[petsc-users] MPI Iterative solver crash on HPC
Zhang, Hong hzhang at mcs.anl.gov
Mon Jan 14 10:36:31 CST 2019
This time, it crashes at
[6]PETSC ERROR: #1 MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ() line 1989 in /lustre/home/vef002/petsc/src/mat/impls/aij/mpi/mpimatmatmult.c
ierr      = PetscMalloc1(bi[pn]+1,&bj);
which allocates local portion of B^T*A.
You may also try to increase number of cores to reduce local matrix size.
Hong
On Mon, Jan 14, 2019 at 7:42 AM Mark Adams <mfadams at lbl.gov<mailto:mfadams at lbl.gov>> wrote:
The memory requested is an insane number. You may need to use 64 bit integers.
On Mon, Jan 14, 2019 at 8:06 AM Sal Am via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
I ran it by: mpiexec -n 8 valgrind --tool=memcheck -q --num-callers=20 --log-file=valgrind.log-osa.%p ./solveCSys -malloc off -ksp_type bcgs -pc_type gamg -mattransposematmult_via scalable -ksp_monitor -log_view
The error:
[6]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[6]PETSC ERROR: Out of memory. This could be due to allocating
[6]PETSC ERROR: too large an object or bleeding by not properly
[6]PETSC ERROR: destroying unneeded objects.
[6]PETSC ERROR: Memory allocated 0 Memory used by process 39398023168
[6]PETSC ERROR: Try running with -malloc_dump or -malloc_log for info.
[6]PETSC ERROR: Memory requested 18446744066024411136
[6]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[6]PETSC ERROR: Petsc Release Version 3.10.2, unknown
[6]PETSC ERROR: ./solveCSys on a linux-cumulus-debug named r02g03 by vef002 Mon Jan 14 08:54:45 2019
[6]PETSC ERROR: Configure options PETSC_ARCH=linux-cumulus-debug --with-cc=/usr/local/depot/openmpi-3.1.1-gcc-7.3.0/bin/mpicc --with-fc=/usr/local/depot/openmpi-3.1.1-gcc-7.3.0/bin/mpifort --with-cxx=/usr/local/depot/openmpi-3.1.1-gcc-7.3.0/bin/mpicxx --download-parmetis --download-metis --download-ptscotch --download-superlu_dist --download-mumps --with-scalar-type=complex --with-debugging=yes --download-scalapack --download-superlu --download-fblaslapack=1 --download-cmake
[6]PETSC ERROR: #2 PetscMallocA() line 397 in /lustre/home/vef002/petsc/src/sys/memory/mal.c
[6]PETSC ERROR: #3 MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ() line 1989 in /lustre/home/vef002/petsc/src/mat/impls/aij/mpi/mpimatmatmult.c
[6]PETSC ERROR: #4 MatTransposeMatMult_MPIAIJ_MPIAIJ() line 1203 in /lustre/home/vef002/petsc/src/mat/impls/aij/mpi/mpimatmatmult.c
[6]PETSC ERROR: #5 MatTransposeMatMult() line 9984 in /lustre/home/vef002/petsc/src/mat/interface/matrix.c
[6]PETSC ERROR: #6 PCGAMGCoarsen_AGG() line 882 in /lustre/home/vef002/petsc/src/ksp/pc/impls/gamg/agg.c
[6]PETSC ERROR: #7 PCSetUp_GAMG() line 522 in /lustre/home/vef002/petsc/src/ksp/pc/impls/gamg/gamg.c
[6]PETSC ERROR: #8 PCSetUp() line 932 in /lustre/home/vef002/petsc/src/ksp/pc/interface/precon.c
[6]PETSC ERROR: #9 KSPSetUp() line 391 in /lustre/home/vef002/petsc/src/ksp/ksp/interface/itfunc.c
[6]PETSC ERROR: #10 main() line 68 in /home/vef002/debugenv/tests/solveCmplxLinearSys.cpp
[6]PETSC ERROR: PETSc Option Table entries:
[6]PETSC ERROR: -ksp_monitor
[6]PETSC ERROR: -ksp_type bcgs
[6]PETSC ERROR: -log_view
[6]PETSC ERROR: -malloc off
[6]PETSC ERROR: -mattransposematmult_via scalable
[6]PETSC ERROR: -pc_type gamg
[6]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
MPI_ABORT was invoked on rank 6 in communicator MPI_COMM_WORLD
with errorcode 55.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
Memory requested error seems astronomical though.... This was done on a machine with 500GB of memory, during my last check it was using 30GB mem/processor not sure if it increased suddenly. The file size of the matrix is 40GB still same matrix
2 122 821 366 (non-zero elements)
25 947 279 x 25 947 279
On Fri, Jan 11, 2019 at 5:34 PM Zhang, Hong <hzhang at mcs.anl.gov<mailto:hzhang at mcs.anl.gov>> wrote:
Add option '-mattransposematmult_via scalable'
Hong
On Fri, Jan 11, 2019 at 9:52 AM Zhang, Junchao via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
I saw the following error message in your first email.
