[petsc-users] I suggest to create a demo code for the problem of "Get a value from global vector to a local processor"
Thu Jan 17 05:43:30 CST 2019
On Thu, Jan 17, 2019 at 3:34 AM leejearl via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hi all Petscer,
>         I have ask helps for some questions. Thanks for the replies
> from developer. I have known more about the petsc. I have also sought
> helps in the mail lists, and I find that there are many subjects
> focused on such a problem. Some subjects are listed as follow
> https://lists.mcs.anl.gov/pipermail/petsc-users/2019-January/037425.html
> https://lists.mcs.anl.gov/mailman/htdig/petsc-users/2015-January/024068.html
> https://lists.mcs.anl.gov/mailman/htdig/petsc-users/2008-November/003633.html
> https://lists.mcs.anl.gov/pipermail/petsc-users/2019-January/037436.html
> The problem can be summarized as
> 1. Getting the value of vector from other processor
> 2. How to set the value of ghost cell, the value of the ghost cell
> might be as same as a very cell in other processor.
> I think the above problem is very popular. I suffer such a problem when
> I want to treat the periodic boundary for the FVM method.
Ah, I think I am now seeing the problem. In DMPlex, we do not implement
periodicity of the mesh by putting in extra communication. We make a
periodic mesh directly. For example, in 1D what you describe would mesh
a line segment, and then communicate the values from one end to the other.
Instead, in Plex we just mesh a circle.
    Matt
> After the dm
> object is distributed, the donor cell of bound might be in other
> processor. Since the donor cell must be matched as a pair correctly,
> using the routines DMGlobaltoLocal and DMLocaltoGlobal can not get the
> expected results.
> In fact, such a problem is not very difficult for a mpi program. But we
> are coding with the petsc, we always think that whether we can
> implement more easily.
> Whether our developer can create a demo for us to following. I think
> such a demo is very useful for user.
> Thanks
> leejeal
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190117/9475b378/attachment.html>
