[petsc-users] Problems about Picard and NolinearGS
Thu Jan 3 07:35:51 CST 2019
On Thu, Jan 3, 2019 at 7:36 AM Yingjie Wu via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Thanks for your reply.
> I read the article you provided. This is my first contact with the
> quasi-Newton method.
> I have some problem:
> 1. From the point of view of algorithm, the quasi-Newton method does not
> need to be solved by linear equations, so why would KSP be used?
It is solving the equations, but we know the analytical answer. KSP is our
abstraction for linear equation solver,
so we also use it in this case.
> 2. Where and how to  use preconditioner in quasi-Newton method?
You do not need a PC here. Note that this is only going to work well if you
have a good initial
guess for the inverse of your Jacobian. The optimization people who
invented have that (it is
the identity). In Jed's paper, they use a V-cycle as the good initial guess.
    Matt
> Thanks,
> Yingjie
> Jed Brown <jed at jedbrown.org> 于2018年12月27日周四 上午10:11写道:
>> Yingjie Wu via petsc-users <petsc-users at mcs.anl.gov> writes:
>> > I my opinion, the difficulty in constructing my Jacobian matrix is
>> complex
>> > coefficient.(eg, thermal conductivity* λ* , density )
>> > For example, in temperature equation(T):
>> >                 ∇(*λ*∇T) - ∇(ρ* Cp* u ) + Q =  0
>> > *λ* is thermal conductivity , ρ* is density  Cp* is specific heat , u is
>> > velocity, Q is source.
>> > *λ = *1.9*(1.0e-3)*pow(T+273.0-150.0,1.29)            function of T
>> > ρ=
>> (0.4814*P/1.0e3/(T+273.15))/(1.0+0.446*(1.0e-2)*P/1.0e3/(pow(T+273.15,1.2)))
>> > function of T and P
>> > In theory, the coefficient contain variable. So it is complicated to
>> > calculate the element of Jacobian.
>> > In my snes_mf_operator method, I treat λ,ρ as constant. In every
>> nonlinear
>> > step, I use the solution update the λ,ρ  and thus update the
>> > preconditioning matrix. At each residual function call(in
>> > SNESFormFunction), I also update the coefficient to ensure the
>> correction
>> > of the residual function.
>> If those Jacobian entries are really that hard to get right, you can try
>> using quasi-Newton as an alternative to -snes_mf_operator; similar to
>> https://jedbrown.org/files/BrownBrune-LowRankQuasiNewtonRobustJacobianLagging-2013.pdf
>> In general, I would start with an exact Jacobian (computed by coloring,
>> AD, or just in one specific material/configuration).  Test Newton using
>> direct solvers to see your "best case" convergence (globalization may be
>> needed).  Test fieldsplit using direct solvers on the blocks so you know
>> how much error is attributable to that approximation.  Only then look at
>> backing off on the approximation of the Jacobian and the preconditioner.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190103/4418a8ef/attachment.html>