[0]PETSC ERROR: Out of memory. This could be due to allocating
[0]PETSC ERROR: too large an object or bleeding by not properly
[0]PETSC ERROR: destroying unneeded objects.
Probably the matrix is too large. You can try with more compute nodes, for example, use 8 nodes instead of 2, and see what happens.
--Junchao Zhang
On Fri, Jan 11, 2019 at 7:45 AM Sal Am via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Using a larger problem set with 2B non-zero elements and a matrix of 25M x 25M I get the following error:
[4]PETSC ERROR: ------------------------------------------------------------------------
[4]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
[4]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[4]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
[4]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[4]PETSC ERROR: likely location of problem given in stack below
[4]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[4]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[4]PETSC ERROR:       INSTEAD the line number of the start of the function
[4]PETSC ERROR:       is given.
[4]PETSC ERROR: [4] MatCreateSeqAIJWithArrays line 4422 /lustre/home/vef002/petsc/src/mat/impls/aij/seq/aij.c
[4]PETSC ERROR: [4] MatMatMultSymbolic_SeqAIJ_SeqAIJ line 747 /lustre/home/vef002/petsc/src/mat/impls/aij/seq/matmatmult.c
[4]PETSC ERROR: [4] MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ_nonscalable line 1256 /lustre/home/vef002/petsc/src/mat/impls/aij/mpi/mpimatmatmult.c
[4]PETSC ERROR: [4] MatTransposeMatMult_MPIAIJ_MPIAIJ line 1156 /lustre/home/vef002/petsc/src/mat/impls/aij/mpi/mpimatmatmult.c
[4]PETSC ERROR: [4] MatTransposeMatMult line 9950 /lustre/home/vef002/petsc/src/mat/interface/matrix.c
[4]PETSC ERROR: [4] PCGAMGCoarsen_AGG line 871 /lustre/home/vef002/petsc/src/ksp/pc/impls/gamg/agg.c
[4]PETSC ERROR: [4] PCSetUp_GAMG line 428 /lustre/home/vef002/petsc/src/ksp/pc/impls/gamg/gamg.c
[4]PETSC ERROR: [4] PCSetUp line 894 /lustre/home/vef002/petsc/src/ksp/pc/interface/precon.c
[4]PETSC ERROR: [4] KSPSetUp line 304 /lustre/home/vef002/petsc/src/ksp/ksp/interface/itfunc.c
[4]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[4]PETSC ERROR: Signal received
[4]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[4]PETSC ERROR: Petsc Release Version 3.10.2, unknown
[4]PETSC ERROR: ./solveCSys on a linux-cumulus-debug named r02g03 by vef002 Fri Jan 11 09:13:23 2019
[4]PETSC ERROR: Configure options PETSC_ARCH=linux-cumulus-debug --with-cc=/usr/local/depot/openmpi-3.1.1-gcc-7.3.0/bin/mpicc --with-fc=/usr/local/depot/openmpi-3.1.1-gcc-7.3.0/bin/mpifort --with-cxx=/usr/local/depot/openmpi-3.1.1-gcc-7.3.0/bin/mpicxx --download-parmetis --download-metis --download-ptscotch --download-superlu_dist --download-mumps --with-scalar-type=complex --with-debugging=yes --download-scalapack --download-superlu --download-fblaslapack=1 --download-cmake
[4]PETSC ERROR: #1 User provided function() line 0 in  unknown file
MPI_ABORT was invoked on rank 4 in communicator MPI_COMM_WORLD
with errorcode 59.
