[petsc-users] MPI Iterative solver crash on HPC
Sal Am tempohoper at gmail.com
Wed Jan 23 02:50:50 CST 2019
Sorry it took long had to see if I could shrink down the problem files from
50GB to something smaller (now ~10GB).
> Can you compress your matrix and upload it to google drive, so we can try
> to reproduce the error.
How I ran the problem: mpiexec valgrind --tool=memcheck
--suppressions=$HOME/valgrind/valgrind-openmpi.supp -q --num-callers=20
--log-file=valgrind.log-DS.%p ./solveCSys -malloc off -ksp_type gmres
-pc_type lu -pc_factor_mat_solver_type superlu_dist -ksp_max_it 1
-ksp_monitor_true_residual -log_view -ksp_error_if_not_converged
here is the link to matrix A and vector b:
https://drive.google.com/drive/folders/16YQPTK6TfXC6pV5RMdJ9g7X-ZiqbvwU8?usp=sharing
I redid the problem (twice) by trying to solve a 1M finite elements problem
corresponding to ~ 4M n and 417M nnz matrix elements on the login shell
which has ~550GB mem, but it failed. First time it failed because of bus
error, second time it said killed. I have attached valgrind file from both
runs.
OpenMPI is not my favorite. You need to use a suppressions file to get rid
> of all of that noise. Here is one:
Thanks I have been using it, but sometimes I still see same amount of
errors.
On Fri, Jan 18, 2019 at 3:12 AM Zhang, Junchao <jczhang at mcs.anl.gov> wrote:
> Usually when I meet a SEGV error, I will run it again with a parallel
> debugger like DDT and wait for it to segfault, and then examine the stack
> trace to see what is wrong.
> --Junchao Zhang
> On Thu, Jan 17, 2019 at 10:44 AM Sal Am via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
>> I did two runs, one with the SuperLU_dist and one with bcgs using jacobi,
>> attached are the results of one of the reports from valgrind on one random
>> processor (out of the 128 files).
>> DS = direct solver
>> IS = iterative  solver
>> There is an awful lot of errors.
>> how I initiated the two runs:
>> mpiexec valgrind --tool=memcheck -q --num-callers=20
>> --log-file=valgrind.log-IS.%p ./solveCSys -malloc off -ksp_type bcgs
>> -pc_type jacobi -mattransposematmult_via scalable -build_twosided allreduce
>> -ksp_monitor -log_view
>> Thank you
>> On Thu, Jan 17, 2019 at 4:24 PM Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Thu, Jan 17, 2019 at 9:18 AM Sal Am <tempohoper at gmail.com> wrote:
>>>> 1) Running out of memory
>>>>> 2) You passed an invalid array
>>>> I have select=4:ncpus=32:mpiprocs=32:mem=300GB in the job script, i.e.
>>>> using 300GB/node, a total of 1200GB memory, using 4 nodes and 32 processors
>>>> per node (128 processors in total).
>>>> I am not sure what would constitute an invalid array or how I can check
>>>> that. I am using the same procedure as when dealing with the smaller
>>>> matrix. i.e. Generate matrix A and vector b using FEM software then convert
>>>> the matrix and vector using a python script ready for petsc. read in petsc
>>>> and calculate.
>>>> Are you running with 64-bit ints here?
>>>> Yes I have it configured petsc with  --with-64-bit-indices and
>>>> debugging mode, which this was run on.
>>> It sounds like you have enough memory, but the fact that is runs for
>>> smaller problems makes me suspicious. It
>>> could still be a memory overwrite. Can you either
>>> a) Run under valgrind
>>> or
>>> b) Run under the debugger and get a stack trace
>>>    Thanks,
>>>     Matt
>>>> On Thu, Jan 17, 2019 at 1:59 PM Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Thu, Jan 17, 2019 at 8:16 AM Sal Am <tempohoper at gmail.com> wrote:
>>>>>> SuperLU_dist supports 64-bit ints. Are you not running in parallel?
