[petsc-users] I suggest to create a demo code for the problem of "Get a value from global vector to a local processor"
Thu Jan 17 20:41:19 CST 2019
On Thu, Jan 17, 2019 at 9:39 PM leejearl <leejearl at mail.nwpu.edu.cn> wrote:
> Hi, Matt,
> On Thu, 2019-01-17 at 21:20 -0500, Matthew Knepley wrote:
> On Thu, Jan 17, 2019 at 9:04 PM leejearl <leejearl at mail.nwpu.edu.cn>
> wrote:
> Hi Matt,
> Thanks for your reply. We have got to a consensus. For such a problem, I
> have sought the mail list for helps and found a great
> many misleading answers. I think some of answers may work for the DMDA.
> Now I have overcome this
> by creating a PetscSF and PetscSFBcast, and the procedures are described
> as follow.
> 1. Using DMGLobaltoLocal to update the local vector(the ghost cell mighb
> get the wrong result)
> 2. Creating a PetscSF which matches the local ghost cell and the global
> donor cell across the processes
> 3. Using PetscSFBCast to update the local ghost cell
> Now, my code can work. Can you give me a more scalable procedure?
> That is a scalable procedure. I do not do it that way because it requires
> more steps than just meshing the structure directly.
> You are right. You have said that the more efficient way is to meshing the
> structure directly. It means that we have better to generate
> a mesh with periodic topology structure. Is it right?
Just to be clear, your method is perfectly fine. Mine is not more
efficient. I just think its easier.
You can see periodic meshes generated using DMPlexCreateBoxMesh().
    Matt
>   Thanks,
>     Matt
> Thanks.
> On Thu, 2019-01-17 at 06:43 -0500, Matthew Knepley wrote:
> On Thu, Jan 17, 2019 at 3:34 AM leejearl via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> Hi all Petscer,
>         I have ask helps for some questions. Thanks for the replies
> from developer. I have known more about the petsc. I have also sought
> helps in the mail lists, and I find that there are many subjects
> focused on such a problem. Some subjects are listed as follow
> https://lists.mcs.anl.gov/pipermail/petsc-users/2019-January/037425.html
> https://lists.mcs.anl.gov/mailman/htdig/petsc-users/2015-January/024068.html
> https://lists.mcs.anl.gov/mailman/htdig/petsc-users/2008-November/003633.html
> https://lists.mcs.anl.gov/pipermail/petsc-users/2019-January/037436.html
> The problem can be summarized as
> 1. Getting the value of vector from other processor
> 2. How to set the value of ghost cell, the value of the ghost cell
> might be as same as a very cell in other processor.
> I think the above problem is very popular. I suffer such a problem when
> I want to treat the periodic boundary for the FVM method.
> Ah, I think I am now seeing the problem. In DMPlex, we do not implement
> periodicity of the mesh by putting in extra communication. We make a
> periodic mesh directly. For example, in 1D what you describe would mesh
> a line segment, and then communicate the values from one end to the other.
> Instead, in Plex we just mesh a circle.
>   Thanks,
>     Matt
> After the dm
> object is distributed, the donor cell of bound might be in other
> processor. Since the donor cell must be matched as a pair correctly,
> using the routines DMGlobaltoLocal and DMLocaltoGlobal can not get the
> expected results.
> In fact, such a problem is not very difficult for a mpi program. But we
> are coding with the petsc, we always think that whether we can
> implement more easily.
> Whether our developer can create a demo for us to following. I think
> such a demo is very useful for user.
> Thanks
> leejeal
> Thanks
> leejearl
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190117/7c90f71c/attachment.html>
