[petsc-users] superlu_dist+parmetis
Marius Buerkle
mbuerkle at web.de
Thu Feb 14 18:44:59 CST 2019
Dear PETSc team,
I try to run superlu_dist+parmetis with " -mat_superlu_dist_colperm parmetis -mat_superlu_dist_parsymbfact" which gives me the following error
[6]PETSC ERROR: Caught signal number 8 FPE: Floating Point Exception,probably divide by zero
[6]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[6]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
[6]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[651]PETSC ERROR: #1 User provided function() line 0 in unknown file
[653]PETSC ERROR: ------------------------------------------------------------------------
[653]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the batch system) has told this process to end
[653]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[653]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
[653]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[653]PETSC ERROR: likely location of problem given in stack below
[653]PETSC ERROR: --------------------- Stack Frames ------------------------------------
[653]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[653]PETSC ERROR: INSTEAD the line number of the start of the function
[653]PETSC ERROR: is given.
[653]PETSC ERROR: [653] SuperLU_DIST:pzgssvx line 465 /home/cdfmat_marius/prog/petsc/git/petsc/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c
[653]PETSC ERROR: [653] MatLUFactorNumeric_SuperLU_DIST line 314 /home/cdfmat_marius/prog/petsc/git/petsc/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c
[653]PETSC ERROR: [653] MatLUFactorNumeric line 3124 /home/cdfmat_marius/prog/petsc/git/petsc/src/mat/interface/matrix.c
[653]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[653]PETSC ERROR: Signal received
[653]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[653]PETSC ERROR: Petsc Development GIT revision: v3.10.3-980-g66b342c GIT Date: 2018-12-26 13:49:21 -0600
[653]PETSC ERROR: /home/cdfmat_marius/prog/transomat_latest_openmpi4.0/transomat on a named h023 by cdfmat_marius Wed Feb 13 23:58:21 2019
Any idea?
best,
marius
