[petsc-users] Create a DM given sets of IS's
Justin Chang jychang48 at gmail.com
Wed Jan 2 19:37:18 CST 2019
So I was slightly incorrect - these options I originally posted:
-fieldsplit_1_pc_fieldsplit_0_fields 3,4
-fieldsplit_1_pc_fieldsplit_1_fields 5
-fieldsplit_2_pc_fieldsplit_0_fields 6,7
-fieldsplit_2_pc_fieldsplit_1_fields 8
should instead be these:
-fieldsplit_1_pc_fieldsplit_0_fields 0,1
-fieldsplit_1_pc_fieldsplit_1_fields 2
-fieldsplit_2_pc_fieldsplit_0_fields 0,1
-fieldsplit_2_pc_fieldsplit_1_fields 2
So for a coupled two domain problem with three fields total: velocity,
pressure, and temperature where I'd want to schur complement the velocity
and pressure, I would use these options:
-ksp_monitor_true_residual
-ksp_view
-ksp_type gmres
-pc_type fieldsplit
-pc_fieldsplit_0_fields 0,1,2
-fieldsplit_0_ksp_type preonly
-fieldsplit_0_pc_type fieldsplit
-fieldsplit_0_pc_fieldsplit_type additive
-fieldsplit_0_pc_fieldsplit_0_fields 0,1
-fieldsplit_0_fieldsplit_0_pc_type fieldsplit
-fieldsplit_0_fieldsplit_0_pc_fieldsplit_type schur
-fieldsplit_0_fieldsplit_0_pc_fieldsplit_fact_type full
-fieldsplit_0_fieldsplit_0_pc_fieldsplit_schur_precondition selfp
-fieldsplit_0_fieldsplit_0_fieldsplit_v1_ksp_type preonly
-fieldsplit_0_fieldsplit_0_fieldsplit_p1_ksp_type preonly
-fieldsplit_0_fieldsplit_0_fieldsplit_v1_pc_type bjacobi
-fieldsplit_0_fieldsplit_0_fieldsplit_p1_pc_type hypre
-fieldsplit_0_pc_fieldsplit_1_fields 2
-fieldsplit_0_fieldsplit_t1_ksp_type preonly
-fieldsplit_0_fieldsplit_t1_pc_type hypre
-pc_fieldsplit_1_fields 3,4,5
-fieldsplit_1_ksp_type preonly
-fieldsplit_1_pc_type fieldsplit
-fieldsplit_1_pc_fieldsplit_type additive
-fieldsplit_1_fieldsplit_0_pc_type fieldsplit
-fieldsplit_1_fieldsplit_0_pc_fieldsplit_type schur
-fieldsplit_1_fieldsplit_0_pc_fieldsplit_fact_type full
-fieldsplit_1_fieldsplit_0_pc_fieldsplit_schur_precondition selfp
-fieldsplit_1_fieldsplit_0_fieldsplit_v2_ksp_type preonly
-fieldsplit_1_fieldsplit_0_fieldsplit_p2_ksp_type preonly
-fieldsplit_1_fieldsplit_0_fieldsplit_v2_pc_type bjacobi
-fieldsplit_1_fieldsplit_0_fieldsplit_p2_pc_type hypre
-fieldsplit_1_fieldsplit_t2_ksp_type preonly
-fieldsplit_1_fieldsplit_t2_pc_type hypre
Attached is the output of ksp_view
On Wed, Jan 2, 2019 at 3:39 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Jan 2, 2019 at 4:55 PM Justin Chang <jychang48 at gmail.com> wrote:
>> Okay that's fine.
>> Now consider one more case:
>> Suppose I create a PetscSection with 9 fields:
>> section = PETSc.Section().create()
>> section.setNumFields(9)
>> section.setFieldName(0,'u1')
>> section.setFieldName(1,'c1')
>> section.setFieldName(2,'t1')
>> section.setFieldName(3,'u2')
>> section.setFieldName(4,'c2')
>> section.setFieldName(5,'t2')
>> section.setFieldName(6,'u3')
>> section.setFieldName(7,'c3')
>> section.setFieldName(8,'t3')
>> section.setFieldComponents(0,1)
>> section.setFieldComponents(1,1)
>> section.setFieldComponents(2,1)
>> section.setFieldComponents(3,1)
>> section.setFieldComponents(4,1)
>> section.setFieldComponents(5,1)
>> section.setFieldComponents(6,1)
>> section.setFieldComponents(7,1)
>> section.setFieldComponents(8,1)
>> where u is potential, c is concentration, and t is temperature. The
>> numbers refer to different domains of a battery (anode, electrolyte,
>> cathode).
