[petsc-users] Error in using MatTranspose
Matthew Knepley
knepley at gmail.com
Thu Feb 28 08:34:48 CST 2019
On Thu, Feb 28, 2019 at 3:15 AM Eda Oktay via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hello,
> I am trying to use MatTranspose function as in below (last row) but I get
> an error like this:
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Object is in wrong state
> [0]PETSC ERROR: Not for unassembled matrix
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.10.3, Dec, 18, 2018
> [0]PETSC ERROR: ./FINAL on a arch-linux2-c-debug named
> localhost.localdomain by edaoktay Wed Feb 27 16:36:34 2019
> [0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
> --with-fc=gfortran --with-cxx-dialect=C++11 --download-openblas
> --download-metis --download-parmetis --download-superlu_dist
> --download-slepc --download-mpich
> [0]PETSC ERROR: #1 MatTranspose() line 4821 in
> /home/edaoktay/petsc-3.10.3/src/mat/interface/matrix.c
> [0]PETSC ERROR: #2 main() line 185 in
> /home/edaoktay/petsc-3.10.3/arch-linux2-c-debug/share/slepc/examples/src/eda/FINAL.c
> [0]PETSC ERROR: PETSc Option Table entries:
> [0]PETSC ERROR: -f
> /home/edaoktay/petsc-3.10.3/share/petsc/datafiles/matrices/small
> [0]PETSC ERROR: -unweighted
> [0]PETSC ERROR: ----------------End of Error Message -------send entire
> error message to petsc-maint at mcs.anl.gov----------
> I understood that error states that there is an unassembled matrix but
> there is not, as it can be seen below, I defined NSymmA and I want to get
> NSymmAtr.
> This not the first time I use MatTranspose but I only get this error here.
> What can be the reason?
> Best regards,
> Eda
> ierr = MatGetOwnershipRange(L,&mm,&nn);CHKERRQ(ierr);
> ierr =
> MatDuplicate(A,MAT_DO_NOT_COPY_VALUES,&NSymmA);CHKERRQ(ierr);
> for(rw = mm; rw<nn; ++rw){
> ierr = MatGetRow(L,rw,&ncols,&cols,&vals);CHKERRQ(ierr);
> s = sizeof(vals);
> ierr = PetscMalloc1(s,&arr);CHKERRQ(ierr);
> for(j=0;j<s;++j){
> arr[j]=-1;
> ierr =
> MatSetValues(NSymmA,1,&rw,ncols,cols,arr,INSERT_VALUES);CHKERRQ(ierr);
> ierr = MatRestoreRow(L,rw,&ncols,&cols,&vals);CHKERRQ(ierr);
You have to assemble here since you called MatSetValues().
Matt
ierr =
> MatTranspose(NSymmA,MAT_INITIAL_MATRIX,&NSymmAtr);CHKERRQ(ierr);
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190228/8571cf32/attachment.html>