>>>>>> I will try that, although I think solving the real problem (later on
>>>>>> if I can get this to work) with 30 million finite elements might be a
>>>>>> problem for SuperLU_dist. so it is better to get an iterative solver to
>>>>>> work with first.
>>>>>> 1) Try using    -build_twosided allreduce    on this run
>>>>>> How I ran it: mpiexec valgrind --tool=memcheck -q --num-callers=20
>>>>>> --log-file=valgrind.log-osaii.%p ./solveCSys -malloc off -ksp_type bcgs
>>>>>> -pc_type gamg -mattransposematmult_via scalable -build_twosided allreduce
>>>>>> I have attached the full error output.
>>>>> You are getting an SEGV on MatSetValues(), so its either
>>>>>> 2) Is it possible to get something that fails here but we can run.
>>>>>>> None of our tests show this problem.
>>>>>> I am not how I can do that, but i have added my code which is quite
>>>>>> short and should only read and solve the system, the problem arises at
>>>>>> larger matrices for example current test case has 6 million finite elements
>>>>>> (~2B non-zero numbers and 25M x 25M matrix).
>>>>>    Matt
>>>>>> On Wed, Jan 16, 2019 at 1:12 PM Matthew Knepley <knepley at gmail.com>
>>>>>> wrote:
>>>>>>> On Wed, Jan 16, 2019 at 3:52 AM Sal Am via petsc-users <
>>>>>>>> The memory requested is an insane number. You may need to use 64
>>>>>>>>> bit integers.
>>>>>>>> Thanks Mark, I reconfigured it to use 64bit, however in the process
>>>>>>>> it says I can no longer use MUMPS and SuperLU as they are not supported (I
>>>>>>>> see on MUMPS webpage it supports 64int). However it does not exactly solve
>>>>>>>> the problem.
>>>>>>>> This time, it crashes at
>>>>>>>>> [6]PETSC ERROR: #1 MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ()
>>>>>>>>> line 1989 in /lustre/home/vef002/petsc/src/mat/impls/aij/mpi/mpimatmatmult.c
>>>>>>>>> ierr      = PetscMalloc1(bi[pn]+1,&bj);
>>>>>>>>> which allocates local portion of B^T*A.
>>>>>>>>> You may also try to increase number of cores to reduce local
>>>>>>>>> matrix size.
>>>>>>>> So I increased the number of cores to 16 on one node and ran it by :
>>>>>>>> --log-file=valgrind.log-osa.%p ./solveCSys -malloc off -ksp_type bcgs
>>>>>>>> -pc_type gamg -mattransposematmult_via scalable -ksp_monitor -log_view
>>>>>>>> It crashed after reading in the matrix and before starting to
>>>>>>>> solve. The error:
>>>>>>>> [15]PETSC ERROR: [0]PETSC ERROR:
>>>>>>>> [0]PETSC ERROR: Caught signal number 15 Terminate: Some process (or
>>>>>>>> the batch system) has told this process to end
>>>>>>>> [0]PETSC ERROR: [1]PETSC ERROR:
>>>>>>>> [2]PETSC ERROR:
>>>>>>>> [2]PETSC ERROR: Caught signal number 15 Terminate: Some process (or
>>>>>>>> [3]PETSC ERROR:
>>>>>>>> [4]PETSC ERROR:
>>>>>>>> [4]PETSC ERROR: [5]PETSC ERROR: [6]PETSC ERROR:
>>>>>>>> [8]PETSC ERROR:
>>>>>>>> [12]PETSC ERROR:
>>>>>>>> [12]PETSC ERROR: [14]PETSC ERROR:
>>>>>>>> [14]PETSC ERROR: Caught signal number 15 Terminate: Some process
>>>>>>>> (or the batch system) has told this process to end
>>>>>>>> mpiexec noticed that process rank 10 with PID 0 on node r03n01
>>>>>>>> exited on signal 9 (Killed).
