[petsc-users] GPUs, cud, complex
Smith, Barry F. bsmith at mcs.anl.gov
Thu Feb 21 23:53:06 CST 2019
   Hmm, ex32 suddenly becomes ex39 (and there is no ex39 in the src/ksp/ksp/examples/tutorials/ directory?) I try ex32 with those options and it runs though the -n1 n2 n3 options aren't used.
   Barry
> On Feb 21, 2019, at 6:20 PM, Randall Mackie <rlmackie862 at gmail.com> wrote:
> Hi Barry and Satish,
> Yes, sorry, I meant -dm_mat_type_aijcusparse…..
> Here is an attempt to run ex39 under complex:
> 0]PETSC ERROR: ------------------------------------------------------------------------
> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
> [0]PETSC ERROR: likely location of problem given in stack below
> [0]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
> [0]PETSC ERROR:       INSTEAD the line number of the start of the function
> [0]PETSC ERROR:       is given.
> [0]PETSC ERROR: [0] VecCUDAGetArrayRead line 1283 /home/everderio/DEV/petsc-3.10.3/src/vec/vec/impls/seq/seqcuda/veccuda2.cu
> [0]PETSC ERROR: [0] VecAYPX_SeqCUDA line 185 /home/everderio/DEV/petsc-3.10.3/src/vec/vec/impls/seq/seqcuda/veccuda2.cu
> [0]PETSC ERROR: [0] VecAYPX line 739 /home/everderio/DEV/petsc-3.10.3/src/vec/vec/interface/rvector.c
> [0]PETSC ERROR: [0] KSPBuildResidualDefault line 886 /home/everderio/DEV/petsc-3.10.3/src/ksp/ksp/interface/iterativ.c
> [0]PETSC ERROR: [0] KSPBuildResidual line 2132 /home/everderio/DEV/petsc-3.10.3/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: [0] KSPMonitorTrueResidualNorm line 252 /home/everderio/DEV/petsc-3.10.3/src/ksp/ksp/interface/iterativ.c
> [0]PETSC ERROR: [0] KSPMonitor line 1714 /home/everderio/DEV/petsc-3.10.3/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: [0] KSPSolve_BCGS line 33 /home/everderio/DEV/petsc-3.10.3/src/ksp/ksp/impls/bcgs/bcgs.c
> [0]PETSC ERROR: [0] KSPSolve line 678 /home/everderio/DEV/petsc-3.10.3/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [0]PETSC ERROR: Signal received
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.10.3, Dec, 18, 2018
> [0]PETSC ERROR: ./ex39_cmplx on a linux-gfortran-complex-debug named GPU by root Thu Feb 21 19:03:37 2019
> [0]PETSC ERROR: Configure options --with-clean=1 --with-scalar-type=complex --with-debugging=1 --with-fortran=1 --with-cuda=1 --with-cudac=/usr/local/cuda-10.0/bin/nvcc --download-mpich=./mpich-3.3b1.tar.gz --download-fblaslapack=fblaslapack-3.4.2.tar.gz
> [0]PETSC ERROR: #1 User provided function() line 0 in  unknown file
> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
> I used these options:
> #!/bin/bash
> export PETSC_ARCH=linux-gfortran-complex-debug
> ${PETSC_DIR}/lib/petsc/bin/petscmpiexec -n 1 ./ex39_cmplx \
> -ksp_type bcgs \
> -ksp_rtol 1.e-6 \
> -pc_type jacobi \
> -ksp_monitor_true_residual \
> -ksp_converged_reason \
> -mat_type aijcusparse \
> -vec_type cuda \
> -n1 32 \
> -n2 32 \
> -n3 32 \
> My next step was going to try valgrind and see if that turned something up.
> Thanks, Randy
>> On Feb 21, 2019, at 2:51 PM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>> Randy,
>>   Could you please cut and paste the entire error message you get. It worked for me.
>>   I assume you mean -dm_mat_type aijcusparse  not aijcuda (which doesn't exist).
>> Satish,
>>     I does appear we do not have a nightly test for cuda and complex, could that test be added to the nightly sweeps?
>>  Thanks
>>  Barry
>>> On Feb 14, 2019, at 7:33 PM, Randall Mackie via petsc-users <petsc-users at mcs.anl.gov> wrote:
>>> We are testing whether or not we can benefit from porting our PETSc code to use GPUS.
>>> We have installed PETSc following the instructions here:
>>> https://www.mcs.anl.gov/petsc/features/gpus.html
>>> Using KSP example 32 (ex32.c) to test, and using -dm_vec_type cuda and -dm_mat_type aijcuda
>>> then ex32 runs fine when compiled with a REAL version of PETSc but bombs out when using a COMPLEX version.
>>> Is it possible to run PETSc on GPUS in complex mode?d
>>> Thanks, Randy M.
