[petsc-users] Problem in loading Matrix Market format
Eda Oktay eda.oktay at metu.edu.tr
Tue Feb 12 01:50:05 CST 2019
Hello,
I am trying to load matrix in Matrix Market format. I found an example on
mat file  (ex78) whih can be tested by using .dat file. Since .dat file and
.mtx file are similar  in structure (specially afiro_A.dat file is similar
to amesos2_test_mat0.mtx since they both have 3 columns and the columns
represent the same properties), I tried to run ex78 by using
amesos2_test_mat0.mtx instead of afiro_A.dat. However, I got the error
"Badly formatted input file". Here is the full error message:
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Badly formatted input file
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.10.3, Dec, 18, 2018
[0]PETSC ERROR: ./ex78 on a arch-linux2-c-debug named 7330.wls.metu.edu.tr
by edaoktay Tue Feb 12 10:47:58 2019
[0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
--with-fc=gfortran --with-cxx-dialect=C++11 --download-openblas
--download-metis --download-parmetis --download-superlu_dist
--download-slepc --download-mpich
[0]PETSC ERROR: #1 main() line 73 in
/home/edaoktay/petsc-3.10.3/src/mat/examples/tests/ex78.c
[0]PETSC ERROR: PETSc Option Table entries:
[0]PETSC ERROR: -Ain
/home/edaoktay/petsc-3.10.3/share/petsc/datafiles/matrices/amesos2_test_mat0.mtx
[0]PETSC ERROR: ----------------End of Error Message -------send entire
error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0
[unset]: write_line error; fd=-1 buf=:cmd=abort exitcode=1
system msg for write_line failure : Bad file descriptor
I know there is also an example (ex72) for Matrix Market format but in
description, it is only proper for symmmetric and lower triangle, so I
decided to use ex78.
Best regards,
Eda
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190212/360f5d38/attachment.html>
