[petsc-users] saving results
Tue Feb 19 06:15:40 CST 2019
On Tue, Feb 19, 2019 at 4:12 AM Sal Am via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> It is a finite-element problem of an RF antenna dielectric interaction
> where all the non-zero elements are on the diagonal of the sparse matrix
> (if that is relevant).
I am unsure whether this is what you mean. If you matrix is diagonal, you
can invert it exactly in a single step so you
do not need a Krylov solver. What equations are you solving? Maxwell?
Electrostatic? What finite element are you using?
    Matt
> More about the matrix: 25Mx25M, 2B non-zeros. I checked the KSPMonitor, it
> seems that I have to write my own routine?
>> Running for a Krylov method for tens of thousands of iterations is very
>> rarely recommended.
> GAMG and BCGS is the only ones that have actually worked for me so far, I
> increased the max_it because it was not enough with the default one. With
> the default tolerance I got ||r(i)||/||b|| in the order of 10^-3, but I
> need more accuracy so I increased the tol to 10^-7 and that is when it
> crashed after ~51000 iterations.
> @Barry
>> I'm guessing you mange your own time stepping (and nonlinear solver if
>> there is one)?
> It is the default from the solver (attached the short code).
>> As Jed says it doesn't make sense to save "partial" solutions within the
>> linear solver.  Just save it every several time-steps.
> Yes maybe I worded it wrong. I did mean to save checkpoints basically such
> that the next time it is running it can pick up from where it crashed.
>    Also the code should not be "crashing" at seemingly long times (after
>> hours) with a Segmentation fault. Send us the full error message and we'll
>> see if there is some way we can help you fix this problem.
> I have added this before, but seemingly they conclusion was that it is
> memory error...although I am not sure how, but I have added the entire
> error.
> On Mon, Feb 18, 2019 at 8:21 PM Smith, Barry F. <bsmith at mcs.anl.gov>
>> there is one)?
>>    You can save the solution with a call to VecView() and then reload the
>> solution with a VecLoad() but you need to manage any other restart data
>> that you may need, like the value of the current time etc.
>> the linear solver.  Just save it every several time-steps.
>>    Barry
>> > On Feb 18, 2019, at 9:47 AM, Sal Am via petsc-users <
>> > Is there a function/command line option to save the solution as it is
>> solving (and read in the file from where it crashed and keep iterating from
>> there perhaps)?
>> > Had a seg fault and all the results until that point seems to have been
>> lost.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190219/ff7bdf1a/attachment.html>
