[petsc-users] Meaning of PETSc error code 77
aditya kumar
adityakr42 at gmail.com
Fri Feb 8 11:40:24 CST 2019
Hello,
I am using PETSc with FEniCS project libraries to solve a nonlinear
problem. I am using PETSc Krylov solver with the following configuration
pc = PETScPreconditioner("petsc_amg")
PETScOptions.set("mg_levels_ksp_type", "chebyshev")
PETScOptions.set("mg_levels_pc_type", "jacobi")
PETScOptions.set("mg_levels_esteig_ksp_type", "cg")
PETScOptions.set("mg_levels_ksp_chebyshev_esteig_steps", 50) solver_u =
PETScKrylovSolver("cg", pc)
I am encountering this error sometimes during the solution of the linear
system:
Error: Unable to successfully call PETSc function 'KSPSolve'. *** Reason:
PETSc error code is: 77 (Petsc has generated inconsistent data). *** Where:
This error was encountered inside
/tmp/dolfin/dolfin/la/PETScKrylovSolver.cpp.
*** Process: 130
Can anybody help me in understanding the possible reasons for this error
code? Or refer me to any available documentation? It will be really
helpful.
Also, I will like to know if there is a way to prevent the code from
stopping due to such PETSc errors, so that I can tweak some parameters to
hopefully make it progress.
Thanks and Regards,
Aditya
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190208/bf2abbbe/attachment.html>
