[petsc-users] Create a DM given sets of IS's
Justin Chang
jychang48 at gmail.com
Wed Jan 2 15:54:35 CST 2019
Okay that's fine.
Now consider one more case:
Suppose I create a PetscSection with 9 fields:
section = PETSc.Section().create()
section.setNumFields(9)
section.setFieldName(0,'u1')
section.setFieldName(1,'c1')
section.setFieldName(2,'t1')
section.setFieldName(3,'u2')
section.setFieldName(4,'c2')
section.setFieldName(5,'t2')
section.setFieldName(6,'u3')
section.setFieldName(7,'c3')
section.setFieldName(8,'t3')
section.setFieldComponents(0,1)
section.setFieldComponents(1,1)
section.setFieldComponents(2,1)
section.setFieldComponents(3,1)
section.setFieldComponents(4,1)
section.setFieldComponents(5,1)
section.setFieldComponents(6,1)
section.setFieldComponents(7,1)
section.setFieldComponents(8,1)
where u is potential, c is concentration, and t is temperature. The numbers
refer to different domains of a battery (anode, electrolyte, cathode).
I want three levels of splits:
1) Split by domain
2) Split potential and concentration from temperature.
3) Split potential and concentration for schur complementing purpose.
Do the following PETSc command line options describe the split I mentioned
above:
-pc_type fieldsplit
-pc_fieldsplit_0_fields 0,1,2
-pc_fieldsplit_1_fields 3,4,5
-pc_fieldsplit_2_fields 6,7,8
-fieldsplit_0_pc_type fieldsplit
-fieldsplit_1_pc_type fieldsplit
-fieldsplit_2_pc_type fieldsplit
-fieldsplit_0_pc_fieldsplit_0_fields 0,1
-fieldsplit_0_pc_fieldsplit_1_fields 2
-fieldsplit_1_pc_fieldsplit_0_fields 3,4
-fieldsplit_1_pc_fieldsplit_1_fields 5
-fieldsplit_2_pc_fieldsplit_0_fields 6,7
-fieldsplit_2_pc_fieldsplit_1_fields 8
I don't have an actual code to test these out with yet as I've never done
anything beyond two levels of split. So I am wondering if the above will
break anything as far as you can tell.
Justin
On Tue, Jan 1, 2019 at 7:10 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Jan 1, 2019 at 5:06 AM Justin Chang <jychang48 at gmail.com> wrote:
>> Okay so I managed to successfully do this by translating the IS's into a
>> PetscSection, assigning it to an empty DMShell, and then assigning that to
>> KSP.
>> However, I seem to be unable to rename the outer fields that aggregate
>> two or more inner fields.
> Right now you cannot do that because of the way that I check for the
> option:
> https://bitbucket.org/petsc/petsc/src/0a5f382fff62a328ec919e3e9fe959e6cbbcf413/src/ksp/pc/impls/fieldsplit/fieldsplit.c#lines-369
> I guess we could replace this by some search code that looked for any
> option of that form and then read
> out the splitname using scanf. Right now, I do not see a pattern search
> function for the options database.
> Thanks,
> Matt
>> Consider this snippet of a four-field dual porosity/permeability
>> FEniCS/petsc4py code:
>> ## Extract FEniCS dof layout, global indices ##
>> dof_total = np.array(W.dofmap().dofs())
>> dof_v1 = np.array(W.sub(0).dofmap().dofs())
>> dof_p1 = np.array(W.sub(1).dofmap().dofs())
>> dof_v2 = np.array(W.sub(2).dofmap().dofs())
>> dof_p2 = np.array(W.sub(3).dofmap().dofs())
>> offset = np.min(dof_total)
>> ## Create PetscSection ##
>> section.setNumFields(4)
>> section.setFieldName(0,'v1')
>> section.setFieldName(1,'p1')
>> section.setFieldName(2,'v2')
>> section.setFieldName(3,'p2')
>> section.setChart(0,len(dof_total))
>> for i in np.nditer(dof_v1):
>> section.setDof(i-offset,1)
>> section.setFieldDof(i-offset,0,1)
>> for i in np.nditer(dof_p1):
>> section.setFieldDof(i-offset,1,1)
>> for i in np.nditer(dof_v2):
>> section.setFieldDof(i-offset,2,1)
>> for i in np.nditer(dof_p2):
>> section.setFieldDof(i-offset,3,1)
>> section.setUp()
>> ## Create DM and assign PetscSection ##
>> dm = PETSc.DMShell().create()
>> dm.setDefaultSection(section)