>>>>>>>> Now I was running this with valgrind as someone had previously
>>>>>>>> suggested and the 16 files created all contain the same type of error:
>>>>>>> Okay, its possible that there are bugs in the MPI implementation. So
>>>>>>>   Thanks,
>>>>>>>      Matt
>>>>>>>> ==25940== Invalid read of size 8
>>>>>>>> ==25940==    at 0x5103326: PetscCheckPointer (checkptr.c:81)
>>>>>>>> ==25940==    by 0x4F42058: PetscCommGetNewTag (tagm.c:77)
>>>>>>>> ==25940==    by 0x4FC952D: PetscCommBuildTwoSidedFReq_Ibarrier
>>>>>>>> (mpits.c:373)
>>>>>>>> ==25940==    by 0x4FCB29B: PetscCommBuildTwoSidedFReq (mpits.c:572)
>>>>>>>> ==25940==    by 0x52BBFF4: VecAssemblyBegin_MPI_BTS (pbvec.c:251)
>>>>>>>> ==25940==    by 0x52D6B42: VecAssemblyBegin (vector.c:140)
>>>>>>>> ==25940==    by 0x5328C97: VecLoad_Binary (vecio.c:141)
>>>>>>>> ==25940==    by 0x5329051: VecLoad_Default (vecio.c:516)
>>>>>>>> ==25940==    by 0x52E0BAB: VecLoad (vector.c:933)
>>>>>>>> ==25940==    by 0x4013D5: main (solveCmplxLinearSys.cpp:31)
>>>>>>>> ==25940==  Address 0x19f807fc is 12 bytes inside a block of size 16
>>>>>>>> alloc'd
>>>>>>>> ==25940==    at 0x4C2A603: memalign (vg_replace_malloc.c:899)
>>>>>>>> ==25940==    by 0x4FD0B0E: PetscMallocAlign (mal.c:41)
>>>>>>>> ==25940==    by 0x4FD23E7: PetscMallocA (mal.c:397)
>>>>>>>> ==25940==    by 0x4FC948E: PetscCommBuildTwoSidedFReq_Ibarrier
>>>>>>>> (mpits.c:371)
>>>>>>>> ==25940==
>>>>>>>> On Mon, Jan 14, 2019 at 7:29 PM Zhang, Hong <hzhang at mcs.anl.gov>
>>>>>>>> wrote:
>>>>>>>>> Fande:
>>>>>>>>>> According to this PR
>>>>>>>>>> https://bitbucket.org/petsc/petsc/pull-requests/1061/a_selinger-feature-faster-scalable/diff
>>>>>>>>>> Should we set the scalable algorithm as default?
>>>>>>>>> Sure, we can. But I feel we need do more tests to compare scalable
>>>>>>>>> and non-scalable algorithms.
>>>>>>>>> On theory, for small to medium matrices, non-scalable matmatmult()
>>>>>>>>> algorithm enables more efficient
>>>>>>>>> data accessing. Andreas optimized scalable implementation. Our
>>>>>>>>> non-scalable implementation might have room to be further optimized.
>>>>>>>>> Hong
>>>>>>>>>> On Fri, Jan 11, 2019 at 10:34 AM Zhang, Hong via petsc-users <
>>>>>>>>>>> Add option '-mattransposematmult_via scalable'
>>>>>>>>>>> Hong
>>>>>>>>>>> On Fri, Jan 11, 2019 at 9:52 AM Zhang, Junchao via petsc-users <
>>>>>>>>>>>> I saw the following error message in your first email.
>>>>>>>>>>>> [0]PETSC ERROR: Out of memory. This could be due to allocating
>>>>>>>>>>>> [0]PETSC ERROR: too large an object or bleeding by not properly
>>>>>>>>>>>> [0]PETSC ERROR: destroying unneeded objects.
>>>>>>>>>>>> Probably the matrix is too large. You can try with more compute
>>>>>>>>>>>> nodes, for example, use 8 nodes instead of 2, and see what happens.
