f90 \
HiDAC_Quadrature/HiDAC_directQuadrature.f90 \
HiDAC_Quadrature/HiDAC_adaptiveQuadrature.f90 \
HiDAC_Quadrature/HiDAC_Quadrature.f90 \
HiDAC_Analysis/HiDAC_BC.f90 \
HiDAC_Analysis/HiDAC_baseAnalysis.f90 \
HiDAC_Analysis/HiDAC_elastostatics.f90 \
HiDAC_Analysis/HiDAC_heatConduction.f90 \
HiDAC_Analysis/HiDAC_phaseTransition.f90 \
HiDAC_Analysis/HiDAC_fracture.f90 \
HiDAC_Analysis/HiDAC_lineenrich.f90 \
HiDAC_Analysis/HiDAC_sensitivityAnalysis.f90 \
HiDAC_Analysis/HiDAC_Analysis.f90 \
HiDAC_Solver/HiDAC_baseSolver.f90 \
HiDAC_Solver/HiDAC_LapackSolver.f90 \
HiDAC_Solver/HiDAC_MumpsSolver.f90 \
HiDAC_Solver/HiDAC_Solver.f90 \
IGES/read_iges_file.f90 \
IGES/nrb.f90 \
IGES/parse.f90 \
IGES/map.f90 \
DXF/dxf_reader.f90 \
TSRCS_DIR := $(SRCS_DIR)HiDAC_Test/
CSRCS := \
HiDAC_Utils/HiDAC_DistanceField/HiDAC_QhullInterface_C.c \
SRCS := $(addprefix $(SRCS_DIR), $(FSRCS) $(CSRCS))
OBJS_DIR := $(OUT_DIR)obj/$(MODE)/
LIB_DIR := $(OUT_DIR)lib/$(MODE)/
EXE_DIR := $(OUT_DIR)bin/$(MODE)/
EXT_DIR := /usr/local/
#petsc lib
include ${PETSC_DIR}/lib/petsc/conf/variables
include ${PETSC_DIR}/lib/petsc/conf/rules
OBJS := $(addprefix $(OBJS_DIR), \
$(patsubst %.f90, %.o, $(notdir $(FSRCS))) \
$(patsubst %.c, %.o, $(notdir $(CSRCS))))
LIB = $(LIB_DIR)libhidac.a
VPATH := $(sort $(dir $(SRCS))) $(TSRCS_DIR)
