[petsc-users] Configuring PETSc with OpenMPI
Sal Am
tempohoper at gmail.com
Mon Jan 7 10:31:25 CST 2019
Added the log file.
>From OpenMPI:
> The only special configuration that you need to build PETSc is to ensure
> that Open MPI's wrapper compilers (i.e., mpicc and mpif77) are in your
> $PATH before running the PETSc configure.py script.
> PETSc should then automatically find Open MPI's wrapper compilers and
> correctly build itself using Open MPI.
The OpenMPI dir is on my PATH which contain mpicc and mpif77.
This is on a HPC, if that matters.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190107/4eda2ddc/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190107/4eda2ddc/attachment-0001.obj>
