[petsc-users] Configuring PETSc with OpenMPI
Sal Am tempohoper at gmail.com
Tue Jan 8 02:58:48 CST 2019
Thanks Satish for quick response,
I tried both of the above, first removing the options --with-cc etc. and
then explicitly specifying the path e.g.
--with-cc=/usr/local/depot/openmpi-3.1.1-gcc-7.3.0/bin/mpicc etc..
Netiher worked, the error is still the same telling me "did not work" I
have attached the log file.
Thanks
On Mon, Jan 7, 2019 at 4:39 PM Balay, Satish <balay at mcs.anl.gov> wrote:
> Configure Options: --configModules=PETSc.Configure
> --optionsModule=config.compilerOptions PETSC_ARCH=linux-cumulus-hpc
> --with-cc=gcc --with-fc=gfortran --with-cxx=g++
> --with-mpi-dir=/usr/local/depot/openmpi-3.1.1-gcc-7.3.0/bin/
> --download-parmetis --download-metis --download-ptscotch
> --download-superlu_dist --download-mumps --with-scalar-type=complex
> --with-debugging=no --download-scalapack --download-superlu
> --download-fblaslapack=1 --download-cmake
> ' --with-cc=gcc --with-fc=gfortran --with-cxx=g++' prevents usage of mpicc
> etc - so remove these options when using with-mpi-dir
> Or use:
> Satish
> On Mon, 7 Jan 2019, Sal Am via petsc-users wrote:
> > Added the log file.
> > >From OpenMPI:
> > > The only special configuration that you need to build PETSc is to
> ensure
> > > that Open MPI's wrapper compilers (i.e., mpicc and mpif77) are in your
> > > $PATH before running the PETSc configure.py script.
> > > PETSc should then automatically find Open MPI's wrapper compilers and
> > > correctly build itself using Open MPI.
> > The OpenMPI dir is on my PATH which contain mpicc and mpif77.
> > This is on a HPC, if that matters.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190108/2dbf05eb/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190108/2dbf05eb/attachment-0001.obj>
