[petsc-users] About DMDA (and extracting its ordering)
Thibaut Appel
t.appel17 at imperial.ac.uk
Thu Feb 21 12:19:25 CST 2019
Hi Matthew,
Is your first part of your answer (using DMDASetBlockFills) valid only
in the case I create a DMDA object?
Yes I think that is the kind of stencil I am using. I could know how the
stencil looks like exactly, but I preallocate looping, for each process
on all the elements of the stencil, grid node by grid node (which is not
that costly, and "exact")
If I do NOT use a DMDA object and create my MPIAIJ matrix myself, how do
I get the global row indices owned by the process (the "DMDA-like" ones
you mentioned)? The problem is that MatGetOwnershipRange cannot be
called if the matrix hasn't been preallocated, and I need the global
indices to preallocate.
Thibaut
On 21/02/2019 17:49, Matthew Knepley wrote:
> On Thu, Feb 21, 2019 at 11:16 AM Thibaut Appel via petsc-users
> <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
> Dear PETSc developers/users,
> I’m solving linear PDEs on a regular grid with high-order finite
> differences, assembling an MPIAIJ matrix to solve linear systems
> or eigenvalue problems. I’ve been using vertex major, natural
> ordering for the parallelism with PetscSplitOwnership (yielding
> rectangular slices of the physical domain) and wanted to move to
> DMDA to have a more square-ish domain decomposition and minimize
> communication between processes.
> However, my application is memory critical, and I have
> finely-tuned matrix preallocation routines for allocating memory
> “optimally”. It seems the memory of a DMDA matrix is allocated
> along the value of the stencil width of DMDACreate and the manual
> says about it
> “These DMDA stencils have nothing directly to do with any finite
> difference stencils one might chose to use for a discretization”
> And despite reading the manual pages there must be something I do
> not understand in the DM topology, what is that "stencil width"
> for then? I will not use ghost values for my FD-method, right?
> What this is saying is, "You might be using some stencil that is not
> STAR or BOX, but we are preallocating according to one of those".
> If you really care about how much memory is preallocated, which it
> seems you do, then you might be able to use
> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DMDA/DMDASetBlockFills.html
> to tell use exactly how to preallocate.
> I was then wondering if I could just create a MPIAIJ matrix, and
> with a PETSc routine get the global indices of the domain for each
> process: in other words, an equivalent of PetscSplitOwnership that
> gives me the DMDA unknown ordering. So I can feed and loop on that
> in my preallocation and assembly routines.
> You can make an MPIAIJ matrix yourself of course. It should have the
> same division of rows as the DMDA division of dofs. Also,
> MatSetValuesStencil() will not work for a custom matrix.
> Thanks,
> Matt
> Thanks very much,
> Thibaut
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190221/9d20ebf0/attachment.html>