[0]PETSC ERROR: ------------------------------------------------------------------------
[0]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the batch system) has told this process to end
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
Using Valgrind on only one of the valgrind files the following error was written:
==9053== Invalid read of size 4
==9053==    at 0x5B8067E: MatCreateSeqAIJWithArrays (aij.c:4445)
==9053==    by 0x5BC2608: MatMatMultSymbolic_SeqAIJ_SeqAIJ (matmatmult.c:790)
==9053==    by 0x5D106F8: MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ_nonscalable (mpimatmatmult.c:1337)
==9053==    by 0x5D0E84E: MatTransposeMatMult_MPIAIJ_MPIAIJ (mpimatmatmult.c:1186)
==9053==    by 0x5457C57: MatTransposeMatMult (matrix.c:9984)
==9053==    by 0x64DD99D: PCGAMGCoarsen_AGG (agg.c:882)
==9053==    by 0x64C7527: PCSetUp_GAMG (gamg.c:522)
==9053==    by 0x6592AA0: PCSetUp (precon.c:932)
==9053==    by 0x66B1267: KSPSetUp (itfunc.c:391)
==9053==    by 0x4019A2: main (solveCmplxLinearSys.cpp:68)
==9053==  Address 0x8386997f4 is not stack'd, malloc'd or (recently) free'd
==9053==
On Fri, Jan 11, 2019 at 8:41 AM Sal Am <tempohoper at gmail.com<mailto:tempohoper at gmail.com>> wrote:
Thank you Dave,
I reconfigured PETSc with valgrind and debugging mode, I ran the code again with the following options:
mpiexec -n 8 valgrind --tool=memcheck -q --num-callers=20 --log-file=valgrind.log.%p ./solveCSys -malloc off -ksp_type bcgs -pc_type gamg -log_view
(as on the petsc website you linked)
It finished solving using the iterative solver, but the resulting valgrind.log.%p files (all 8 corresponding to each processor) are all empty. And it took a whooping ~15hours, for what used to take ~10-20min. Maybe this is because of valgrind? I am not sure. Attached is the log_view.
On Thu, Jan 10, 2019 at 8:59 AM Dave May <dave.mayhem23 at gmail.com<mailto:dave.mayhem23 at gmail.com>> wrote:
On Thu, 10 Jan 2019 at 08:55, Sal Am via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
I am not sure what is exactly is wrong as the error changes slightly every time I run it (without changing the parameters).
This likely implies that you have a memory error in your code (a memory leak would not cause this behaviour).
I strongly suggest you make sure your code is free of memory errors.
You can do this using valgrind. See here
https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
for an explanation of how to use valgrind.
I have attached the first two run's errors and my code.
Is there a memory leak somewhere? I have tried running it with -malloc_dump, but not getting anything printed out, however, when run with -log_view I see that Viewer is created 4 times, but destroyed 3 times. The way I see it, I have destroyed it where I see I no longer have use for it so not sure if I am wrong. Could this be the reason why it keeps crashing? It crashes as soon as it reads the matrix, before entering the solving mode (I have a print statement before solving starts that never prints).
how I run it in the job script on 2 node with 32 processors using the clusters OpenMPI.
mpiexec ./solveCSys -ksp_type bcgs -pc_type gamg -ksp_converged_reason -ksp_monitor_true_residual -log_view -ksp_error_if_not_converged -ksp_monitor -malloc_log -ksp_view
the matrix:
Thanks and all the best
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190114/2a5b5d82/attachment-0001.html>
