[petsc-users] Direct PETSc to use MCDRAM on KNL and other optimizations for KNL
Sajid Ali sajidsyed2021 at u.northwestern.edu
Wed Feb 27 19:02:43 CST 2019
Hi Junchao,
I’m confused with the syntax. If I submit the following as my job script, I
get an error :
#!/bin/bash
#SBATCH --job-name=petsc_test
#SBATCH -N 1
#SBATCH -C knl,quad,flat
#SBATCH -p apsxrmd
#SBATCH --time=1:00:00
module load intel/18.0.3-d6gtsxs
module load intel-parallel-studio/cluster.2018.3-xvnfrfz
module load numactl-2.0.12-intel-18.0.3-wh44iog
srun -n 64 -c 64 --cpu_bind=cores numactl -m 1 aps ./ex_modify
-ts_type cn -prop_steps 25 -pc_type gamg -ts_monitor -log_view
The error is :
srun: cluster configuration lacks support for cpu binding
srun: error: Unable to create step for job 916208: More processors
requested than permitted
I’m following the advice as given at slide 33 of
https://www.nersc.gov/assets/Uploads/02-using-cori-knl-nodes-20170609.pdf
For further info, I’m using LCRC at ANL.
Thank You,
Sajid Ali
Applied Physics
Northwestern University
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190227/88f81bce/attachment.html>
