[petsc-users] Nonconforming object sizes in axpy
Marius Buerkle mbuerkle at web.de
Wed Feb 27 17:25:18 CST 2019
Ok. I also tried without openmp which gave the same error.
The segfault left aside, is MatAXPY supposed to work when Y is of type ELEMENTAL and X of type MATMPIAIJ ? It worked before but now it stops with mat elemental not supported.
> Von: "Stefano Zampini" <stefano.zampini at gmail.com>
> An: "Marius Buerkle" <mbuerkle at web.de>
> Cc: "Matthew Knepley" <knepley at gmail.com>, "PETSc users list" <petsc-users at mcs.anl.gov>
> Betreff: Re: [petsc-users] Nonconforming object sizes in axpy
> If you check ALL ERROR CODES by doing
> ierr = _AnyPetscCall_();CHKERRQ(ierr);
> The code will stop at the first error
> I see you are using openmp. Probably this is causing the problem, I don’t know what to say without a MWE.
> > On Feb 25, 2019, at 10:50 PM, Marius Buerkle <mbuerkle at web.de> wrote:
> > <error_output.tar.gz>
