[petsc-users] GPUs, cud, complex
Smith, Barry F. bsmith at mcs.anl.gov
Thu Feb 21 16:51:56 CST 2019
  Randy,
    Could you please cut and paste the entire error message you get. It worked for me.
    I assume you mean -dm_mat_type aijcusparse  not aijcuda (which doesn't exist).
  Satish,
      I does appear we do not have a nightly test for cuda and complex, could that test be added to the nightly sweeps?
   Thanks
   Barry
> On Feb 14, 2019, at 7:33 PM, Randall Mackie via petsc-users <petsc-users at mcs.anl.gov> wrote:
> We are testing whether or not we can benefit from porting our PETSc code to use GPUS.
> We have installed PETSc following the instructions here:
> https://www.mcs.anl.gov/petsc/features/gpus.html
> Using KSP example 32 (ex32.c) to test, and using -dm_vec_type cuda and -dm_mat_type aijcuda
> then ex32 runs fine when compiled with a REAL version of PETSc but bombs out when using a COMPLEX version.
> Is it possible to run PETSc on GPUS in complex mode?d
> Thanks, Randy M.
