[petsc-users] interchange between two different DMDAs
Wed Feb 13 06:55:28 CST 2019
On Wed, Feb 13, 2019 at 7:25 AM Kun Jiao via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hi,
> I have a problem that need to interchange between two different DMDAs.
> They have the exactly same size, however they are distributed/partitioned
> differently across multiple processes. For instance, one DMDA is created
> with DMDACreated1d, the other is created with DMDACreated3d. How can I
> interchange between different DMDAs with VecScatter, or something else?
Yes, you would need to use VecScatter. Getting this right sounds
nontrivial. What are you using it for?
     Matt
> Regards,
> Kun
> Schlumberger-Private
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190213/affddc7c/attachment.html>
