[petsc-users] superlu_dist+parmetis
Marius Buerkle
mbuerkle at web.de
Fri Feb 15 00:30:11 CST 2019
It works with all options for "-mat_superlu_dist_colperm" save parmetis. or do you mean to change some other option besides colperm?
> Gesendet: Freitag, 15. Februar 2019 um 04:16 Uhr
> Von: "Smith, Barry F." <bsmith at mcs.anl.gov>
> An: "Marius Buerkle" <mbuerkle at web.de>
> Cc: "PETSc users list" <petsc-users at mcs.anl.gov>
> Betreff: Re: [petsc-users] superlu_dist+parmetis
> Given the message the likely cause is SuperLU_DIST got a zero pivot on process 6. Presumably the colperm parmetis is one induced the zero pivot.
> Have you tried other superlu_dist options to find others that do not cause this?
> Barry
> > On Feb 14, 2019, at 6:44 PM, Marius Buerkle via petsc-users <petsc-users at mcs.anl.gov> wrote:
> > Dear PETSc team,
> > I try to run superlu_dist+parmetis with " -mat_superlu_dist_colperm parmetis -mat_superlu_dist_parsymbfact" which gives me the following error
> > [6]PETSC ERROR: Caught signal number 8 FPE: Floating Point Exception,probably divide by zero
> > [6]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> > [6]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> > [6]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
> > [651]PETSC ERROR: #1 User provided function() line 0 in unknown file
> > [653]PETSC ERROR: ------------------------------------------------------------------------
> > [653]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the batch system) has told this process to end
> > [653]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> > [653]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> > [653]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
> > [653]PETSC ERROR: likely location of problem given in stack below
> > [653]PETSC ERROR: --------------------- Stack Frames ------------------------------------
> > [653]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
> > [653]PETSC ERROR: INSTEAD the line number of the start of the function
> > [653]PETSC ERROR: is given.
> > [653]PETSC ERROR: [653] SuperLU_DIST:pzgssvx line 465 /home/cdfmat_marius/prog/petsc/git/petsc/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c
> > [653]PETSC ERROR: [653] MatLUFactorNumeric_SuperLU_DIST line 314 /home/cdfmat_marius/prog/petsc/git/petsc/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c
> > [653]PETSC ERROR: [653] MatLUFactorNumeric line 3124 /home/cdfmat_marius/prog/petsc/git/petsc/src/mat/interface/matrix.c
> > [653]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> > [653]PETSC ERROR: Signal received
> > [653]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> > [653]PETSC ERROR: Petsc Development GIT revision: v3.10.3-980-g66b342c GIT Date: 2018-12-26 13:49:21 -0600
> > [653]PETSC ERROR: /home/cdfmat_marius/prog/transomat_latest_openmpi4.0/transomat on a named h023 by cdfmat_marius Wed Feb 13 23:58:21 2019
> > Any idea?
> > best,
> > marius
