[petsc-users] MatCompositeMerge + MatCreateRedundantMatrix
Matthew Knepley
knepley at gmail.com
Wed Feb 20 18:31:44 CST 2019
On Wed, Feb 20, 2019 at 6:57 PM Marius Buerkle <mbuerkle at web.de> wrote:
> ok, I think I understand now. I will give it a try and if there is some
> trouble comeback to you. thanks.
Cool.
Matt
> marius
> On Tue, Feb 19, 2019 at 8:42 PM Marius Buerkle <mbuerkle at web.de> wrote:
>> ok, so it seems there is no straight forward way to transfer data between
>> PETSc matrices on different subcomms. Probably doing it by "hand"
>> extracting the matricies on the subcomms create a MPI_INTERCOMM transfering
>> the data to PETSC_COMM_WORLD and assembling them in a new PETSc matrix
>> would be possible, right?
> That sounds too complicated. Why not just reverse
> MPICreateSubMatricesMPI()? Meaning make it collective on the whole big
> communicator, so that you can swap out all the subcommunicator for the
> aggregation call, just like we do in that function.
> Then its really just a matter of reversing the communication call.
> Matt
>> On Tue, Feb 19, 2019 at 7:12 PM Marius Buerkle <mbuerkle at web.de> wrote:
>>> I see. This would work if the matrices are on different subcommumicators
>>> ? Is it possible to add this functionality ?
>> Hmm, no. That is specialized to serial matrices. You need the inverse of
>> MatCreateSubMatricesMPI().
>> Thanks,
>> Matt
>>> marius
>>> You basically need the inverse of MatCreateSubmatrices(). I do not think
>>> we have that right now, but it could probably be done without too much
>>> trouble by looking at that code.
>>> Thanks,
>>> Matt
>>> On Tue, Feb 19, 2019 at 6:15 AM Marius Buerkle via petsc-users <
>>> petsc-users at mcs.anl.gov> wrote:
>>>> Hi !
>>>> Is there some way to combine MatCompositeMerge
>>>> with MatCreateRedundantMatrix? I basically want to create copies of a
>>>> matrix from PETSC_COMM_WORLD to subcommunicators, do some work on each
>>>> subcommunicator and than gather the results back to PETSC_COMM_WORLD,
>>>> namely I want to sum the the invidual matrices from the subcommunicatos
>>>> component wise and get the resulting matrix on PETSC_COMM_WORLD. Is this
>>>> somehow possible without going through all the hassle of using MPI
>>>> directly?
>>>> marius
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190220/cea4d2f4/attachment.html>
