[petsc-users] Error Norm_2
Fazlul Huq
huq2090 at gmail.com
Mon Feb 25 20:37:03 CST 2019
Hello PETSc Developers,
Thanks for the response!
To calculate error, I first calculate the analytical solution and put it
inside vector s.
Then I took difference between analytical solution and numerical solution
and put it inside vector x.
Then I calculate the NORM_2 of x.
The code is as follows:
Check the error
for (i = 0; i < n; i++)
k1 = (float) (i+1)/(n+1);
k2 = -0.5 * k1 * k1 + 5.5 * k1 + 10;
ierr = VecSetValues(s, 1, &i, &k2, INSERT_VALUES);CHKERRQ(ierr);
ierr = VecAXPY(x,-1.0,s);CHKERRQ(ierr);
ierr = VecNorm(x,NORM_2,&norm);CHKERRQ(ierr);
if (norm > tol) {
ierr = PetscPrintf(PETSC_COMM_WORLD,"Second Norm of error
%g\n",(double)norm);CHKERRQ(ierr);
Thanks again.
Sincerely,
Huq
On Mon, Feb 25, 2019 at 5:15 PM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> How are you computing the error norm?
> You need to use the L2 norm in the computations, not the l2 norm.
> Also you need to make sure the convergence criteria you use for the
> algebraic system is smaller than the descritzation error
> Barry
> > On Feb 25, 2019, at 1:55 PM, Fazlul Huq via petsc-users <
> > I have solved a very simple poisson problem with different matrix sizes
> (10 to 10^7).
> > But when I have compared error norm_2 for the solution, I got the
> attached curve.
> > It looks like error norm_2 increases with increasing matrix size.
> Shouldn't it decrease rather with increasing matrix size?
> > Thanks.
> > Sincerely,
> > Huq
> > Fazlul Huq
> > Graduate Research Assistant
> > Department of Nuclear, Plasma & Radiological Engineering (NPRE)
> > University of Illinois at Urbana-Champaign (UIUC)
> > E-mail: huq2090 at gmail.com
> > <Error norm_2_withoutJacobi.png>
Fazlul Huq
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190225/1316421c/attachment.html>