>> I want three levels of splits:
>> 1) Split by domain
>> 2) Split potential and concentration from temperature.
>> 3) Split potential and concentration for schur complementing purpose.
>> Do the following PETSc command line options describe the split I
>> mentioned above:
>> -pc_type fieldsplit
>> -pc_fieldsplit_2_fields 6,7,8
>> -fieldsplit_2_pc_type fieldsplit
>> I don't have an actual code to test these out with yet as I've never done
>> anything beyond two levels of split. So I am wondering if the above will
>> break anything as far as you can tell.
> This should work as you expect. Send me the -ksp_view output when you run
> it. It would be very cool to see 3-level in action.
>   Thanks,
>      Matt
>> Thanks,
>> Justin
>> On Tue, Jan 1, 2019 at 7:10 AM Matthew Knepley <knepley at gmail.com> wrote:
>>> On Tue, Jan 1, 2019 at 5:06 AM Justin Chang <jychang48 at gmail.com> wrote:
>>>> Okay so I managed to successfully do this by translating the IS's into
>>>> a PetscSection, assigning it to an empty DMShell, and then assigning that
>>>> to KSP.
>>>> However, I seem to be unable to rename the outer fields that aggregate
>>>> two or more inner fields.
>>> Right now you cannot do that because of the way that I check for the
>>> option:
>>> https://bitbucket.org/petsc/petsc/src/0a5f382fff62a328ec919e3e9fe959e6cbbcf413/src/ksp/pc/impls/fieldsplit/fieldsplit.c#lines-369
>>> I guess we could replace this by some search code that looked for any
>>> option of that form and then read
>>> out the splitname using scanf. Right now, I do not see a pattern search
>>> function for the options database.
>>>   Thanks,
>>>     Matt
>>>> Consider this snippet of a four-field dual porosity/permeability
>>>> FEniCS/petsc4py code:
>>>> ## Extract FEniCS dof layout, global indices ##
>>>> dof_total = np.array(W.dofmap().dofs())
>>>> dof_v1 = np.array(W.sub(0).dofmap().dofs())
>>>> dof_p1 = np.array(W.sub(1).dofmap().dofs())
>>>> dof_v2 = np.array(W.sub(2).dofmap().dofs())
>>>> dof_p2 = np.array(W.sub(3).dofmap().dofs())
>>>> offset = np.min(dof_total)
>>>> ## Create PetscSection ##
>>>> section.setNumFields(4)
>>>> section.setFieldName(0,'v1')
>>>> section.setFieldName(1,'p1')
>>>> section.setFieldName(2,'v2')
>>>> section.setFieldName(3,'p2')
>>>> section.setChart(0,len(dof_total))
>>>> for i in np.nditer(dof_v1):
>>>>   section.setDof(i-offset,1)
>>>>   section.setFieldDof(i-offset,0,1)
>>>> for i in np.nditer(dof_p1):
>>>>   section.setFieldDof(i-offset,1,1)
>>>> for i in np.nditer(dof_v2):
>>>>   section.setFieldDof(i-offset,2,1)
>>>> for i in np.nditer(dof_p2):
>>>>   section.setFieldDof(i-offset,3,1)
>>>> section.setUp()
>>>> ## Create DM and assign PetscSection ##
>>>> dm = PETSc.DMShell().create()
>>>> dm.setDefaultSection(section)
>>>> dm.setUp()
>>>> ## Create KSP and assign DM ##
>>>> ksp = PETSc.KSP().create()
>>>> ksp.setDM(dm)
>>>> ksp.setDMActive(False)
>>>> ### PETSc Command-line options ##
>>>> PETScOptions.set('ksp_monitor_true_residual')
>>>> PETScOptions.set('ksp_view')
>>>> PETScOptions.set('ksp_type','gmres')
>>>> PETScOptions.set('pc_type','fieldsplit')
>>>> PETScOptions.set('pc_fieldsplit_0_fields','0,1')
>>>> PETScOptions.set('pc_fieldsplit_1_fields','2,3')
>>>> PETScOptions.set('pc_fieldsplit_type','additive')
>>>> PETScOptions.set('fieldsplit_0_ksp_type','preonly')
>>>> PETScOptions.set('fieldsplit_0_pc_type','fieldsplit')
