[petsc-users] VecGetArrayF90 in PETSc/3.10 (Fortran)
Chang Liu chang.liu at utexas.edu
Sun Jan 6 16:54:39 CST 2019
Hi Satish,
I included that part in the module... At the beginning, I have:
#include "petsc/finclude/petscsys.h"
#include "petsc/finclude/petscvec.h"
#include "petsc/finclude/petscmat.h"
#include "petsc/finclude/petscpc.h"
#include "petsc/finclude/petscksp.h"
use petscksp
Sorry, I didnt mention at first...
Chang
On Sun, Jan 6, 2019 at 4:45 PM Balay, Satish <balay at mcs.anl.gov> wrote:
> This code is missing:
> #include <petsc/finclude/petscvec.h>
>       use petscvec
> Check:
> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/UsingFortran.html
> Satish
> On Sun, 6 Jan 2019, Chang Liu via petsc-users wrote:
> > Hi All,
> > Recently, when I am upgrading our code from 3.8 to 3.10, it always runs
> > into error during VecGetArrayF90 call (it is Fortran90-based code). The
> > reason we use is to access the array for our user-defined matrix-vector
> > multiplication subroutine, for example:
> > *  subroutine mymult(A,x,y,loco_ierr) *
> > *   !!!!!!!!!!!!!!! matrix-vector multiplication  y=A.x
> > *    use mat_vec_mult,only:matvec*
> > *    implicit none*
> > *    Mat,intent(in)::A ! required by PETSc*
> > *    Vec,intent(in)::x*
> > *    Vec,intent(out)::y*
> > *    PetscErrorCode,intent(out)::loco_ierr*
> > *    PetscScalar,pointer::xx(:),yy(:)*
> > *    call VecGetArrayReadF90(x,xx,loco_ierr)*
> > *    call VecGetArrayF90(y,yy,loco_ierr)*
> > *    call matvec(xx,yy)*
> > *    call VecRestoreArrayReadF90(x,xx,loco_ierr)*
> > *    call VecRestoreArrayF90(y,yy,loco_ierr)*
> > *    return*
> > * end subroutine mymult*
> > I checked the change log on the website and saw a statement:
> > TAO:
> >    - Added VecLock{Push|Pop} calls around user callbacks; use of
> >    VecGetArray in user callbacks is now prohibited.
> > Is there any relation to my issue? All the online PETSc examples and
> > description for VecGetArray/VecGetArrayF90 are the same as PETSc/3.8.  I
> > tried to add/use VecLockPop/Push, but still doesn't work.
> > I am confused and not sure what is the problem?
> > Could I get some help?
> > Thanks,
Chang Liu
PhD candidate
Dept. of Electrical & Computer Engineering
Ph: 765-7143357
Email: chang.liu at utexas.edu
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190106/59316f62/attachment.html>