FC := mpif90
CC := mpicc
AR := ar rcs
FCFLAGS := -cpp -J$(OBJS_DIR) # ${PETSC_KSP_LIB}# -fprofile-arcs -ftest-coverage
CCFLAGS := -Dqh_QHpointer -ansi
LFLAGS := -Wl,-rpath,$(EXT_DIR)lib, ${PETSC_KSP_LIB}
FIDIR := \
-I$(EXT_DIR)include \
-I$(PETSC_DIR)/include
CIDIR := \
-I$(EXT_DIR)include/libqhull
# sequence does matter
EXTLIBS := \
-L$(EXT_DIR)lib \
-ldmumps -lmumps_common \
-lparmetis -lmetis -lpord -lscalapack \
-llapack -lblas -lqhullstatic_p \
-lpetsc
.PHONY: debug release all clean
# Handle different mode using target-specific variable
debug: FCFLAGS += -Wall -fcheck=bounds
debug: CCFLAGS += -Wall
debug: LFLAGS += -Wall -fcheck=bounds
release: FCFLAGS += -O2
release: CCFLAGS += -O2
release: LFLAGS += -O2
debug release: $(EXE_DIR)optimal_mechanical_part.hdc
## Rules
.SUFFIXES: .hdc
# Note the sequence of $(OBJS_DIR)%.o $(LIB) and $(EXTLIBS) does matter! Lib later!
$(EXE_DIR)%.hdc: $(OBJS_DIR)%.o $(LIB)
@mkdir -p $(EXE_DIR)
echo $(OBJS_DIR)
$(FC) $(LFLAGS) -o $@ $^ $(EXTLIBS) ${PETSC_KSP_LIB}
$(LIB): $(OBJS)
echo $(OBJS)
@mkdir -p $(LIB_DIR)
$(AR) $@ $^
$(OBJS_DIR)%.o:
@echo $@
## Dependencies of files
$(OBJS_DIR)optimal_mechanical_part.o: \
optimal_mechanical_part.f90 \
$(OBJS_DIR)read_iges_file.o \
$(OBJS_DIR)HiDAC_Approximation.o \
$(OBJS_DIR)HiDAC_Domain.o \
$(OBJS_DIR)HiDAC_Material.o \
$(OBJS_DIR)HiDAC_Quadrature.o \
$(OBJS_DIR)HiDAC_Analysis.o \
$(OBJS_DIR)HiDAC_Utils.o
$(OBJS_DIR)read_iges_file.o: \
$(OBJS_DIR)HiDAC_Utils.o \
$(OBJS_DIR)nrb.o \
$(OBJS_DIR)parse.o \
$(OBJS_DIR)map.o \
$(OBJS_DIR)dxf_reader.o
$(OBJS_DIR)test_main.o: \
test_main.f90 \
$(OBJS_DIR)dxf_reader.o: \
dxf_reader.f90 \
$(OBJS_DIR)nrb.o
$(OBJS_DIR)parse.o: \
parse.f90 \
$(OBJS_DIR)nrb.o
$(OBJS_DIR)map.o: \
map.f90 \
$(OBJS_DIR)nrb.o
<Other dependencies >
# $(OBJS_DIR)HiDAC_PetscSolver.o : HiDAC_PetscSolver.f90 $(OBJS_DIR)HiDAC_baseSolver.o $(OBJS_DIR)HiDAC_Utils.o
# mpif90 -cpp -JHiDACX/obj/debug/ -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -I/Users/yaxiong/Downloads/petsc-3.9.4/include \
# -I/Users/yaxiong/Downloads/petsc-3.9.4/arch-darwin-c-debug/include \
# -I/opt/X11/include -o $(OBJS_DIR)HiDAC_PetscSolver.o \
# /Users/yaxiong/Documents/HiDAC_Code_Git/HiDAC_Tao_NURBS_PETSC/Hidac_Fortran_Lib/HiDAC_Solver/HiDAC_PetscSolver.f90 \
# /Users/yaxiong/Documents/HiDAC_Code_Git/HiDAC_Tao_NURBS_PETSC/Hidac_Fortran_Lib/HiDACX/obj/debug/HiDAC_baseSolver.o \
# /Users/yaxiong/Documents/HiDAC_Code_Git/HiDAC_Tao_NURBS_PETSC/Hidac_Fortran_Lib/HiDACX/obj/debug/HiDAC_Utils.o \
# This part is removed
endif
#============================Makefile finished ===============================
and the main program starts like this:
!============================ Main program starts=========================
program main
! Import all HiDAC library
include 'mpif.h'
#include <petsc/finclude/petscksp.h>
use petscksp
use read_iges_file
use HiDAC_Approximation
use HiDAC_Domain
use HiDAC_Material
use HiDAC_Analysis
use HiDAC_Utils
use HiDAC_quadType
implicit none
I have not call the function in PETSC yet. Just add the KSP library in my main program. But I received the following error when compiling:
mpif90 -cpp -JHiDACX/obj/debug/ -Wall -fcheck=bounds -I/usr/local/include -I/Users/yaxiong/Downloads/petsc-3.9.4/include -c /Users/yaxiong/Documents/HiDAC_Code_Git/HiDAC_Tao_NURBS_Petsc/Hidac_Fortran_Lib/HiDAC_Test/optimal_mechanical_part.f90 -o HiDACX/obj/debug/optimal_mechanical_part.o
1~~~~~~~~~~~~
How can I solve this problem?
You named the file
but it has to be
in order for the compiler to preprocess it.
Matt
Thanks
Yaxiong Chen,
Ph.D. Student
585 Purdue Mall
Sent: Friday, January 18, 2019 2:21 PM
To: Yaxiong Chen; PETSc
On Fri, Jan 18, 2019 at 2:06 PM Yaxiong Chen <chen2018 at purdue.edu<mailto:chen2018 at purdue.edu>> wrote:
Hi Matt,
Do not drop the Cc.
I have hundreds .F90 files to compile as well as an .c file to compile in this project. The present makefile is more complex than the PETSC makefile. Do you mean I should use the PETSC makefile as a template and add all the dependencies in it?
If you want to do it by hand you can, its just more error prone and verbose.