>>>> PETScOptions.set('fieldsplit_0_pc_fieldsplit_type','schur')
>>>> PETScOptions.set('fieldsplit_0_pc_fieldsplit_schur_fact_type','full')
>>>> PETScOptions.set('fieldsplit_0_pc_fieldsplit_schur_precondition','selfp')
>>>> PETScOptions.set('fieldsplit_0_fieldsplit_v1_ksp_type','preonly')
>>>> PETScOptions.set('fieldsplit_0_fieldsplit_v1_pc_type','bjacobi')
>>>> PETScOptions.set('fieldsplit_0_fieldsplit_p1_ksp_type','preonly')
>>>> PETScOptions.set('fieldsplit_0_fieldsplit_p1_pc_type','hypre')
>>>> PETScOptions.set('fieldsplit_1_ksp_type','preonly')
>>>> PETScOptions.set('fieldsplit_1_pc_type','fieldsplit')
>>>> PETScOptions.set('fieldsplit_1_pc_fieldsplit_type','schur')
>>>> PETScOptions.set('fieldsplit_1_pc_fieldsplit_schur_fact_type','full')
>>>> PETScOptions.set('fieldsplit_1_pc_fieldsplit_schur_precondition','selfp')
>>>> PETScOptions.set('fieldsplit_1_fieldsplit_v2_ksp_type','preonly')
>>>> PETScOptions.set('fieldsplit_1_fieldsplit_v2_pc_type','bjacobi')
>>>> PETScOptions.set('fieldsplit_1_fieldsplit_p2_ksp_type','preonly')
>>>> PETScOptions.set('fieldsplit_1_fieldsplit_p2_pc_type','hypre')
>>>> Is it possible to rename the outer splits (aka make
>>>> '-pc_fieldsplit_0_fields 0,1' be something like
>>>> '-pc_fieldsplit_micro_fields 0,1')?
>>>> Thanks,
>>>> Justin
>>>> On Mon, Dec 31, 2018 at 7:40 AM Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Mon, Dec 31, 2018 at 2:40 AM Justin Chang via petsc-users <
>>>>> petsc-users at mcs.anl.gov> wrote:
>>>>>> Hi all,
>>>>>> I am solving a six field battery problem (concentration and potential
>>>>>> for each of the two solid and one electrolyte domains) and I want to
>>>>>> experiment with nested/recursice fieldsplitting. I have the IS's and am
>>>>>> able to use these to define my PCFieldSplitsSetIS(). However, I can imagine
>>>>>> this getting really messy from a programming standpoint, especially once I
>>>>>> need to add temperature into the mix, so it is my hope that I can translate
>>>>>> these index sets and fields into a DM (maybe DMShell?) so that I can just
>>>>>> rely on command line options to play around with various combinations of
>>>>>> field assignments and splits (e.g. -pc_fieldsplit_X_fields)
>>>>>> However, it doesn't seem clear to me how I would create a DM when you
>>>>>> already know the IS's for each fields. If I understand functions like
>>>>>> DMCreateFieldDecomposition() correctly, it seems that it returns to you the
>>>>>> IS's and sub DM's associated with the original DM, whereas I want to do it
>>>>>> the other way around. Perhaps the "reversal" of something like
>>>>>> DMCreateFieldIS()
>>>>>> <https://www.mcs.anl.gov/petsc/petsc-dev/src/dm/interface/dm.c.html#DMCreateFieldIS>,
>>>>>> where you convert the IS into a PetscSection or is there an easier/better
>>>>>> way?
>>>>>> Any thoughts/help appreciated!
>>>>> Paul has recently done this for LibMesh. I believe that constructing a
>>>>> PetscSection is enough to get you minimally started. That allows
>>>>> DMCreateSubDM() to work by subsetting the Section, and that should
>>>>> allow the command line to work. CreateFieldDecomposition() should
>>>>> be removed I think.
>>>>>   Thanks,
>>>>>     Matt
>>>>>> Justin
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190102/b45e48e3/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190102/b45e48e3/attachment-0001.obj>