>>>>>>>>>>>> --Junchao Zhang
>>>>>>>>>>>> On Fri, Jan 11, 2019 at 7:45 AM Sal Am via petsc-users <
>>>>>>>>>>>>> Using a larger problem set with 2B non-zero elements and a
>>>>>>>>>>>>> matrix of 25M x 25M I get the following error:
>>>>>>>>>>>>> [4]PETSC ERROR:
>>>>>>>>>>>>> [4]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
>>>>>>>>>>>>> Violation, probably memory access out of range
>>>>>>>>>>>>> [4]PETSC ERROR: Try option -start_in_debugger or
>>>>>>>>>>>>> -on_error_attach_debugger
>>>>>>>>>>>>> [4]PETSC ERROR: or see
>>>>>>>>>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
>>>>>>>>>>>>> [4]PETSC ERROR: or try http://valgrind.org on GNU/linux and
>>>>>>>>>>>>> Apple Mac OS X to find memory corruption errors
>>>>>>>>>>>>> [4]PETSC ERROR: likely location of problem given in stack below
>>>>>>>>>>>>> [4]PETSC ERROR: ---------------------  Stack Frames
>>>>>>>>>>>>> [4]PETSC ERROR: Note: The EXACT line numbers in the stack are
>>>>>>>>>>>>> not available,
>>>>>>>>>>>>> [4]PETSC ERROR:       INSTEAD the line number of the start of
>>>>>>>>>>>>> the function
>>>>>>>>>>>>> [4]PETSC ERROR:       is given.
>>>>>>>>>>>>> [4]PETSC ERROR: [4] MatCreateSeqAIJWithArrays line 4422
>>>>>>>>>>>>> /lustre/home/vef002/petsc/src/mat/impls/aij/seq/aij.c
>>>>>>>>>>>>> [4]PETSC ERROR: [4] MatMatMultSymbolic_SeqAIJ_SeqAIJ line 747
>>>>>>>>>>>>> /lustre/home/vef002/petsc/src/mat/impls/aij/seq/matmatmult.c
>>>>>>>>>>>>> [4]PETSC ERROR: [4]
>>>>>>>>>>>>> MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ_nonscalable line 1256
>>>>>>>>>>>>> [4]PETSC ERROR: [4] MatTransposeMatMult_MPIAIJ_MPIAIJ line
>>>>>>>>>>>>> 1156 /lustre/home/vef002/petsc/src/mat/impls/aij/mpi/mpimatmatmult.c
>>>>>>>>>>>>> [4]PETSC ERROR: [4] MatTransposeMatMult line 9950
>>>>>>>>>>>>> /lustre/home/vef002/petsc/src/mat/interface/matrix.c
>>>>>>>>>>>>> [4]PETSC ERROR: [4] PCGAMGCoarsen_AGG line 871
>>>>>>>>>>>>> /lustre/home/vef002/petsc/src/ksp/pc/impls/gamg/agg.c
>>>>>>>>>>>>> [4]PETSC ERROR: [4] PCSetUp_GAMG line 428
>>>>>>>>>>>>> /lustre/home/vef002/petsc/src/ksp/pc/impls/gamg/gamg.c
>>>>>>>>>>>>> [4]PETSC ERROR: [4] PCSetUp line 894
>>>>>>>>>>>>> /lustre/home/vef002/petsc/src/ksp/pc/interface/precon.c
>>>>>>>>>>>>> [4]PETSC ERROR: [4] KSPSetUp line 304
>>>>>>>>>>>>> /lustre/home/vef002/petsc/src/ksp/ksp/interface/itfunc.c
>>>>>>>>>>>>> [4]PETSC ERROR: --------------------- Error Message
>>>>>>>>>>>>> [4]PETSC ERROR: Signal received
>>>>>>>>>>>>> [4]PETSC ERROR: See
>>>>>>>>>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html for
>>>>>>>>>>>>> trouble shooting.
