[petsc-users] PCMG: level dependent smoothing steps
Pietro Benedusi pietro.benedusi at usi.ch
Tue Feb 19 09:28:44 CST 2019
Hi Patrick,
It worked, thank you!
Cheers from Lugano,
Pietro
Il giorno 19-feb-2019, alle ore 16:19, Patrick Sanan <patrick.sanan at gmail.com<mailto:patrick.sanan at gmail.com>> ha scritto:
Will it work for you to use
https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCMGGetSmoother.html
to pull out the KSP for the level you're interested in (Note link to PCMGGetSmootherDown() if you want to control up and down smoothers separately) and then use
https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/KSP/KSPSetTolerances.html
to set the maximum iterations?
Am Di., 19. Feb. 2019 um 16:07 Uhr schrieb Pietro Benedusi via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>:
Dear PETSc team,
Is there a way to set the number of smoothing steps done inside a specific multigrid level l ?
Something like:
PCMGSetNumberSmoothDown<https://www.mcs.anl.gov/petsc/petsc-3.8/docs/manualpages/PCMG/PCMGSetNumberSmoothDown.html#PCMGSetNumberSmoothDown>(PC<https://www.mcs.anl.gov/petsc/petsc-3.8/docs/manualpages/PC/PC.html#PC> pc,PetscInt<https://www.mcs.anl.gov/petsc/petsc-3.8/docs/manualpages/Sys/PetscInt.html#PetscInt> n, PetscInt<https://www.mcs.anl.gov/petsc/petsc-3.8/docs/manualpages/Sys/PetscInt.html#PetscInt> l)
In this way I could, for example set 3 smoothing steps on level 1 and 7 smoothing steps on level 2.
Thank you!
Pietro
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190219/1c1e46dd/attachment-0001.html>