My present Makefile is like the following(Red parts are news added related to Petsc). Is this the right direction? Since a static pattern is defined while the compiling for PetscSolver is a little different. I guess I should list it as a specific case instead of using the pattern.
I will comment inline.
# Name : Makefile
# Author : Tao Song
# Version : 2.1
# Copyright : GNU 2.1
# Description : Makefile for HiDACX
OUT_DIR := HiDACX/
## Define mode
ifndef MODE
debug release:
@$(MAKE) $@
clean:
else
FSRCS := \
<other .f90 files>
HiDAC_Solver/HiDAC_PetscSolver.F90 \
IGES/nrb.f90 \
IGES/parse.f90 \
IGES/map.f90 \
CSRCS := \
#petsc lib
You do not need 'rules' if you are doing things by hand. Although it is easier to just use the builtin rule for building source.
FC := mpif90
CC := mpicc
AR := ar rcs
FIDIR := \
CIDIR := \
EXTLIBS := \
-L$(EXT_DIR)lib \
-lpetsc
## Rules
.SUFFIXES: .hdc
echo $OBJS_DIR
$(LIB): $(OBJS)
echo $OBJS
$(AR) $@ $^
$(OBJS_DIR)%.o:
@echo $@
$(OBJS_DIR)nrb.o \
$(OBJS_DIR)map.o \
test_main.f90 \
<.... Other dependencies>
$ (OBJS_DIR)HiDAC_PetscSolver.o : HiDAC_PetscSolver.F90 $(OBJS_DIR)HiDAC_baseSolver.o $(OBJS_DIR)HiDAC_Utils.o
/Users/yaxiong/Documents/HiDAC_Code_Git/HiDAC_Tao_NURBS_PETSC/Hidac_Fortran_Lib/HiDAC_Solver/HiDAC_PetscSolver.F90 \
${PETSC_KSP_LIB}
You can do this, but to be certain you should should use
${FC} -c ${FC_FLAGS} ${FFLAGS} ${FCPPFLAGS}
along with your flags (-J, etc.). Notice that you do not need the *.o files here since you are only compiling.
You can simplify this by includeing 'rules' and just putting the $ (OBJS_DIR)HiDAC_PetscSolver.o as a
dependence for your link.
Matt
endif
Yaxiong Chen,
Ph.D. Student
585 Purdue Mall
Sent: Friday, January 18, 2019 11:57 AM
On Fri, Jan 18, 2019 at 11:37 AM Yaxiong Chen <chen2018 at purdue.edu<mailto:chen2018 at purdue.edu>> wrote:
Hi Matt,
Now I have some problem with makefile.I want to integrate PETSC with a previous FEM Fortran code. To do that, I add a module named PetscSolver. It starts as the following:
It needs to have suffix .F or .F90 so the preprocessor is invoked. Use the PETSc makefiles to avoid problems.
Matt
module HiDAC_PetscSolver
use petscksp
use HiDAC_Utils
use HiDAC_baseSolver
implicit none
private
type, extends(Solver), public :: PetscSolver
private
Vec xvec,bvec,uvec
Mat Amat
KSP ksp
contains
procedure :: initialize => initialize_PetscSolver
procedure :: assemble => assemble_PetscSolver
procedure :: solve => solve_PetscSolver
procedure :: postprocess => postprocess_PetscSolver
procedure :: finalize => finalize_PetscSolver
procedure :: getID
end type PetscSolver
<Functions>
end module HiDAC_PetscSolver
However, it did not compile successfully. It gave me the error:
1
Warning: Illegal preprocessor directive
/Users/yaxiong/Documents/HiDAC_Code_Git/HiDAC_Tao_NURBS_PETSC/Hidac_Fortran_Lib/HiDAC_Solver/HiDAC_PetscSolver.f90:23:5:
Vec xvec,bvec,uvec
1
Error: Unclassifiable statement at (1)
/Users/yaxiong/Documents/HiDAC_Code_Git/HiDAC_Tao_NURBS_PETSC/Hidac_Fortran_Lib/HiDAC_Solver/HiDAC_PetscSolver.f90:24:5:
Mat Amat
All function and type related to Petsc are not defined.
I must have made a very silly mistake. Can you show me how to fix it?
Thanks
Yaxiong Chen,
Ph.D. Student
585 Purdue Mall
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
-- Norbert Wiener
-- Norbert Wiener
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190124/2db00b15/attachment-0001.html>