>>>>>>>>>>>>> [4]PETSC ERROR: Petsc Release Version 3.10.2, unknown
>>>>>>>>>>>>> [4]PETSC ERROR: ./solveCSys on a linux-cumulus-debug named
>>>>>>>>>>>>> r02g03 by vef002 Fri Jan 11 09:13:23 2019
>>>>>>>>>>>>> [4]PETSC ERROR: Configure options
>>>>>>>>>>>>> PETSC_ARCH=linux-cumulus-debug
>>>>>>>>>>>>> --with-cc=/usr/local/depot/openmpi-3.1.1-gcc-7.3.0/bin/mpicc
>>>>>>>>>>>>> --with-fc=/usr/local/depot/openmpi-3.1.1-gcc-7.3.0/bin/mpifort
>>>>>>>>>>>>> --with-cxx=/usr/local/depot/openmpi-3.1.1-gcc-7.3.0/bin/mpicxx
>>>>>>>>>>>>> --download-parmetis --download-metis --download-ptscotch
>>>>>>>>>>>>> --download-superlu_dist --download-mumps --with-scalar-type=complex
>>>>>>>>>>>>> --with-debugging=yes --download-scalapack --download-superlu
>>>>>>>>>>>>> --download-fblaslapack=1 --download-cmake
>>>>>>>>>>>>> [4]PETSC ERROR: #1 User provided function() line 0 in  unknown
>>>>>>>>>>>>> file
>>>>>>>>>>>>> MPI_ABORT was invoked on rank 4 in communicator MPI_COMM_WORLD
>>>>>>>>>>>>> with errorcode 59.
>>>>>>>>>>>>> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI
>>>>>>>>>>>>> processes.
>>>>>>>>>>>>> You may or may not see output from other processes, depending
>>>>>>>>>>>>> on
>>>>>>>>>>>>> exactly when Open MPI kills them.
>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>> process (or the batch system) has told this process to end
>>>>>>>>>>>>> [0]PETSC ERROR: Try option -start_in_debugger or
>>>>>>>>>>>>> [0]PETSC ERROR: or see
>>>>>>>>>>>>> Using Valgrind on only one of the valgrind files the following
>>>>>>>>>>>>> error was written:
>>>>>>>>>>>>> ==9053== Invalid read of size 4
>>>>>>>>>>>>> ==9053==    at 0x5B8067E: MatCreateSeqAIJWithArrays
>>>>>>>>>>>>> (aij.c:4445)
>>>>>>>>>>>>> ==9053==    by 0x5BC2608: MatMatMultSymbolic_SeqAIJ_SeqAIJ
>>>>>>>>>>>>> (matmatmult.c:790)
>>>>>>>>>>>>> ==9053==    by 0x5D106F8:
>>>>>>>>>>>>> MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ_nonscalable (mpimatmatmult.c:1337)
>>>>>>>>>>>>> ==9053==    by 0x5D0E84E: MatTransposeMatMult_MPIAIJ_MPIAIJ
>>>>>>>>>>>>> (mpimatmatmult.c:1186)
>>>>>>>>>>>>> ==9053==    by 0x5457C57: MatTransposeMatMult (matrix.c:9984)
>>>>>>>>>>>>> ==9053==    by 0x64DD99D: PCGAMGCoarsen_AGG (agg.c:882)
>>>>>>>>>>>>> ==9053==    by 0x64C7527: PCSetUp_GAMG (gamg.c:522)
>>>>>>>>>>>>> ==9053==    by 0x6592AA0: PCSetUp (precon.c:932)
>>>>>>>>>>>>> ==9053==    by 0x66B1267: KSPSetUp (itfunc.c:391)
>>>>>>>>>>>>> ==9053==    by 0x4019A2: main (solveCmplxLinearSys.cpp:68)
>>>>>>>>>>>>> ==9053==  Address 0x8386997f4 is not stack'd, malloc'd or
>>>>>>>>>>>>> (recently) free'd
>>>>>>>>>>>>> ==9053==
>>>>>>>>>>>>> On Fri, Jan 11, 2019 at 8:41 AM Sal Am <tempohoper at gmail.com>
>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>> Thank you Dave,
>>>>>>>>>>>>>> I reconfigured PETSc with valgrind and debugging mode, I ran
>>>>>>>>>>>>>> the code again with the following options:
>>>>>>>>>>>>>> mpiexec -n 8 valgrind --tool=memcheck -q --num-callers=20
>>>>>>>>>>>>>> --log-file=valgrind.log.%p ./solveCSys -malloc off -ksp_type bcgs -pc_type
>>>>>>>>>>>>>> gamg -log_view
>>>>>>>>>>>>>> (as on the petsc website you linked)
>>>>>>>>>>>>>> It finished solving using the iterative solver, but the
>>>>>>>>>>>>>> resulting valgrind.log.%p files (all 8 corresponding to each processor) are
>>>>>>>>>>>>>> all empty. And it took a whooping ~15hours, for what used to take
>>>>>>>>>>>>>> ~10-20min. Maybe this is because of valgrind? I am not sure. Attached is
>>>>>>>>>>>>>> the log_view.
