[petsc-users] DMPlex H27 elements
Yann Jobic
yann.jobic at univ-amu.fr
Sat Jan 5 03:03:59 CST 2019
On 05/01/2019 02:36, Matthew Knepley wrote:
> On Fri, Jan 4, 2019 at 10:04 AM Yann Jobic via petsc-users
> <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
> Dear Petsc Users,
> I'm using DMPlexCreateFromCellList to create my DM. I would like
> to have
> an order 2 geometry.
> It's working fine in 2D for elements of type Q9.
> I do not see how that is possible. The topology does not work that
> way, and there
> is no way a 9 vertex quad was interpolated, so something else is
> happening.
> Moreover, anything you input still has affine geometry. Toby has been
> working on
> non-affine geometry, and all the code is there, but right now you have
> to build and
> populate the coordinate space by hand. What this means is that you
> create a
> quadratic space for the coordinate DM (rather than the default
> linear), get the
> global coordinate vector out, and stick in the Q9 coordinates. The
> topology is still
> the same no matter what coordinates you read in.
I get the idea. So at the beginning i start with the Q4/H8 dmplex, then
i fill from the global coordinate vector the missing coordinates, and
attach this new coordinate vector to the DM. Then the interpolation will
be correct ? Can i use DMproject and all the petsc functions ?
In order to output the results, i've got to write my own vtk interface
no ? (by splitting the Q9/H27 in 4xQ4 or 8xH8).
Or is it working with the hdf5 one ?
Does the p4est interface work with this setup ?
> We will get around to making an interface for this soon.
Great !
Yann
> Thanks,
> Matt
> I checked that it's working correctly by using
> DMPlexComputeCellGeometryFEM, and compute the value of the
> determinant
> (CheckMeshGeometry of dm/impls/plex/examples/tutorials/ex2.c)
> I can import H8 elements, it's working fine.
> But for H27 element, it's not working. I really don't know how to
> order
> my vertex in the cells array. So far, the determinant is zero...
> I don't know where to look in order to find this information. I tried
> the function DMPlexGetRawFaces_Internal of the file
> https://www.mcs.anl.gov/petsc/petsc-current/src/dm/impls/plex/plexinterpolate.c.html#DMPlexGetRawFaces_Internal
> but it didn't help me.
> Could you please point me where to look ?
> Thanks, and happy new year !
> Yann
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190105/c0efa278/attachment.html>
