[petsc-users] Installation error on macOS Mojave using GNU compiler
Thu Jan 3 18:45:03 CST 2019
On Thu, Jan 3, 2019 at 7:02 PM Danyang Su via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hi All,
> I am trying to install PETSc on macOS Mojave using GNU compiler.
> First, I tried the debug version using the following configuration and it
> works fine.
> ./configure --with-cc=gcc --with-cxx=g++ --with-fc=gfortran
> --download-mpich --download-scalapack --download-parmetis --download-metis
> --download-ptscotch --download-fblaslapack --download-hypre
> --download-superlu_dist --download-hdf5=yes --download-ctetgen
> After testing debug version, I reconfigured PETSc with optimization turned
> on using the following configuration. However, I got error during this step.
Your optimization flags are not right because the compiler is producing
AVX-512, but your linker cannot handle it. However, it looks like
it might be that your Fortran compiler can't handle it. Do you need
Fortran? If not, turn it off (configure with --with-fc=0) and try again.
    Matt
> --with-cxx-dialect=C++11 --download-mpich --download-scalapack
> --download-parmetis --download-metis --download-ptscotch
> --download-fblaslapack --download-hypre --download-superlu_dist
> --download-hdf5=yes --download-ctetgen --with-debugging=0 COPTFLAGS="-O3
> -march=native -mtune=native" CXXOPTFLAGS="-O3 -march=native -mtune=native"
> FOPTFLAGS="-O3 -march=native -mtune=native"
> The error information is
> ctoolchain/usr/bin/ranlib: file: .libs/libmpl.a(mpl_dbg.o) has no symbols
> /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib:
> /var/folders/jm/wcm4mv8s3v1gqz383tcf_4c00000gp/T//ccrlfFuo.s:14:2: error:
> instruction requires: AVX-512 ISA AVX-512 VL ISA
>         vmovdqu64       (%rdi), %xmm0
> make[2]: *** [src/binding/fortran/use_mpi/mpi_constants.mod-stamp] Error 1
> make[2]: *** Waiting for unfinished jobs....
> make[1]: *** [all-recursive] Error 1
> make: *** [all] Error 2
> Thanks,
> Danyang
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190103/a7fbdd1c/attachment.html>