>>>>>>>>>>>>>> On Thu, Jan 10, 2019 at 8:59 AM Dave May <
>>>>>>>>>>>>>> dave.mayhem23 at gmail.com> wrote:
>>>>>>>>>>>>>>> On Thu, 10 Jan 2019 at 08:55, Sal Am via petsc-users <
>>>>>>>>>>>>>>>> I am not sure what is exactly is wrong as the error changes
>>>>>>>>>>>>>>>> slightly every time I run it (without changing the parameters).
>>>>>>>>>>>>>>> This likely implies that you have a memory error in your
>>>>>>>>>>>>>>> code (a memory leak would not cause this behaviour).
>>>>>>>>>>>>>>> I strongly suggest you make sure your code is free of memory
>>>>>>>>>>>>>>> errors.
>>>>>>>>>>>>>>> You can do this using valgrind. See here
>>>>>>>>>>>>>>> https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
>>>>>>>>>>>>>>> for an explanation of how to use valgrind.
>>>>>>>>>>>>>>>> I have attached the first two run's errors and my code.
>>>>>>>>>>>>>>>> Is there a memory leak somewhere? I have tried running it
>>>>>>>>>>>>>>>> with -malloc_dump, but not getting anything printed out, however, when run
>>>>>>>>>>>>>>>> with -log_view I see that Viewer is created 4 times, but destroyed 3 times.
>>>>>>>>>>>>>>>> The way I see it, I have destroyed it where I see I no longer have use for
>>>>>>>>>>>>>>>> it so not sure if I am wrong. Could this be the reason why it keeps
>>>>>>>>>>>>>>>> crashing? It crashes as soon as it reads the matrix, before entering the
>>>>>>>>>>>>>>>> solving mode (I have a print statement before solving starts that never
>>>>>>>>>>>>>>>> prints).
>>>>>>>>>>>>>>>> how I run it in the job script on 2 node with 32 processors
>>>>>>>>>>>>>>>> using the clusters OpenMPI.
>>>>>>>>>>>>>>>> mpiexec ./solveCSys -ksp_type bcgs -pc_type gamg
>>>>>>>>>>>>>>>> -ksp_converged_reason -ksp_monitor_true_residual -log_view
>>>>>>>>>>>>>>>> -ksp_error_if_not_converged -ksp_monitor -malloc_log -ksp_view
>>>>>>>>>>>>>>>> the matrix:
>>>>>>>>>>>>>>>> 2 122 821 366 (non-zero elements)
>>>>>>>>>>>>>>>> 25 947 279 x 25 947 279
>>>>>>>>>>>>>>>> Thanks and all the best
>>>>>>> What most experimenters take for granted before they begin their
>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190123/d6f37941/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190123/d6f37941/attachment-0002.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190123/d6f37941/attachment-0003.obj>