>> dm.setUp()
>> ## Create KSP and assign DM ##
>> ksp = PETSc.KSP().create()
>> ksp.setDM(dm)
>> ksp.setDMActive(False)
>> ### PETSc Command-line options ##
>> PETScOptions.set('ksp_monitor_true_residual')
>> PETScOptions.set('ksp_view')
>> PETScOptions.set('ksp_type','gmres')
>> PETScOptions.set('pc_type','fieldsplit')
>> PETScOptions.set('pc_fieldsplit_0_fields','0,1')
>> PETScOptions.set('pc_fieldsplit_1_fields','2,3')
>> PETScOptions.set('pc_fieldsplit_type','additive')
>> PETScOptions.set('fieldsplit_0_ksp_type','preonly')
>> PETScOptions.set('fieldsplit_0_pc_type','fieldsplit')
>> PETScOptions.set('fieldsplit_0_pc_fieldsplit_type','schur')
>> PETScOptions.set('fieldsplit_0_pc_fieldsplit_schur_fact_type','full')
>> PETScOptions.set('fieldsplit_0_pc_fieldsplit_schur_precondition','selfp')
>> PETScOptions.set('fieldsplit_0_fieldsplit_v1_ksp_type','preonly')
>> PETScOptions.set('fieldsplit_0_fieldsplit_v1_pc_type','bjacobi')
>> PETScOptions.set('fieldsplit_0_fieldsplit_p1_ksp_type','preonly')
>> PETScOptions.set('fieldsplit_0_fieldsplit_p1_pc_type','hypre')
>> PETScOptions.set('fieldsplit_1_ksp_type','preonly')
>> PETScOptions.set('fieldsplit_1_pc_type','fieldsplit')
>> PETScOptions.set('fieldsplit_1_pc_fieldsplit_type','schur')
>> PETScOptions.set('fieldsplit_1_pc_fieldsplit_schur_fact_type','full')
>> PETScOptions.set('fieldsplit_1_pc_fieldsplit_schur_precondition','selfp')
>> PETScOptions.set('fieldsplit_1_fieldsplit_v2_ksp_type','preonly')
>> PETScOptions.set('fieldsplit_1_fieldsplit_v2_pc_type','bjacobi')
>> PETScOptions.set('fieldsplit_1_fieldsplit_p2_ksp_type','preonly')
>> PETScOptions.set('fieldsplit_1_fieldsplit_p2_pc_type','hypre')
>> Is it possible to rename the outer splits (aka make
>> '-pc_fieldsplit_0_fields 0,1' be something like
>> '-pc_fieldsplit_micro_fields 0,1')?
>> Thanks,
>> Justin
>> On Mon, Dec 31, 2018 at 7:40 AM Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Mon, Dec 31, 2018 at 2:40 AM Justin Chang via petsc-users <
>>> petsc-users at mcs.anl.gov> wrote:
>>>> Hi all,
>>>> I am solving a six field battery problem (concentration and potential
>>>> for each of the two solid and one electrolyte domains) and I want to
>>>> experiment with nested/recursice fieldsplitting. I have the IS's and am
>>>> able to use these to define my PCFieldSplitsSetIS(). However, I can imagine
>>>> this getting really messy from a programming standpoint, especially once I
>>>> need to add temperature into the mix, so it is my hope that I can translate
>>>> these index sets and fields into a DM (maybe DMShell?) so that I can just
>>>> rely on command line options to play around with various combinations of
>>>> field assignments and splits (e.g. -pc_fieldsplit_X_fields)
>>>> However, it doesn't seem clear to me how I would create a DM when you
>>>> already know the IS's for each fields. If I understand functions like
>>>> DMCreateFieldDecomposition() correctly, it seems that it returns to you the
>>>> IS's and sub DM's associated with the original DM, whereas I want to do it
>>>> the other way around. Perhaps the "reversal" of something like
>>>> DMCreateFieldIS()
>>>> <https://www.mcs.anl.gov/petsc/petsc-dev/src/dm/interface/dm.c.html#DMCreateFieldIS>,
>>>> where you convert the IS into a PetscSection or is there an easier/better
>>>> way?
>>>> Any thoughts/help appreciated!
>>> Paul has recently done this for LibMesh. I believe that constructing a
>>> PetscSection is enough to get you minimally started. That allows
>>> DMCreateSubDM() to work by subsetting the Section, and that should allow
>>> the command line to work. CreateFieldDecomposition() should
>>> be removed I think.
>>> Thanks,
>>> Matt
>>>> Justin
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190102/802a5c77/attachment.html>
