[petsc-users] Question with filedsplit in PETSc
Zhu, Qiming
qiming2 at illinois.edu
Thu Feb 21 14:23:30 CST 2019
Dear all,
Sorry to disturb you. I am a user of Petsc. I am trying to use Fieldsplit in Petsc to do preconditioning for Navier-Stokes problem. I have some problems when I trying to use Fieldsplit function. I am now defining the nest matrix first, then I get the IS from nested matrix. But I find that my code just work for one core. When I change to parallel case, I could only get zero solution. I wonder is there any special requirements for IS definition in Fieldsplit? I include one code here. If you have any idea, hope you reply soon. Thank you for your help. Thank you very much.
Yours sincerely,
Qiming Zhu,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190221/20e30bc8/attachment.html>
Desc: makefile
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190221/20e30bc8/attachment.obj>
Type: text/x-csrc
Desc: ex5.c
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190221/20e30bc8/attachment.bin>
