[petsc-users] Problem in loading Matrix Market format
Tue Feb 12 15:47:14 CST 2019
It definitely should not be there under 'datafiles'. We should put it in an
example, as Junchao graciously agreed to do.
    Matt
On Tue, Feb 12, 2019 at 11:15 AM Zhang, Hong <hzhang at mcs.anl.gov> wrote:
> We have /home/petsc/datafiles/matrices/MtxMarket/mm2petsc.c
> Hong
> On Tue, Feb 12, 2019 at 9:52 AM Zhang, Junchao via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
>> Sure.
>> --Junchao Zhang
>> On Tue, Feb 12, 2019 at 9:47 AM Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> Hi Junchao,
>>> Could you fix the MM example in PETSc to have this full support? That
>>> way we will always have it.
>>>  Thanks,
>>>     Matt
>>> On Tue, Feb 12, 2019 at 10:27 AM Zhang, Junchao via petsc-users <
>>>> Eda,
>>>>   I have a code that can read in Matrix Market and write out PETSc
>>>> binary files.  Usage:  mpirun -n 1 ./mm2petsc -fin <infile> -fout
>>>> <outfile>.  You can have a try.
>>>> --Junchao Zhang
>>>> On Tue, Feb 12, 2019 at 1:50 AM Eda Oktay via petsc-users <
>>>>> Hello,
>>>>> I am trying to load matrix in Matrix Market format. I found an example
>>>>> on mat file  (ex78) whih can be tested by using .dat file. Since .dat file
>>>>> and .mtx file are similar  in structure (specially afiro_A.dat file is
>>>>> similar to amesos2_test_mat0.mtx since they both have 3 columns and the
>>>>> columns represent the same properties), I tried to run ex78 by using
>>>>> amesos2_test_mat0.mtx instead of afiro_A.dat. However, I got the error
>>>>> "Badly formatted input file". Here is the full error message:
>>>>> [0]PETSC ERROR: --------------------- Error Message
>>>>> [0]PETSC ERROR: Badly formatted input file
>>>>> [0]PETSC ERROR: See
>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
>>>>> shooting.
>>>>> [0]PETSC ERROR: Petsc Release Version 3.10.3, Dec, 18, 2018
>>>>> [0]PETSC ERROR: ./ex78 on a arch-linux2-c-debug named
>>>>> 7330.wls.metu.edu.tr by edaoktay Tue Feb 12 10:47:58 2019
>>>>> [0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
>>>>> --with-fc=gfortran --with-cxx-dialect=C++11 --download-openblas
>>>>> --download-metis --download-parmetis --download-superlu_dist
>>>>> --download-slepc --download-mpich
>>>>> [0]PETSC ERROR: #1 main() line 73 in
>>>>> /home/edaoktay/petsc-3.10.3/src/mat/examples/tests/ex78.c
>>>>> [0]PETSC ERROR: PETSc Option Table entries:
>>>>> [0]PETSC ERROR: -Ain
>>>>> /home/edaoktay/petsc-3.10.3/share/petsc/datafiles/matrices/amesos2_test_mat0.mtx
>>>>> [0]PETSC ERROR: ----------------End of Error Message -------send
>>>>> entire error message to petsc-maint at mcs.anl.gov----------
>>>>> application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0
>>>>> [unset]: write_line error; fd=-1 buf=:cmd=abort exitcode=1
>>>>> system msg for write_line failure : Bad file descriptor
>>>>> I know there is also an example (ex72) for Matrix Market format but in
>>>>> description, it is only proper for symmmetric and lower triangle, so I
>>>>> decided to use ex78.
>>>>> Best regards,
>>>>> Eda
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190212/f5a90a25/attachment.html>
