[petsc-users] VecGetArrayF90 in PETSc/3.10 (Fortran)
Chang Liu chang.liu at utexas.edu
Sun Jan 6 15:12:03 CST 2019
Hi All,
Recently, when I am upgrading our code from 3.8 to 3.10, it always runs
into error during VecGetArrayF90 call (it is Fortran90-based code). The
reason we use is to access the array for our user-defined matrix-vector
multiplication subroutine, for example:
*  subroutine mymult(A,x,y,loco_ierr) *
*   !!!!!!!!!!!!!!! matrix-vector multiplication  y=A.x
*    use mat_vec_mult,only:matvec*
*    implicit none*
*    Mat,intent(in)::A ! required by PETSc*
*    Vec,intent(in)::x*
*    Vec,intent(out)::y*
*    PetscErrorCode,intent(out)::loco_ierr*
*    PetscScalar,pointer::xx(:),yy(:)*
*    call VecGetArrayReadF90(x,xx,loco_ierr)*
*    call VecGetArrayF90(y,yy,loco_ierr)*
*    call matvec(xx,yy)*
*    call VecRestoreArrayReadF90(x,xx,loco_ierr)*
*    call VecRestoreArrayF90(y,yy,loco_ierr)*
*    return*
* end subroutine mymult*
I checked the change log on the website and saw a statement:
TAO:
   - Added VecLock{Push|Pop} calls around user callbacks; use of
   VecGetArray in user callbacks is now prohibited.
Is there any relation to my issue? All the online PETSc examples and
description for VecGetArray/VecGetArrayF90 are the same as PETSc/3.8.  I
tried to add/use VecLockPop/Push, but still doesn't work.
I am confused and not sure what is the problem?
Could I get some help?
Chang Liu
PhD candidate
Dept. of Electrical & Computer Engineering
Ph: 765-7143357
Email: chang.liu at utexas.edu
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190106/b7011833/attachment.html>
