[petsc-users] DM error? same code working on local but not on cray system
Thu Feb 21 12:40:36 CST 2019
On Wed, Feb 20, 2019 at 11:19 PM Zin Lin via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hi
> I have a finite difference code based on petsc-3.6.4 working perfectly
> fine on a local server (using about ~40 cpus)
> but the exact same code and the exact same example on a cray system
> compiled with petsc-3.7.4 is giving me the following error:
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Argument out of range
> [0]PETSC ERROR: Partition in y direction is too fine! 0 1
Okay, what this seem to be saying is that you have 1 point in z (which it
seems you do), but
zero processors in that direction. If you set P = 1, then this should go
away.
    Matt
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.7.6, Apr, 24, 2017
> [0]PETSC ERROR: ./farfieldopt_exec on a x86_64 named nid02531 by zinlin
> Wed Feb 20 21:59:21 2019
> [0]PETSC ERROR: Configure options --known-has-attribute-aligned=1
> --known-mpi-int64_t=0 --known-bits-per-byte=8 --known-sdot-returns-double=0
> --known-snrm2-returns-double=0 --known-level1-dcache-assoc=4
> --known-level1-dcache-linesize=64 --known-level1-dcache-size=16384
> --known-memcmp-ok=1 --known-mpi-c-double-complex=1
> --known-mpi-long-double=0 --known-mpi-shared-libraries=0
> --known-sizeof-MPI_Comm=4 --known-sizeof-MPI_Fint=4 --known-sizeof-char=1
> --known-sizeof-double=8 --known-sizeof-float=4 --known-sizeof-int=4
> --known-sizeof-long-long=8 --known-sizeof-long=8 --known-sizeof-short=2
> --known-sizeof-size_t=8 --known-sizeof-void-p=8 --with-ar=ar --with-batch=1
> --with-cc=cc --with-clib-autodetect=0 --with-cxx=CC
> --with-cxxlib-autodetect=0 --with-debugging=0 --with-dependencies=0
> --with-fc=ftn --with-fortran-datatypes=0 --with-fortran-interfaces=0
> --with-fortranlib-autodetect=0 --with-ranlib=ranlib
> --with-scalar-type=complex --with-shared-ld=ar --with-etags=0
> --with-dependencies=0 --with-x=0 --with-ssl=0 --with-shared-libraries=0
> --with-dependencies=0 --with-mpi-lib="[]" --with-mpi-include="[]"
> --with-blas-lapack-lib="-L/opt/cray/libsci/17.06.1.1/CRAY/8.6/x86_64/lib
> -lsci_cray_mp" --with-superlu_dist=1
> --with-superlu_dist-include=/opt/cray/tpsl/17.06.1/CRAY64/8.6/x86_64/include
> --with-superlu_dist-lib="-L/opt/cray/tpsl/17.06.1/CRAY64/8.6/x86_64/lib
> -lsuperlu_dist-64" --with-parmetis=1
> --with-parmetis-include=/opt/cray/tpsl/17.06.1/CRAY64/8.6/x86_64/include
> --with-parmetis-lib="-L/opt/cray/tpsl/17.06.1/CRAY64/8.6/x86_64/lib
> -lparmetis-64" --with-metis=1
> --with-metis-include=/opt/cray/tpsl/17.06.1/CRAY64/8.6/x86_64/include
> --with-metis-lib="-L/opt/cray/tpsl/17.06.1/CRAY64/8.6/x86_64/lib
> -lmetis-64" --with-ptscotch=1
> --with-ptscotch-include=/opt/cray/tpsl/17.06.1/CRAY64/8.6/x86_64/include
> --with-ptscotch-lib="-L/opt/cray/tpsl/17.06.1/CRAY64/8.6/x86_64/lib
> -lptscotch-64 -lscotch-64 -lptscotcherr-64 -lscotcherr-64"
> --with-scalapack=1 --with-scalapack-include=/opt/cray/libsci/
> 17.06.1.1/CRAY/8.6/x86_64/include
> --with-scalapack-lib="-L/opt/cray/libsci/17.06.1.1/CRAY/8.6/x86_64/lib
> -lsci_cray_mpi_mp -lsci_cray_mp" --with-hdf5=1
> --with-hdf5-include=/opt/cray/hdf5-parallel/1.10.0.3/CRAY/8.6/include
> --with-hdf5-lib="-L/opt/cray/hdf5-parallel/1.10.0.3/CRAY/8.6/lib
> -lhdf5_parallel -lz -ldl" --CFLAGS="-hnopattern -O2  -hpic"
> --CPPFLAGS="-hnomessage=11709 " --CXXFLAGS="-hnopattern -O2   -hpic"
> --FFLAGS="-hnopattern -O2  -F -em -hnocaf  -hpic" --LIBS=
> --CXX_LINKER_FLAGS= --PETSC_ARCH=x86_64 --prefix=/opt/cray/pe/petsc/
> 3.7.6.0/complex/CRAY64/8.6/x86_64 --with-64-bit-indices
> [0]PETSC ERROR: #1 DMSetUp_DA_3D() line 298 in src/dm/impls/da/da3.c
> [0]PETSC ERROR: #2 DMSetUp_DA() line 27 in src/dm/impls/da/dareg.c
> [0]PETSC ERROR: #3 DMSetUp() line 744 in src/dm/interface/dm.c
> [0]PETSC ERROR: #4 DMDACreate3d() line 1446 in src/dm/impls/da/da3.c
> [0]PETSC ERROR: #5 setParDataGrid() line 176 in
> /p/home/zinlin/Dev_3DOpt/library/initialize.c
> [0]PETSC ERROR: key 1099516865361 is greater than largest key allowed 751
> [0]PETSC ERROR: #6 PetscTableFind() line 142 in
> /b/cray-petsc/.cray-build/CRAY/86/x86_64/cray-petsc-64-complex/petsc-3.7.6/./include/petscctable.h
> [0]PETSC ERROR: #7 MatSetUpMultiply_MPIAIJ() line 33 in
> src/mat/impls/aij/mpi/mmaij.c
> [0]PETSC ERROR: #8 MatAssemblyEnd_MPIAIJ() line 747 in
> src/mat/impls/aij/mpi/mpiaij.c
> [0]PETSC ERROR: #9 MatAssemblyEnd() line 5194 in src/mat/interface/matrix.c
> [0]PETSC ERROR:
> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> probably memory access out of range
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [0]PETSC ERROR: or see
> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS
> X to find memory corruption errors
> [0]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and
> run
> [0]PETSC ERROR: to get more information on the crash.
> [0]PETSC ERROR: Signal received
> [0]PETSC ERROR: #10 User provided function() line 0 in  unknown file
> Rank 0 [Wed Feb 20 21:59:21 2019] [c13-0c0s8n3] application called
> MPI_Abort(MPI_COMM_WORLD, 59) - process 0
> _pmiu_daemon(SIGCHLD): [NID 02531] [c13-0c0s8n3] [Wed Feb 20 21:59:21
> 2019] PE RANK 0 exit signal Aborted
> now this is testing with just 1 cpu.
> does it have something to do with DM having a problem because y dimension
> is just one pixel (so a 2d problem though DMDAcreate3d was used) ?
> but there was no problem with it before on the local server and
> petsc-3.6.4.
> any help will be appreciated.
> Thanks,
> Zin
> Zin Lin
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190221/6438edd3/attachment-0001.html>
